Rise of Cancer: Examining the Role of Sugar and Refined Carbs
In summary: I forget who it was, sorry.The increase in obesity isn't about carbs, it's about eating too many calories. Taubes is a fruitcake. Cute, that brought a smile to my face :)
  • #36
russ_watters said:
Those are really terrrible articles. They take something that is true (and blindingly obvious) and twist it around to imply - completely incorrectly - that it's false, for the sake of sucking you into reading the article. Time does that all the time and IIRC, they got a huge amount of negative feedback for that article.
Exercise alone will make you lose weight.
That statement is true. It has to be. The human body's weight gain or loss is determined by the caloric balance: calories in - calories out = calories stored. If you increase the calories out while maintaining the calories in, you lose weight. Period.
Unfortunately, that's not true. Our body is far more complex than a simplistic calories in = calories out. The laws of theormodynamics are not violated (obviously!) but the set point changes depending on the type of calories.
For eg, if you feed 2 groups the same 2000 calories, but one where 80% are from carbs (mostly refined) and the other where 80% is fat, the 2 groups will gain different amounts of weight.
One simple factor is the energy the body uses in the digestion process, which is called the thermic effect of food. The thermic effect of protein is about twice that of carbohydrate or fat.
I will find the link later, but there was a study done at the City of Hope Medical Center in Duarte, California. Here they studied two groups of overweight people, both on medically supervised low-calorie liquid diets. One group added 3 ounces of almonds to their daily diet, while the other group added the same amount of calories from complex carbs like popcorn and Triscuit crackers. Both groups ate the same number of calories daily, about 1,000. During the 24-week study, the almond-eating group lost more weight even though they ate the same number of calories as the carb group.
There have been other studies done as well, I will need some time to dig them out.
Meanwhile, here's a nice article from Dr. Feinman
http://www.nutritionj.com/content/3/1/9
Quoting from the conclusion -
A review of simple thermodynamic principles shows that weight change on isocaloric diets is not expected to be independent of path (metabolism of macronutrients) and indeed such a general principle would be a violation of the second law. Homeostatic mechanisms are able to insure that, a good deal of the time, weight does not fluctuate much with changes in diet – this might be said to be the true "miraculous metabolic effect" – but it is subject to many exceptions. The idea that this is theoretically required in all cases is mistakenly based on equilibrium, reversible conditions that do not hold for living organisms and an insufficient appreciation of the second law. The second law of thermodynamics says that variation of efficiency for different metabolic pathways is to be expected. Thus, ironically the dictum that a "calorie is a calorie" violates the second law of thermodynamics, as a matter of principle.
Plus eating fewer than a certain threshold of calories puts your body in starvation mode and drastically reduces your metabolism too.
The correct message that should be transmitted here is this: Exercise alone will cause you to lose weight, but it will cause you to want to eat more, so you have to be vigilant in maintaining your caloric intake. This really should not be hard to grasp, nor to do as long as you make yourself conscious of it. Eating habits are just that - habits. You should be able to control your caloric intake by eating what you normally do because you know what you normally eat. Ie, if you used to eat the "medium" extra value meal and now you're eating the "supersize", you're eating more. Obviously, this will cut into the weight loss, so you shouldn't do it.
Duh.
Here's a 5-part rebuttal:
http://www.examiner.com/diets-and-e...-why-exercise-won-t-make-you-thin-part-1-of-5
Maybe this guy is a weirdo, but that does not matter. Resorting to ad hominem won't negative his evidence. And the evidence is there.
The Terry Wilkin study of childhood obesity, for e.g.
http://adc.bmj.com/content/early/2008/06/30/adc.2007.135012.abstract
There were no associations between physical activity and changes in any measure of body mass or fatness over time in either sex (e.g. BMI-SDS: r=-0.02 p=0.76). However, there was a small-to-moderate inverse association between physical activity and change in composite metabolic score (r=-0.19, p<0.01). Mixed effects modeling showed that the improvement in metabolic score among the more active compared to the less active children was linear with time (-0.08 z-scores/year, p=0.001).
Exercise is beneficial for lots of other things, but not weight loss.
Merely saying that if you starve and exercise you lose weight is no solution to anything. Its your bodies complicated homeostasis mechanism which makes you hungrier when you exercise. Which is what makes the calories in = calories out cliche a myth.
Exercise is not a useful method for weight loss. As Taubes says, the original Finnish report cited by most researchers for the benefit of exercise in weight loss is far from conclusive.
Yet the Finnish report, the most scientifically rigorous review of the evidence to date, can hardly be said to have cleared up the matter. When the Finnish investigators looked at the results of the dozen best-constructed experimental trials that addressed weight maintenance—that is, successful dieters who were trying to keep off the pounds they had shed—they found that everyone regains weight. And depending on the type of trial, exercise would either decrease the rate of that gain (by 3.2 ounces per month) or increase its rate (by 1.8 ounces). As the Finns themselves concluded, with characteristic understatement, the relationship between exercise and weight is “more complex” than they might otherwise have imagined.
The problem is that light exercise burns an insignificant number of calories, amounts that are undone by comparatively effortless changes in diet. In 1942, Louis Newburgh of the University of Michigan calculated that a 250-pound man expends only three calories climbing a flight of stairs—the equivalent of depriving himself of a quarter-teaspoon of sugar or a hundredth of an ounce of butter. “He will have to climb twenty flights of stairs to rid himself of the energy contained in one slice of bread!” Newburgh observed. So why not skip the stairs, skip the bread, and call it a day?
