Differential equation BVP
  1. Feb 25, 2009 #1
    Using the given differential eq. M'' + bM=0 where b is a real-valued parameter, find all nonzero values for b that adhere to the following boundary conditions:
    M'(0)=0
    M'(Pi)=0
    2. Relevant equations
    When I apply the boundary conditions, after I set up the equation for f(x) using the gen. sol for the characteristic equation M^2+bM=0, do I need to figure out when f(x) has nonzero solutions or when f ' (x) has nonzero solutions?
    3. The attempt at a solution
    ex: when b < 0 taking b= -a where a>0 we get the gen. sol:
    f(x)=c_1exp(ax) + c_2exp(-ax).
    applying the bound. conds we find that c_1= c_2 from f '(0)=0 and using f '(Pi)=0 we find that 0=c_1a [exp(aPi)-exp(-aPi)]. If c_1 and c_2 are not equal to 0 we see the exponential part can never be zero, implying c_1 and c_2 are equal to 0.
    Does this mean there are no nonzero sols for f '(x) which is what we want? and or does this say there are no non-zero sols. for f(x) if that is what we want?
    I see I need 2 other cases for the value of b. I am just wondering if I am on the right track.
    Thanks.
  3. Feb 26, 2009 #2
    HallsofIvy
    Acutually, when b< 0, you want to take b= -a2 to get eax and e-ax as solutions. However, it is still true that for b< 0, this problem has only the "trivial" solution, M(x)= 0.
    If b= 0, then M"= 0 and you can get the general solution just by integrating twice.
    If b> 0, then let b= a2 and two independent solutions are cos(ax) and sin(ax).
  4. Feb 26, 2009 #3
    I meant take b= -a^2 for b<0 like you said. I have that part.
    For b=0 solving I get M(x)= c_1 + c_2 x. I got M'(x)=c_2. When applying the boundary conditions M'(0)=0 I found that c_2= 0. M'(Pi)=0 gives me the same info that c_2=0. Does this mean a nonzero solution is M(x)=c_1 when c_1 >0???
    Also, for b>0 I found that M(x)=c_1 cos(ax)+c_2 sin(ax). applying the boundary conditions M'(x)=0 I got 0=c_2 a. Since a>0 by assumption, c_2=0. For M'(Pi)=0 I got 0= -c_1asin(aPi). taking c_1 not equal to 0 and a>0 (assumed) sin(aPi)=0 when a=n n=1,2,3...
    Does this mean the nonzero solutions are M_n(x)=sin(a_nx)=sin(nx)???
    Thanks.
