Difference between two images
  1. Jan 2, 2010 #1
    Hi all,
    I have two images, without any exact spatial correspondence
    I want to find if the difference between two regions is statistically significant
    How would I do this?
  3. Jan 2, 2010 #2
    EnumaElish
    What do you mean by "exact spatial correspondence"?
  4. Jan 2, 2010 #3
    Hi EnumaElish,
    The images are of the human brain
    They would be very similar except one is (slightly) distorted
    Otherwise they would be the same
    Hence no exact spatial correspondence
  5. Jan 3, 2010 #4
    Anyone?
    To clarify my question... I would be selecting regions which look as though they belong to the same anatomy
    Then I need to tell if intensities in the two regions are significantly different
    If it matters, I can select regions which contain the same no. of voxels
    Please let me know if I'm not making sense, statistics in general confuse me :-/
  6. Jan 3, 2010 #5
    EnumaElish
    Okay, this makes it a lot easier. On each image you could set up an N-by-M grid, indexed by i = 1, ..., NM. For example, each i could be a pixel (I don't know what a voxel is). Then you could define a distance function d between pixel i of the first image and pixel i of the second image; e.g. d = 1 if both pixels are the same color (or intensity), d = 0 otherwise. This would give you a string of NM numbers (ones and zeros). This would be your data, and you could test whether the mean distance is statistically different from zero using a t test.
    Or you can define a more complicated distance function, e.g., di = |y(1i) - y(2i)|, where y is a measure of intensity (you need to define this), 1i is the i'th cell in the first image, 2i is the i'th cell of the second image, and di is the distance between cells 1i and 2i. Again, this will give you a string of NM numbers (di's), and you can test whether the mean distance is statistically different from zero using a t test.
    A characteristic of statistical tests, such as the t test, is that you can almost always find a statistically significant difference by increasing the sample sizes arbitrarily. So, even with N = M = 10 you do not find a statistically significant difference, with N = M = 10,000 you are much more likely to find a statistically significant difference. This is less of a problem if you are looking for a uniform rule to compare several pairs of images and to make relativistic statements such as "A is different from B more than A is different from C" but it's more problematic if you are looking for "the" statistical difference between two "canonical" images. In the latter case, you need to make a judgment call and come up with a "justifiable" grid size (based on the expertise in your field). Knowing next to nothing about what you are trying to accomplish with these images and the difference between them, one idea may be to zoom in on the region of interest (e.g., "the frontal lobe") and discard the rest of the images; that way your grid will not be "too general."
  7. Jan 3, 2010 #6
    EnumaElish,
    Whoah... thanks for that reply. Great read and very insightful :)
    However I now have several new questions:
    1. You mention two distance metrics, the first one di = 1 if two intensities at a pixel are equal, di = 0 otherwise and the second di = |y(1i) - y(2i)| where y is "some measure of intensity." What about the Euclidean distance (i.e. square root of sum of intensity sq.)? How do I tell which metric is most appropriate?
    2. Consider if I have two copies of the same image, call it image A. Now I distort A by exchanging pairs of intensities at random, creating image B. Image A and B will have the same histogram, but will look quite different. Will a comparison between A and B find a statistically significant difference?
    3. If I select two regions for comparison, according to your post they should have the same number of pixels and also the same dimensions. I assume this is a requirement of the t-test. Are there any statistical tests which do not have these requirements?
    BTW a voxel is just a discrete volume element, in the same way a pixel is a discrete surface element
  8. Jan 5, 2010 #7
    EnumaElish
    1. Euclidean distance is nonlinear, and can be costly to implement for that reason. However, see this article.
    2. This reminds me that you can use the Chi-squared test to test the difference between histograms -- again, not knowing the purpose of your testing, this is just another way to approach the problem. But if you were using any of the distance metrics noted above (discrete, absolute difference, or Euclidean) then almost surely you will find an arithmetic difference between the two means; and you can use a t-test to determine its statistical significance.
    3. Yes; I suggest a regression approach. Let y be a vector of intensity measurements from either of the two images (say, K1 measurements from the first image and K2 measurements from the second image). Define x such that x(k) = 0 if y(k) belongs to the first image, and x(k) = 1 if y(k) belongs to the second image, for k = 1, ..., K1+K2. You can estimate the regression y = a + b x + u, using least squares. Coefficient b equals "mean y from the second image minus mean y of the first image." If b is statistically significant, then the difference between the two means is statistically significant. [Note that the distance function approach depends on a geometrical correspondence between the two images that the regression approach ignores -- to follow the permutation example in your post, in a case where the distance approach produces an arithmetic difference between the original and the permuted images, the regression approach will not.]