Biology news on Phys.org
  • #37
Siv, there is a lot of confusion that seems to originate from differences in how much water people hold onto when they are on a keto diet, versus a higher carb diet that keeps them out of ketosis. people on a ketogenic diet can lose several kilograms of water weight, and unless you correct for this in your studies by doing something like a DEXA scan to measure body composition more directly, you're going to get screwy results. if you're just looking at a person's kg weight changes, then you don't really know what you're looking at. it is easy to misinterpret this as a change in "setpoint".
  • #38
Actually the Atkins water weight thing is just a myth.
http://community.discovery.com/eve/forums/a/tpc/f/634109964/m/8011922838 [Broken]
Anyway I am not recommending any diet here, but just acknowledging the real harm that refined carbs and sugars do. Apart from busting the exercise weight loss myth.
  • #39
no, it is not a myth. and the reason you gain water back on atkins is that atkins is only keto on the induction phase, and after you switch over to a more normal carb intake in later parts of the diet, the water comes back. have you read atkins? you realize it's got different phases and isn't the zero-carb caricature that the press makes it out to be?
  • #40
Ok, if you can skip the patronising assertions, maybe we can have a more productive debate ? :smile:
  • #42
Siv said:
Unfortunately, that's not true...
You failed to address the point I made even a little bit. Besides the irrelevancies you disucssed, like the effects of different types of food (which may be interesting, but have nothing to do with exercise), you used the same logical disconnect as the article did! The fact that eating affects weight gain/loss does not in any way imply that exercise doesn't. The fact that eating less works better doesn't change the fact that exercising more still works. The fact that people who exercise more tend to start eating more doesn't change the fact that if they exercise more while holding their food intake steady they lose weight.
Again: Exercise alone can make you lose weight as long as you really are just adding exercise and not adding extra eating as well.
I think part of the disconnect is that what is the better way to lose weight is different for different people. For most it is a combination of the two, but for many people, the eating is the much bigger problem and therefore the much easier to correct. Example:
Many studies have compared weight loss resulting from changing diet versus increasing activity. Most often, weight loss during programs focused on dietary change produced two to three times greater weight loss than programs focused on exercise.
http://www.msnbc.msn.com/id/13821677/
That's easy to believe. Particularly if you're out of shape, it is very difficult to burn more than a few hundred (say 300) extra calories a day. But 300 calories a day is equal to only two sodas, and that's not a difficult thing to cut out of a diet.
  • #43
very well. as for why atkins works (at least for some people), i think what you will find is that http://www.ajcn.org/cgi/content/full/87/1/44" [Broken]. this results in people eating below their maintenance level of calories, they burn more than they eat, and start losing adipose mass. and because they also lose a lot of water in the beginning, the results appear more dramatic than they really are. losing adipose mass probably doesn't hurt your lipid profiles, either, as many people who unfat themselves find out.
  • #44
Ok, very convenient way of dismissing all the info/links/research I presented.
I let moderator unpleasantness drive me away from PF once, but not again. I should have been able to develop a thick skin by now :wink:
Let me try again.
You said - "The human body's weight gain or loss is determined by the caloric balance: calories in - calories out = calories stored. If you increase the calories out while maintaining the calories in, you lose weight. Period."
To which I responded with - "Unfortunately, that's not true. Our body is far more complex than a simplistic calories in = calories out. The laws of theormodynamics are not violated (obviously!) but the set point changes depending on the type of calories.
Plus eating fewer than a certain threshold of calories puts your body in starvation mode and drastically reduces your metabolism too."
Re: your exercise claim, I responded to that with - "Maybe this guy is a weirdo, but that does not matter. Resorting to ad hominem won't negate his evidence. And the evidence is there.
http://adc.bmj.com/content/early/200...35012.abstract [Broken]
Merely saying that if you starve and exercise you lose weight is no solution to anything. Its your bodies complicated homeostasis mechanism which makes you hungrier when you exercise. Which is what makes the calories in = calories out cliche a myth."
Please read what I wrote. I said that exercise was not a useful method for weight loss. Period.
Precisely because you cannot eat the same if you exercise more. Our body's homeostasis works to ensure that we compensate by eating more too. Artificially and forcefully starving yourself will never work long term and is not sustainable. What is far more likely to work is something which keeps you full and makes you less hungry.
Also, I don't agree that if you eat the same number of calories, the more you exercise, the more weight you will lose. Show me a study which shows this linear or geometric relation. I also contest that the type of food you eat will also affect how much you lose. As stated above, the laws of thermodynamics have been incorrectly interpreted for too long w.r.t nutrition and weight loss.
  • #45
Here are some media articles debunking the calories in = calories out myth (the dumbing down of the complex mechanism of our bodies).
http://migraineur.wordpress.com/2007/11/11/calories-in-calories-out/
http://www.naturalnews.com/027126_dieting_food_health.html.
