Homework Help: Difference equation solution
  1. May 3, 2015 #1
    Given the following difference equation;
    x(k+2)-x(k+1)+0.25x(k)=u(k+2)
    where
    x(0)=1; x(1)=2; u(k)= 1 for k=1,2,3,…
    2. Relevant equations
    Z- transformation
    3. The attempt at a solution
    To be able to solve this difference equation, I think I need to transform it into z domain then after some manipulations I need to convert it back to discrete time signal.
    Here's my attemp
    z2 X(z) - z2 X(0) - zX(1) - [zX(z) - zX(0) ] + 0.25X(z) = z2 [z/(z-1)]
    u(k+2) is the step input. Transformation of step is z/(z-1). However, I'm not sure about the transformation of u(k+2)
    Even if it is z2 [z/(z-1)], I couldn't proceed further with the equation I obtained.
    I would appreciate any help
  3. May 3, 2015 #2
    vela
    Staff Emeritus
    Education Advisor
    Isn't u(k)=1 for k=0 too?
    Try applying the definition of the z-transform to u(k+2).
  4. May 3, 2015 #3
    Yes, it is. My mistake sorry.
    I think it should be z2 [z/(z-1)] but I'm not sure
  5. May 3, 2015 #4
    vela
    Staff Emeritus
    Education Advisor
    That's why I'm suggesting you apply the definition of the z-transform and derive the result.
  6. May 3, 2015 #5
    If u is equal to 1 for every k values, it is a step function and then z/(z-1) should be the z-transform. Am I correct ?
  7. May 3, 2015 #6
    vela
    Staff Emeritus
    Education Advisor
    By "u", do you mean u(k) or u(k+2)?
  8. May 3, 2015 #7
    Actually that's the point confusing me. u(k+2) is there in the equation. However, When I start plugging values for k, starting from 0, I will always get 1. So, I would treat u(k+2) as step function and take its inverse z transform as z/(z-1)
  9. May 3, 2015 #8
    vela
    Staff Emeritus
    Education Advisor
    That's right. You have
    $$\sum_{k=0}^\infty u(k+2)z^{-k} = \sum_{k=0}^\infty z^{-k}.$$ Because you're using the unilateral z-transform, the shift ends up having no effect on the righthand side.
  10. May 7, 2015 #9
    rude man
    You may or may not be aware that there is also a "classical" way to solve finite-difference equations, analogous to the classical (non-transform) way to solve ODE's.
    However, I would stick with the z transform.
Have something to add?
Draft saved Draft deleted
Loading...