  9. Jan 6, 2010 #8
    Really? This might be exactly what I need
    OK you lost me here. What is the vector u? Is it something I know is it part of the regressing?
    "If b is statistically significant"
    You mean sign. different from 0?
    I have never ever come across these methods, so I'm probably missing something...
    BTW thanks for the advice !!! =]
  10. Jan 6, 2010 #9
    EnumaElish
    See http://www.physics.csbsju.edu/stats/chi-square.html, http://www.itl.nist.gov/div898/handbook/eda/section3/eda35f.htm and http://en.wikipedia.org/wiki/Pearson's_chi-square_test
    Sorry, you only provide the y's and the x's, u is the random error term (a.k.a. the residual), or y - a - b x. For instance, if y (intensity measurements) contain a random measurement error ("noise") then u captures this "noise." More generally, any variation among the y's other than the variation that can be explained by the right-hand side variable(s) becomes residual variation. Standard statistical packages (including Excel) estimate and can print out the u terms in addition to the coefficients a and b, their statistical significance, and an array of additional statistics.
    Yes, that's what I meant -- that's the standard usage in regression analysis lingo.
    See http://onlinestatbook.com/ (At the top click on Contents, then "Introduction to Simple Linear Regression" under "XII. Prediction" -- notice Prerequisites listed at the top of the page.)
    Also see:
    http://en.wikipedia.org/wiki/Regression_analysis
    http://www.law.uchicago.edu/files/files/20.Sykes_.Regression.pdf [Broken]
    http://www.nlreg.com/intro.htm
    http://www.statsoft.com/textbook/multiple-regression/
  11. Jan 7, 2010 #10
    EnumaElish
    Above, I wrote:
    I did not mean to imply that the distance approach will always produce a nonzero mean difference -- in fact, if the permutation is random then the expected (true mean) difference is zero, as the following example illustrates:
    y , RandomRank , y* , d
    0.019433061 , 7 , 0.290617864 , -0.271184804
    0.114136996 , 14 , 0.264838615 , -0.150701619
    0.136433932 , 8 , 0.333835024 , -0.197401092
    0.138333371 , 4 , 0.138333371 , 0
    0.19700036 , 13 , 0.312202404 , -0.115202044
    0.264838615 , 2 , 0.705108738 , -0.440270123
    0.290617864 , 1 , 0.019433061 , 0.271184804
    0.312202404 , 5 , 0.136433932 , 0.175768472
    0.317085208 , 16 , 0.99010499 , -0.673019782
    0.333835024 , 3 , 0.662772917 , -0.328937893
    0.567207525 , 20 , 0.974873342 , -0.407665817
    0.650723461 , 17 , 0.834248815 , -0.183525355
    0.662772917 , 10 , 0.19700036 , 0.465772557
    0.679963742 , 15 , 0.114136996 , 0.565826746
    0.705108738 , 6 , 0.679963742 , 0.025144996
    0.834248815 , 12 , 0.317085208 , 0.517163608
    0.850628183 , 19 , 0.650723461 , 0.199904722
    0.960884675 , 18 , 0.960884675 , 0
    0.974873342 , 11 , 0.850628183 , 0.124245159
    0.99010499 , 9 , 0.567207525 , 0.422897465
    Above, y is the original measurement, y* is the re-ordered measurement (y values re-ordered according to a random rank assigned to the original value), and d = y - y*. It can be verified that d averages out to nearly zero.
  12. Jan 7, 2010 #11
    Gotcha. All I wanted to say here was that there was no geometrical correspondence, as you put it, between the two images. As far as I understand (which isn't very far), the t-test assumes this kind of relationship.
    I will try out both the Chi-squared and regression approach and post my results.
  13. Jan 10, 2010 #12
    As per Enuma's initial suggestion, and after some sanity checking, I decided to go with a vanilla t-test using absolute difference between the two images d=|y(1i)-y(2i)| as my distance measure...
    In Matlab its implemented as ttest2(A,B,pvalue)