Quoting from above -
The idea of calories in versus calories out is a complete myth. The body is far more complex than that. There are hundreds upon hundreds of activities performed in your body at any given time - it needs fuel to perform these functions. If your body is not receiving the materials it needs from your diet, then it has no choice but to take from its only other source - itself. Most people assume your body will only use its stored fat for its various needs, but this is not true. Your body will also draw from your bones, muscle tissue and organ tissue. You may lose some fat, but it will be at the sacrifice of vital living tissues. This is not a good state to be in, so your body slows down your metabolism to prevent its own destruction. After all, your body has one natural instinct - to survive.
http://www.dummies.com/how-to/content/busting-the-great-myths-of-fat-burning.html.
A quote from the above :
Technically, once you've been exercising for 15 or 20 minutes, your body has made the shift to using a higher percentage of fat for fuel. But again, if you're trying to lose weight, it's about the total number of calories burned, not necessarily the fuel source.
For example, say that at rest you burn up to 60 percent fat. When you enter the initial phases of intense exercise, the ratio changes. You may now burn only 30 percent fat because your body is using quick-energy carbohydrates. Once the exercise is sustained, the body switches back to using a higher percentage of fat to fuel the movement (up to 75 percent fat). In this aerobic phase of exercise, a higher percentage of fat is being used for energy. But if you aren't working out for a very long period, you may still burn more total calories and, therefore, more fat calories working out harder. Put another way, if burning as many calories as you can is the best way to lose weight, even a dummy can figure out which activity of the following is going to give the best results (answer: jogging and sprinting), even though their fat-burning quota is on the low end of the ratio.
So you see, not only is it not a linear relationship, it depends on the type of exercise as well. Makes us realize how dangerous it is to oversimplify anything.
  • #46
Re: the water weight loss myth re: Atkins, here's an article which comprehensively debunks it.
http://www.diabeteshealth.com/read/2006/09/01/4838/losing-weight-on-a-lower-carb-diet/
Carbohydrates Can Cause Water Retention
Because stored glucose binds water, there is a diuretic effect during the first few days of the Induction phase of the Atkins Lifestyle, when carbs are limited to 20 grams daily. That’s why people on diuretic medications are cautioned when cutting carbs to do so with the supervision of their doctor to avoid overmedication.
For anyone following a lower-carb plan, it is important to stay properly hydrated. Most people do very well during the Induction stage. However, if help is needed to replace lost minerals because of an excessive loss of water, taking a multi-mineral every day or drinking two cups of salty broth daily works quite well for most people.
So its not that Atkins causes initial water weight loss but that high carb diets cause water retention.
Taubes also explains this beautifully in his book.
  • #47
Siv, please stop using blog articles to backup your assertions.
  • #48
These 2 are not blogs.
Plus some of these health blogs are a wealth of information. Run by really clever and qualified scientists/doctors who keep up to date with the latest research.
BTW was looking at the link you posted re: ketogenic diets. And it does not really support your case much.
The significantly (P = 0.006) greater weight loss with the LC diet (1.99 kg) than with the MC diet was due, in part, to the difference in water loss with the ketogenic diet, although this difference did not reach significance (0.71 kg; P = 0.158) (Table 4). There also tended to be greater losses of fat mass (1.05 kg; P = 0.083) and fat-free mass (0.94 kg; P = 0.054) with the LC diet than with the MC diet. In the 4-compartment model used, glycogen is considered part of the fat-free mass, and it cannot easily be directly measured. Examination of the change in protein mass (rather than in fat-free mass), calculated from the 4-compartment model, indicated that there was a weight loss of 0.25 and 0.02 kg with the LC ketogenic and MC nonketogenic diets, respectively (P = 0.281; SED: 0.202).
0.71 kgs ?? The margin of error would have been higher, that's why its not statistically significant.
  • #49
you know i specifically used that study for appetite suppression.
but if you want something with more significance, try this one: http://www.annals.org/content/140/10/769.full
if you want something really rigid (heavily controlled inpatient vs. outpatient), then this is interesting: http://www.ncbi.nlm.nih.gov/pmc/articles/PMC333231/
  • #50
When studying the effects of various interventions on human health, it is notoriously difficult to glean actionable information from anyone single scientific study. Often these are observational studies that are subject to many confounding factors and limited by small sample sizes, poorly controlled conditions, and short observation periods. Even well-controlled, randomized clinical trials can often reach opposing conclusions.
We can reach better conclusions, however, by performing a systematic literature review: examining the scientific literature as a whole by using strict criteria to select the highest quality studies and evaluating the results of the all of the studies as a whole. Although there may be individual studies within the review that support either side of an assertion, if a large majority of the studies support one side of an argument, we can be much more confident about their conclusions.
The 2007 report, Food, Nutrition, Physical Activity, and the Prevention of Cancer by the World Cancer Research Fund and American Institute for Cancer Research does just this. I will summarize the relevant findings of the review below. The full report is available here: http://www.dietandcancerreport.org/
Because obesity is an established cause of cancer, the report examined the risk factors for weight gain, overweight, obesity. The systematic literature review of this area covered 207 publications investigating the determinants of weight gain, overweight and obesity. The report concludes:
"The epidemiological evidence on physical activity is substantial and consistent. There is robust mechanistic evidence, particularly in relation to its impact on appetite regulation and energy balance. Overall, the evidence that all types of physical activity protect against weight gain, overweight, and obesity is convincing. It has this effect by promoting appropriate energy intake. Conversely, the evidence can be interpreted as showing that sedentary living is a cause of weight gain, overweight, and obesity."
