1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Different diameter solenoid
  1. Jan 6, 2013 #1
    We're given two solenoids with identical currents and turns per unit length. But the solenoids have different diameters. Would a metal BB experience a larger acceleration in the smaller diameter tube, assuming we use the same BB in both solenoids it accelerates along the z-axis, which goes through the center of the solenoid?
    2. Relevant equations
    Magnetic field through a solenoid:
    [itex] B = \mu_0NI [/itex]
    Where N is number of turns per unit length and I is the current.
    Biot-Savart Law:
    [tex]B = \frac{1}{4\pi}\frac{I\Delta \vec{s} \times \vec{r}}{r^2}[/tex]
    3. The attempt at a solution
    My thought is that since the BB experiences the same uniform magnetic field in both solenoids, the acceleration is the same. The equation for the magnetic field through a solenoid does not include diameter, I notice. But I was having a little debate on this subject and my friend says he would expect the field to sort of dissipate as the diameter increases. This would make total sense if it were a point charge; you'd use Biot-Savart's law. Who is right?
  3. Jan 6, 2013 #2
    hi joe_cool2! :smile:
    (what's a BB ? :confused:)
    you are correct …
    if the solenoid is infinitely long, the magnetic field is uniform
    if the solenoid is ordinary long (ie, a lot longer than wide), the magnetic field is nearly uniform, and you can assume this to be so in exam questions! :wink:
    from hyperphysics
    "The magnetic field is concentrated into a nearly uniform field in the centre of a long solenoid"​
  4. Jan 6, 2013 #3
    2017 Award
    See here for description of BBs. They are often made of steel with a copper or zinc coating, lead, or plastic. I don't see how a BB in a B field (pun intended, sorry) would experience any noticeable acceleration.
