Differential equation problem
  • Thread starter fayled
I'm solving a differential equation to do with quadratic resistance and it seems to be acting very strangely - I get the opposite sign of answer than I should. If anybody could have a quick look through that would be much appreciated.
For a particle moving downward and taking positive upwards, I have
mdv/dt=-mg+bv2
The terminal velocity comes out at vl=-√(mg/b) (negative as it obviously has its terminal velocity downwards).
Substituting this in gives
dv/dt=-g(1-(v/vl)2)
Now make the substitution z=v/vl so dv/dt=vldz/dt. Then we obtain
vldz/dt=-g(1-z2)
Noting that 1/1-z2=0.5[(1/1+z)+(1/1-z)] and separating variables we get
∫[(1/1+z)+(1/1-z)]dz=-2g/vl∫dt
Integrating each side then gives (the initial conditions are v=0 at t=0 so the constant of integration is zero)
ln(1+z/1-z)=-2gt/vl.
Next let k=vl/2g so that
ln(1+z/1-z)=-t/k
e-t/k=1+z/1-z
e-t/k-ze-t/k=1+z
z(1+e-t/k)=e-t/k-1
z=(e-t/k-1)/(e-t/k+1)
Therefore
v=vl[(e-t/k-1)/(e-t/k+1)]
Now, the correct answer should be
v=vl[(1-e-t/k)/(1+e-t/k)]
i.e
v=-vl[(e-t/k-1)/(e-t/k+1)]
which must be right because as t→∞, v→vl which by the definition of vl is expected.
I've spent a lot of time trying to work out where I'm going wrong and it's driving me crazy. Thanks in advance :)
Answers and Replies
pasmith
2,113
738
mdv/dt=-mg+bv2
dv/dt=-g(1-(v/vl)2)
Probably better to define [itex]v_0 = (mg/b)^{1/2} > 0[/itex] so that terminal velocity is [itex]-v_0[/itex] and [itex]v[/itex] and [itex]z[/itex] increase in the same direction.
Then we obtain
vldz/dt=-g(1-z2)
ln(1+z/1-z)=-t/k
e-t/k=1+z/1-z
e-t/k-ze-t/k=1+z
z(1+e-t/k)=e-t/k-1
Therefore
I believe this is correct.
ie.
I think you have confused yourself. You've defined [itex]k = v_l/2g[/itex] and you initially defined [itex]v_l[/itex] to be negative, so [itex]k[/itex] is negative. It follows that [itex]-1/k[/itex] is positive, so that [itex]e^{-t/k} \to \infty[/itex] as [itex]t \to \infty[/itex]. Thus your answer
[tex]
v=v_l \frac{e^{-t/k}-1}{e^{-t/k}+1} \to v_l < 0
[/tex]
as required.
On the other hand, if you define [itex]v_l[/itex] to be positive then [itex]-1/k[/itex] is negative, so that your answer tends to [itex]-v_l < 0[/itex] as required.
Not quite. If you're defining [itex]v_l = (mg/b)^{1/2} > 0[/itex] then you should find that [itex]v \to -v_l[/itex]. You're measuring displacement upwards but the object is moving downwards so [itex]v < 0[/itex]. That's consistent with the answer you got yourself, and there is as far as I can see no error in your calculation.
But I defined it as vl=-(mg/b)1/2...
pasmith
2,113
738
I only noticed that after replying, since it's extremely unnatural to do that. More normal would be to define [itex]v_l = (mg/b)^{1/2}[/itex].
I have now edited my post accordingly.
Ah right, thankyou very much.
Related Threads on Differential equation problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