The panel gives the evidence linking physical activity to a decreased risk of weight gain, overweight and obesity its highest ranking of convincing. The panel ranks the strength of evidence linking energy-dense foods, sugary drinks, and fast food to an increased risk of weight gain, overweight and obesity as probable.
Furthermore, while Siv has claimed that changes to appetite that accompany physical activity cancel the effects of exercise, the report claims otherwise:
"Control [of appetite] seems to be least effective at relatively low levels of physical activity, meaning that sedentary people tend to gain weight more readily than active people. Conversely, although high levels of physical activity increase energy requirements and appetite, the likelihood of consuming more than is needed is lower."
Therefore, although some may be able to produce studies showing otherwise, the preponderance of high quality scientific evidence strongly supports the assertion that physical activity can prevent weight gain, overweight and obesity.
Since this topic was originally on cancer, I will quote the panel's conclusions about the effects of sugar consumption on the risk for cancer:
"The evidence is hard to interpret. There is limited evidence suggesting that sugar is a cause of colorectal cancer."
This does not mean that there is convincing evidence that sugar is not a cause of cancer. Rather, the report concludes that there is not sufficient high quality evidence to reach a solid conclusion.
  • #51
Good post!
  • #52
You claimed that Atkins weight loss was mostly water loss, so I thought your links would support that. Anyway let's look at what you have now ...
Ok, this is what I have from your first study -
Changes in total body water explained most of the change in fat-free mass in both groups. The expected mean change in total body water was −2.4 kg (CI, −2.9 to −2.0 kg) in the low-carbohydrate diet group and −1.8 kg (CI, −2.3 to −1.3 kg) in the low-fat diet group (mean difference, −0.6 kg [CI, −1.3 to 0 kg]; P = 0.052). However, the low-carbohydrate diet group lost a greater amount of total body water in the first 2 weeks of the study than did the low-fat diet group (−1.1 kg versus −0.5 kg; mean difference, −0.6 kg [CI, −1.0 to −0.2 kg]).
The differences are again very marginal. - 2.4 kg vs 1.8 kg and 1.1 vs 0.6 kg.
Come on, its not even statistically significant, IMO.
And let's look at the actual results from that study, shall we ?
Results: A greater proportion of the low-carbohydrate diet group than the low-fat diet group completed the study (76% vs. 57%; P = 0.02). At 24 weeks, weight loss was greater in the low-carbohydrate diet group than in the low-fat diet group (mean change, −12.9% vs. −6.7%; P < 0.001). Patients in both groups lost substantially more fat mass (change, −9.4 kg with the low-carbohydrate diet vs. −4.8 kg with the low-fat diet) than fat-free mass (change, −3.3 kg vs. −2.4 kg, respectively). Compared with recipients of the low-fat diet, recipients of the low-carbohydrate diet had greater decreases in serum triglyceride levels (change, −0.84 mmol/L vs. −0.31 mmol/L [−74.2 mg/dL vs. −27.9 mg/dL]; P = 0.004) and greater increases in high-density lipoprotein cholesterol levels (0.14 mmol/L vs. −0.04 mmol/L [5.5 mg/dL vs. −1.6 mg/dL]; P < 0.001). Changes in low-density lipoprotein cholesterol level did not differ statistically (0.04 mmol/L [1.6 mg/dL] with the low-carbohydrate diet and −0.19 mmol/L [−7.4 mg/dL] with the low-fat diet; P = 0.2). Minor adverse effects were more frequent in the low-carbohydrate diet group.
Minor adverse effects at the initial stages aside (constipation, headache and the likes), the low carb results were spectacular !
Ok, your second study ... the period is for 50 days total, but in 3 10-day periods. That is very short, IMO. Even 24 weeks in the prev study were short but at least not as short as 50 days. So I don't really find anything significance in the very short term water weight loss.
In any case, the reason for the water loss has also been explained very well b Taubes and others. Carbs make people retain water, as I explained.
  • #53
That is true. But the whole problem with nutrition science (if you can call it science) is how people stretch epidemiological data to support their arguments.
Epidemiological data faces huge problems when it tries to take the place of scientific trials.
Here's an award winning article from Gary Taubes in the National Association of Science Writers on the limitations of epidemiology.
http://www.nasw.org/awards/1996/96Taubesarticle.htm
Problem again, is that it is an epidemiological report. A meta analysis, but one based on epidemiological data nonetheless.
High quality evidence ? No.
I will go through the link in detail later when I have time.
Meanwhile, people who have tried to actual clinical trials find quite the opposite results.
Dr. Timothy Church for eg.
At http://www.plosone.org/article/info:doi/10.1371/journal.pone.0004515
This was a 6 month study. But the surprising finding was that, the control group had a better outcome than the high exercise group :smile:
The primary finding from this large exercise intervention trial in postmenopausal women is that the difference between actual weight loss and predicted weight loss (compensation) increases with exercise dose. We confirmed the findings of previous studies that a relatively high dose of exercise (12 KKW or 194 minutes per week) results in compensatory mechanisms that attenuate weight loss in previously sedentary women. However, a dose of exercise consistent with the exercise prescription for general health (8 KKW or 136 minutes per week) did not result in compensation as the actual weight loss closely matched the predicted weight loss. An exercise dose of 4 KKW (72 minutes per week) also resulted in weight loss that slightly exceeded the predicted weight loss. Our findings are important because most exercise guidelines for weight loss recommend 200–300 minutes per week and we provide evidence that this amount of exercise induces compensation that results in significantly less weight loss than predicted.
