Difference between vibrational, rotational and electron temperature
In summary, spectroscopic studies have shown that the temperature inside the collapsing bubble is not a single value, but rather there is a multi-temperature environment governed by particle energies.
rwooduk
762
59
I am trying to explain the following statement in my own words...
The observation of OH (C2 R+ –A2 R+ ) emission band and a spectroscopic analysis of OH(A2 R+ –X2 Pi) emission band in MBSL of water pre-equilibrated with noble gases revealed the formation of a nonequilibrium plasma inside the collapsing bubble (Te > Tv > Tr, where Te is an electron temperature, Tv is a vibrational temperature and Tr is a rotational (gas) temperature). The Te and Tv estimated using OH(A2 R+ –X2 Pi) emission band increase with ultrasonic frequency.
Would it be correct to say that..
me said:
However more recent spectroscopic studies have shown a more complex situation with non-equilibrium plasma formation in the form of excited OH radicals in different vibrational or energy states [77]. This would indicate that, rather than considering the temperature inside the bubble to be single value, there is in fact a multi-temperature environment governed by particle energies.
I am unsure if a vibrational state is simply a different energy state or something more specific?
Do the electron temperature, vibrational temperature and rotational temperature all contribute to the overall energy state? And when it says temperature, does it mean state?
What does "Te > Tv > Tr" tell us in regards to the properties of the plasma?
Thanks for any help interpreting this!
Last thing...
From the physical point of view, this finding means that the processes inside the bubble should be described by multiple temperatures related to different plasma particles and different degrees of freedom.
How does degrees of freedom relate to the above?
Paper:
http://www.sciencedirect.com/science/article/pii/S1350417716300438
I don't know about "correct"; it would certainly be much less informative. The original is specific, yours is vague. I would say "in different energy states" rather than "vibrational or energy states", which is meaningless - vibration is not an alternative to energy. A "vibrational state" is not simply a different energy state; it is specifically a state of vibration, defined by the vibrational quantum numbers of all the vibrational modes of the molecule (only one for a diatomic like OH). Similarly a rotational state is defined by the rotational quantum numbers.
The electronic, vibrational and rotational energy contribute to the overall energy of a molecule. Temperature is a property of an ensemble of molecules, and is related to the average energy of a molecule. Do not confuse energy with temperature - they are not the same thing.
A "multi-temperature environment governed by particle energies" is tautologous; temperature is always governed by particle energies. The point is that there is a different distribution of energy in the different kinds of energy levels - rotational, vibrational and electronic. At thermal equilibrium the distribution of molecules between energy levels is given by the Boltzmann distribution, and if you can measure this distribution you can say what the temperature is. In a non-equilibrium situation, the "temperature" you would deduce from the observed distribution of the rotational energy levels (the "rotational temperature") may be different from the "temperature" you deduce from the observed distribution of the vibrational levels (the "vibrational temperature"), and the electronic temperature may be different again.
I'm no expert on plasma chemistry, but in broad terms I would interpret "Te > Tv > Tr" as indicating that in the violent environment of the collapsing bubble, water molecules are torn apart to give OH radicals in excited electronic and vibrational states; in the short lifetime of the bubble these do not have time to equilibrate by collision, so the distribution of electronic states is one that would normally be characteristic of a very high (equilibrium) temperature; the distribution of the vibrational states would be characteristic of a lower temperature, and rotational lower again.
I assume "different degrees of freedom" means rotational, vibrational or electronic energy, and the point is that you get a different T value depending on which one you look at to determine the "temperature".
Likes mic* and rwooduk
Wow, a belated thanks! Thank-you for the interpretation!
What is the difference between vibrational, rotational, and electron temperature?
Vibrational, rotational, and electron temperature are all measures of the energy levels of particles in a system. However, they differ in terms of the types of particles they measure and the physical processes that contribute to their temperature.
How is vibrational temperature measured?
Vibrational temperature is a measure of the average kinetic energy of the vibrational motion of molecules in a system. It is typically measured using spectroscopic techniques that analyze the wavelengths of light emitted or absorbed by the molecules.
What factors affect rotational temperature?
Rotational temperature is a measure of the average kinetic energy of the rotational motion of molecules in a system. It is affected by factors such as the molecular structure, temperature, and pressure of the system.
How does electron temperature differ from vibrational and rotational temperature?
Electron temperature is a measure of the average kinetic energy of electrons in a system. Unlike vibrational and rotational temperature, which are primarily affected by molecular motion, electron temperature is more influenced by the behavior of free electrons in the system.
Why is it important to understand the differences between these temperatures?
Understanding the differences between vibrational, rotational, and electron temperature is crucial in many scientific fields, such as chemistry and astrophysics. It allows us to better understand the behavior of particles in different systems and their role in various physical processes.
  • Atomic and Condensed Matter
