Homework Help: Diameter of critical object
  1. Oct 13, 2007 #1
    Diameter of "critical" object
    A pressure of [itex] \textrm{2} \cdot \textrm{10}^{9} [/itex] Pa on a time scale of [itex] \textrm{10}^{9} [/itex] yr, holds half way to the center of the "critical" objects.
    Estimate the diameter using two densities: [itex] \rho = 3 \textrm{g}/ \textrm{cm} ^{3} [/itex] and [itex] \rho = 1 \textrm{g}/ \textrm{cm} ^{3} [/itex].
    2. Relevant equations
    I was told to use the equation for hydrostatic equilibrium
    [tex] \frac{dp_}{dr} = -\frac{GM_{r}\rho}{{r}^{2}} [/tex]
    where
    [tex] M_{r} = \frac{4\pi {r}^{3}\rho}{3} [/tex]
    3. The attempt at a solution
    I chose 2r as the radius for the entire object, then r is the radius half way.
    I then inserted [itex]M_{r}[/itex] into the equation for hydrostatic equilibrium and integrated the new equation
    [tex]p = \int_{2r}^r -\frac{{4\pi G} \rho^{2}}{3}r^\prime\, dr^\prime = \frac{{4\pi G} \rho^{2}}{3} ((2r)^{2}-r^{2}) = 2 \pi G \rho^{2} r^{2}[/tex]
    Then I just inserted all the constants and solved the equation for r.
    [tex]\rho = 3 \textrm{g}/ \textrm{cm} ^{3} \Rightarrow r \approx 728,183 km \Rightarrow d=4r \approx 3000km [/tex]
    and
    [tex]\rho = 1 \textrm{g}/ \textrm{cm} ^{3} \Rightarrow r \approx 2184,550 km \Rightarrow d=4r \approx 8740 km [/tex]
    I was told that I should get a diameter between 500-600 km. Obviously I'm no where near that, so I really need help with this because I have to present a solution on October 18th.
Draft saved Draft deleted