So 10-15 mins exercise per day (the most sedentary of the 3 groups) seems the most beneficial !
Please also see the Terry Wilkin study re: childhood obesity that I posted earlier.
There were no associations between physical activity and changes in any measure of body mass or fatness over time in either sex (e.g. BMI-SDS: r=-0.02 p=0.76). However, there was a small-to-moderate inverse association between physical activity and change in composite metabolic score (r=-0.19, p<0.01). Mixed effects modeling showed that the improvement in metabolic score among the more active compared to the less active children was linear with time (-0.08 z-scores/year, p=0.001). Again, this is an actual trial, not an epidemiological analysis.
Other studies are mentioned in this article
http://www.cbc.ca/health/story/2009/05/07/school-exercise-obesity-child.html [Broken]
Rather than relying on epidemiological evidence, if you end up doing actual studies, however faulty they may be, the results are far more accurate and practical.
Blaming our sedentary lifestyles for obesity without any actual evidence is something for which Jean Mayer requires the most credit. And he promoted his pro-exercise message with a religious zeal like a moral crusade.
People are exercising far more today than they did several decades ago. So, has the obesity declined or gone up ?!
  • #54
3 quick points because I'm running late. Firstly, as Ygg pointed out Systematic/Meta-Reviews>>>>>> case-controls, cohorts or any other primary literature findings. Because, systematic reviews offer to us a summation of findings from many different sources, we are able to derive trends in them. As Ygg's review also points out that trend is to show that when you exercise a long with watching your diet you lose weight.
Secondly to your underlined sentence above. Many people do exercise more, however people also eat larger meal portions than they did in say the 50's or 60's. A serving of meat for most people should be about a deck of cards, when was the last time in America you've seen a correct portion of meat on the menu? Being a medical student, I eat out a lot--Restaurants take the "American dream" (more for less) approach to advertising. In fact, that approach to advertising is everywhere around us in the food industry--"More for less".
And finally, can you propose a biochemical mechanism whereby different types of carbohydrates are preferentially stored as fat? Without being able to show this any evidence of differential carb storage is anecdotal and more likely attributed to confounding factors (even if the confounder is a food specific factor, for example something else in the food with those "bad" carbs which promotes more fat storage)Thanks
Edit: Your BMJ link isn't working by the way.
  • #55
Unfortunately, whether its one study or a meta analysis, if its epidemeliogical data, its pretty much often always misleading. Did you read the link I posted with Taubes award winning article on that ?
Its been beautifully explained, by Taubes and others. Carbs drive insulin drive fat storage (and other bad things). Read the book, its hard for me to summarize an entire book with tons of studies into one post. As I was telling someone else on this forum, the book is like pubmed, so its hard reading. But the plethora of evidence is worth it.
Oops, sorry. It was working yesterday. Let me check.
  • #56
Not sure why there seems to be so much sure footed posturing in this thread. Obesity - is evidently a spectrum disorder - not a single disease. And as a spectrum disorder will have a spectrum of causes. Until we are in a position to ascribe the different causes of obesity to their respective populations - none of these studies will be in a position to make specific claims. All that remains is statistical correlation and postulation.
  • #57
i suppose you could make the same argument about alcoholism and drug use, but it's not helpful for explaining what is going on in the majority of the population. it's really just excuse-making for a population whose primary problem is they enjoy continuing their behavior more than they dislike the negative side effects.
the really interesting thing about this "disease" of obesity is that if you take away their freedoms and only allow them to consume a healthy amount of calories, they will lose weight.
  • #58
Ok, this is what I have from your first study - The differences are again very marginal. - 2.4 kg vs 1.8 kg and 1.1 vs 0.6 kg.
And let's look at the actual results from that study, shall we ? Minor adverse effects at the initial stages aside (constipation, headache and the likes), the low carb results were spectacular !
where did you explain that carbs make people retain water?
and yes, low-carb diets (temporary diets for fat reduction(my fave would be the protein-sparing modified fast, with almost no fat at all)) can be spectacular for a number of reasons. as mentioned before, ketosis can have a significant appetite-suppressive effect, and this makes it easier for people stay on the diet. it also makes it easier for them to control their intake and consume fewer calories. and that is the important point I'm trying to get across. there is nothing magical about carbs making you fat, it's an excess of calories consumed that makes you fat.
and look again at the inpatient study. i think what you will see is that when you actually control what people eat (they can't cheat by sneaking candy and lying about it - skewing your results), fat loss on either a low or med. carb diet is similar.
the other thing to remember is that these studies are primarily about dieting for fat loss, and really don't make a case for eating a ketotic diet on a chronic basis. for that, go look up the papers where they mention the problems with keeping epilepsy patients on keto diets.
  • #59
Agree totally Proton - its the only approach that works. I just find it strange that people want to ascribe it to all these different specific things - what's the point. We don't know - but as you say - what we do know is that if you limit intake and expend more energy - its a solution - irresepective of the specifics of the problem.
