Modeling Bacterial Growth with Differential Equations
In summary, the differential equation describes the growth of bacteria in a culture where the number of bacteria doubles every hour. At the beginning of the experiment there were 1000 bacteria, and after 3 hours there were 2500 bacteria. The equation suggests that the bacteria will reach its maximum population at 3 hours and then slowly decline.
thereddevils
438
A cultured bacteria of a species multiplied at a rate that is directly proportional to the number of cultured bacteria in the culture. If x is the number of bacteria in the culture in time t seconds write down the differential equation that describes the growth of the bacteria. At the beginning of the experiment, there were 1000 bacteria of a certain species. It was known that the cultured bacteria multiply at a rate of 1.5 times per hour. Find the number of bacteria in the culture after 3 hours.
The differential equation is dx/dt=kx with solution x=1000e^(kt)
It was known that the cultured bacteria multiply at a rate of 1.5 times per hour. What did this line imply?
since in one hour it multiplied 1.5 times, then in 3 hours would be 4.5 times. Simply take 1000 multiplied by 4.5 to get the answer?
After 1 hour the bacteria has multiplied by 1.5 times. You need to use this information to find the constant of exponentiation k.
Definitely not. This is not a linear problem.
In the second hour, we already have 1.5x the original bacteria population and now we're going to take 1.5x that population, not the original.
ok thanks,
dx/dt=1.5=kx
k=1.5/x
x=1000e^(1.5t/x)
Then when t=3, x=1000e^(4.5/x)
so i solve for x here?
You have [tex]x=1000e^{kt}[/tex]
And we are given that at time t=0 there are 1000 bacteria, so x=1000 at t=0, which is true by the formula given. We are also given that at time t=1 (we are assuming t is in hours here to make things simple) that the bacteria is 1.5 times the original number, so x=1500 at t=1. Here if we plug this into the equation we can solve for k to find its value. Now we use this value of k to find the value of x at t=3.
Erm that got me confused a little again, if we can do like that why can't the problem be treated like a geometric progression?
1000 , 1000(1.5) , 1000(1.5)^2 ,... ??
It can, but it would be hard to figure out what happens in fractions of an hour that way.
true , thanks for your guidance.
No worries :smile:
Just as a note that has helped me in the past for these kinds of problems. Remember to use all the info given. It's usually needed to find some unknown constants which otherwise wouldn't give you the answer you're looking for.
This happens a lot in integration too for example when you're trying to find what the constant C must be in a physical question.
Say for this question you didn't use the extra info given, you'll try to find the population at time t=3, which gives [tex]x=1000e^{3k}[/tex] but of course this isn't an answer we're looking for, which means you missed something.
Good luck!
1. What is a differential equation?
A differential equation is a mathematical equation that describes how a variable changes over time. It includes both the variable and its derivative, representing the rate of change of the variable. Differential equations are used to model many natural phenomena, such as the growth of populations, the flow of fluids, and the motion of objects.
2. What is the difference between an ordinary and a partial differential equation?
An ordinary differential equation (ODE) involves only one independent variable, while a partial differential equation (PDE) involves multiple independent variables. ODEs are used to describe systems that change over time, while PDEs are used to describe systems that change over both space and time.
3. What is the order of a differential equation?
The order of a differential equation is the highest derivative present in the equation. For example, a first-order differential equation contains only first derivatives, while a second-order differential equation contains second derivatives.
4. What are some applications of differential equations?
Differential equations are used in a variety of fields, including physics, engineering, economics, and biology. They are used to model and understand the behavior of complex systems, such as the weather, population growth, and electrical circuits.
5. How do you solve a differential equation?
The method for solving a differential equation depends on its type and complexity. Some common techniques include separation of variables, substitution, and using specific formulas for certain types of equations. In some cases, numerical methods or computer software may be used to approximate a solution.