Of course people don't want to hear that because it means that they can control the problem - it just takes a heck of a lot of effort and fighting against what our evolutionary biology has dictated we do! In a world of scarcity it was wise to crave fatty sugary food! The scenario has changed!
Manufacturers also don't want to hear it because they can't make money out of people by selling supplements, plans, pills etc
I always am amazed at the amount of money spent on diabetes and CV research - when in fact if we changed attitudes at a young age - we could prevent themajority of these diseases even occurring. Prevention is ultimate, cure is an expensive band aid.
  • #60
No I don't mean how carbohydrates drive insulin regulation and vise-versa. I'm well versed in that.
However, you claimed that various types of carbohydrates promoted this more than others, if I'm remembering correctly (a couple pages back I believe).
What I was asking for is, what is the biochemical mechanism or hypothesis that would explain this. Otherwise, as I pointed out, its just as likely that other confounding factors associated with those 'types of carbs' are the culprit in the up-regulation of insulin and not the 'type' of carb itself.
For example. You claimed that HFCS (a mix of fructose and glucose) is 'worse' for you than sucrose (fructose and glucose). What is the proposed biochemical mechanism for this? And on what basis do you discard the hypothesis that foods with HFCS may contain another factor that promotes obesity over sucrose based ones (if it does at all)?
  • #61
You would have a valid point if the report relied solely on epidemiologial evidence. But, it does not. Of the studies considered linking physical activity to weight maintenance and change, the panel considered 17 randomized controlled trials versus 62 consort studies. No doubt, the experts on the panel gave more consideration to the randomized trials than the consort studies.
For example, we can consider the studies that examined the effects of total physical activity on weight maintenance and change in adults. In this category, there were three randomized controlled trials and 16 consort studies. Two of the randomized controlled trials showed positive effects of physical activities while one of the trials showed no effect. All of the 16 consort studies in this area showed a positive effect. The citations for the three randomized trials are below:
  • Schmitz KH, Jensen MD, Kugler KC, et al. Strength training for obesity prevention in midlife women. Int J Obes 2003;27:326-33.
  • Borg P, Kukkonen-Harjula K, Fogelholm M, et al. Effects of walking or resistance training on weight loss maintenance in obese, middle-aged men: a randomized trial. Int J Obes 2002;26:676-83.
  • Fogelholm M, Kukkonen-Harjula K, Nenonen A, et al. Effects of walking training on weight maintenance after a very-low-energy diet in premenopausal obese women: a randomized controlled trial. Arch Intern Med 2000;160:2177-84.
As I said before, some studies will show no effect and some studies will show a positive effect. However, considering the evidence as a whole shows that the bulk of the evidence points to physical activity as a protective factor against weight gain.
I'm not so sure you're reading the study correctly. Look at at the data in http://www.plosone.org/article/showImageLarge.action?uri=info%3Adoi%2F10.1371%2Fjournal.pone.0004515.g003&representation=PNG_L [Broken]. While the control group showed a weight change of -0.9 kg, the 4 kcal/kg/week exercise group showed a weight change of -1.4 kg, the 8 kcal/kg/week exercise group showed a weight change of -2.1 kg, and the 12 kcal/kg/week exercise group showed a weight change of -1.5 kcal/kg/week. All three experimental groups showed more weight loss than the control group. The authors are merely saying that as exercise dose increases, you get decreasing returns on weight loss (due to the compensatory increases in appetite that you discussed earlier). However, this compensation does not lead to any of the exercise groups to show less weight loss than the control group.
  • #62
Ok, read this news article yesterday.
http://www.dailymail.co.uk/health/a...-diet-make-live-longer.html?ito=feeds-newsxml
Can cutting carbohydrates from your diet make you live longer?
Professor Cynthia Kenyon, whom many experts believe should win the Nobel Prize for her research into ageing, has discovered that the carbohydrates we eat — from bananas and potatoes to bread, pasta, biscuits and cakes — directly affect two key genes that govern youthfulness and longevity.
Scientists already knew how to make laboratory animals live longer and healthier lives — you just cut back their calories to about three-quarters of their normal amount.
It’s not a practical solution for humans, because you feel cold and hungry all the time.
But what Professor Kenyon found out was why *drastically reducing calories has such a remarkable effect.
She discovered that it changed the way two crucial genes behaved. It turned down the gene that controls insulin, which in turn switched on another gene, which in turn switched on another gene, which acted like an elixir of life.
We jokingly called the first gene the Grim Reaper because when it’s switched on, the lifespan is fairly short,’ she explains.
Discovering the Grim Reaper gene has prompted the professor to *dramatically alter her own diet, *cutting right back on carbohydrates. That’s because carbs make your body produce more insulin (to mop up the extra blood sugar carbs *produce); and more insulin means a more active Grim Reaper.
One clue came from a small remote community of dwarves living in northern Ecuador who are cancer-free. They are missing the part of the Grim Reaper gene that controls a hormone called insulin-like growth factor. The downside is they only grow to 4ft tall because the hormone is needed for growth.
But this missing bit of the Grim Reaper gene also means they don’t develop cancer and are less likely to suffer from heart disease or obesity.
Professor Jeff Holly, who specialises in insulin-like growth factor, confirms that it is linked to cancer of the prostate, breast and colon.
In fact raised insulin levels, triggered by high carbohydrate *consumption, could be what *connects many of our big killers.
One way to reduce insulin levels is to exercise, which makes you more sensitive to it, which in turn means you need less of it. It also gives another health benefit in a surprising way. Exercise actually increases the level of damaging free radicals which stimulates the body to produce more protective anti-oxidants.
So should we all be trying to cut back on carbs to reduce our insulin levels?
It is a suggestion that flies in the face of 30 years of health advice to have a lower fat intake and eat plenty of long-lasting complex carbo*hydrates to keep the body supplied with energy.
  • #63
Hmm. Exercise definitely has other benefits and I have admitted that. It improves your insulin resistance, among other things, which could definitely help you reduce weight.
What I don't believe, and what I don't think there is evidence for is the simplistic calories in calories out interpretation of saying that the more you exercise, the more calories out and therefore you will lose weight. Thats nonsense. Because the body will compensate by making you hungrier. We have evolved a very complicated system over millions of years to preserve homeostasis.
Here's the chart
There is a marginal reduction, I agree. But its marginal.
And the more the intensity increases the lesser it is. Which kind of negates the simplistic calories in calories out theory.
Plus how are you controlling for the other improvements due to exercise, like insulin resistance ?
Have you read this article from Gary Taubes ? You don't seem the kind of person who dismisses folks without reading the evidence, so please do read it.
http://nymag.com/news/sports/38001/
There is other evidence too, let me try and dig it out. Wish I had more time.
  • #64
Great. So you do realize the truth in that.
Here are my posts. They present what I said and some of the studies. Please read them.
https://www.physicsforums.com/showpost.php?p=2948044&postcount=17
https://www.physicsforums.com/showpost.php?p=2941054&postcount=2
https://www.physicsforums.com/showpost.php?p=2943978&postcount=13
  • #65
It is certainly true that strong homeostatic mechanisms regulate weight gain in humans. Perhaps strengthening this homeostasis through exercise provides much of its protection against weight gain. However, it is also true that this homeostatic system evolved under conditions where humans were much more physically active than modern humans. All homeostatic systems have limits and it is plausible that at very low levels of physical activity the homeostatic system does not work so well. If this is the case, increases in physical activity from very low levels to moderate levels could have some positive effect. But, this is speculation.
Although the World Cancer Research Fund study shows that physical activity is protective against weight gain, it does not delve deeply into the mechanisms behind the protective effect. They do cite some evidence suggesting that the increased insulin sensitivity from regular physical activity may play a role. So, you certainly could be right that the positive effects of exercise on weight maintenance are not primarily due to the increased energy expenditure due to physical activity. Certainly the Church study shows that compensatory effects do exist. Whether the simple calorie in/calorie out explanation or some other explanation mediates the protective effect of exercise is an a question that probably requires further study.
I agree with the general point of the article: exercise alone will not help one lose weight. Controlling one's diet is another important factor and can often be more important than exercising. If the sole goal is weight loss, exercise may not be the most important factor (although I haven't seen any good evidence yet showing that it hurts weight loss as suggested by the article). Consistent with this view, the WCRF report cites many randomized controlled trials that show that a combination of physical activity and dietary interventions are effective at promoting weight loss.
Finally, the fact remains that strong scientific evidence demonstrates that exercise helps to maintain body weight and protects against weight gain as well as other diseases like diabetes, cancer, and heart disease. Even though regular physical activity may not promote weight loss as well as people think, there are still many good reasons to exercise regularly. Exercise may not necessarily make one thinner, but it will certainly make one healthier.
  • #66
Very well written, Ygggdrasil.
While you and I may differ on some points, overall I think I agree with what you say.
  • #67
i certainly have doubts about much of it. we're certainly not worms or lab rats. very little of the stuff that works in rats re obesity pans out in humans, fwiw.
some things are fairly obvious. kids are eating a bit too much and not exercising as much now. this tends to accelerate some things physiologically, like puberty. it will be interesting to see how that pans out (after I'm dead and gone, most likely), but I'm guessing it shortens their lifespan. being obese is bad, there's not much controversy there.
the other side of the coin is to presumably increase lifespan by decreasing caloric intake, perhaps even below what used to be considered normal. you probably don't want to do this in children and adolescents, especially females. one obvious problem is that most women are prone to osteoporosis in old age, and by age 30, they've got all the calcium they will ever have in their bones. from there it is all downhill. both diet and exercise are important here, as exercise will provide hormonal stimulus to build stronger bones.
later in life, you run into other things. elderly people actually have a better life expectancy if there is a little bit of chub on them. and as always, being too obese will never help, but that typical J-shaped curve(if you're underweight, mortality goes up, overweight and mortality goes up) for longevity shifts to the right a bit.
in general, it seems that optimum BMI is neither too high, nor too low, and optimum may vary by life stage.
and there are other things. for one, we humans don't seem well-designed for conserving calories. we seem designed for keeping our big brains alive, generating copious amounts of heat. we also seem well-designed for traversing long distances on foot, wearing down lesser animals with not speed, but sheer persistance. both of these functions demand copious and efficient fat storage. and come with the expectation that there will be intermittent periods of starvation.
another idea i'd like to throw out there (and i think this is a fairly new topic of research, so there isn't a mountain of data yet) is the http://www.ncbi.nlm.nih.gov/pubmed/15836464" [Broken].
  • #68
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2491496/?tool=pubmed
I love this mouse! I read about it a few years back - but he shows some definite and drastic changes in phenotype in response to a single gene overexpression in a place where it usually ain't! Put a liver enzyme in skeletal muscle - change how the muscle is fuelled - and watch him go! It's pretty amazing.
As usual - its a mouse - so I aint saying anything about the human condition - but its very interesting nevertheless.
  • #69
There is an obvious question that arises after reading this article.
Your body needs energy. This energy can come from carbs, fat or protein. Regardless of the source, the only way the energy can get to your internal organs is via blood glucose. Insulin is released by the pancreas in response to blood glucose. Even if your diet is 100% fat, that fat is converted into glucose via ketogenesis/gluconeogenesis before the energy can be used.
What reason is there to think that consuming 2000 calories/day of "slow release" complex carbs will result in significantly different levels of insulin from consuming the same 2000 calories/day of fat and protein?
  • #70
I am no biochemistry expert (Dr. Stephan Guyenet is, BTW) but here's what it says from everyone's favourite source - wiki -
Most advocates of low-carbohydrate diets, such as the Atkins Diet, argue that the human body is adapted to function primarily in ketosis.[62][63] They argue that high insulin levels can cause many health problems, most significantly fat storage and weight gain. They argue that the purported dangers of ketosis are unsubstantiated (some of the arguments against ketosis result from confusion between ketosis and ketoacidosis which is a related and very dangerous condition).[64] They also argue that fat in the diet only contributes to heart disease in the presence of high insulin levels and that if the diet is instead adjusted to induce ketosis, fat and cholesterol in the diet are not a major concern (although most do not advocate unrestricted fat intake and do advocate avoiding trans fat).
On a high-carbohydrate diet, glucose is used by cells in the body for the energy needed for their basic functions, and about 2/3 of body cells require insulin in order to use glucose. Excessive amounts of blood glucose are thought to be a primary cause of the complications of diabetes; when glucose reacts with body proteins (resulting in glycosolated proteins) and change their behavior. Perhaps for this reason, the amount of glucose tightly maintained in the blood is quite low. Unless a meal is very low in starches and sugars, blood glucose will rise for a period of an hour or two after a meal. When this occurs, beta cells in the pancreas release insulin to cause uptake of glucose into cells. In liver and muscle cells, more glucose is taken in than is needed and stored as glycogen (once called 'animal starch').[65] Diets with a high starch/sugar content, therefore, cause release of more insulin and so more cell absorption. In diabetics, glucose levels vary in time with meals and vary a little more as a result of high carbohydrate content meals. In non-diabetics, blood sugar levels are restored to normal levels within an hour or two, regardless of the content of a meal.
It is worth noting that while there are Essential Fatty Acids(EFA) and Essential Amino Acids(EAA) there are no essential carbohydrates of any sort and while a diet devoid of EFA or EAA will result in eventual death, a diet completely without carbohydrates can be maintained indefinitely without health detriment.
I guess no other reason than the fact that it does. Have you measured your insulin and blood glucose levels after a mostly fatty meal ? People have. My mom has (she is a diabetic). If you add carbs, the difference is marked.
<h2>1. What is the link between sugar and refined carbs and cancer?</h2><p>There is evidence that a diet high in sugar and refined carbohydrates can contribute to the development of cancer. These foods can cause inflammation in the body, which has been linked to cancer growth. Additionally, sugar and refined carbs can lead to obesity, which is a risk factor for many types of cancer.</p><h2>2. How much sugar and refined carbs should I consume to reduce my risk of cancer?</h2><p>The American Heart Association recommends limiting added sugars to no more than 6 teaspoons (25 grams) per day for women and 9 teaspoons (36 grams) per day for men. As for refined carbs, it is best to limit these as well and focus on consuming whole, unprocessed foods such as fruits, vegetables, and whole grains.</p><h2>3. Can cutting out sugar and refined carbs prevent cancer?</h2><p>While there is no guarantee that cutting out sugar and refined carbs will prevent cancer, it can certainly reduce your risk. Eating a healthy, balanced diet that is low in added sugars and refined carbs can help maintain a healthy weight, reduce inflammation, and provide important nutrients for overall health.</p><h2>4. Are there any types of sugar or refined carbs that are worse for cancer risk?</h2><p>High-fructose corn syrup and other added sugars found in processed foods are particularly concerning for cancer risk. These sugars are quickly absorbed into the bloodstream, causing a spike in insulin and inflammation. Refined carbs, such as white bread and white rice, also have a similar effect on the body.</p><h2>5. Is there a safe amount of sugar and refined carbs for cancer patients?</h2><p>It is best for cancer patients to consult with their healthcare team for personalized recommendations. In general, it is important for cancer patients to maintain a healthy weight and consume a balanced diet that provides necessary nutrients for recovery. This may include limiting added sugars and refined carbs, but it is important to also consider individual needs and preferences.</p>
  • Biology and Medical
  • Set Theory, Logic, Probability, Statistics
  • Quantum Interpretations and Foundations
  • Feedback and Announcements
