When Will the Curse of the Medicine Man Wipe Out a Tribe?
In summary, the second tribe will all be dead by 101 weeks if the rate of change of the population is -\sqrt{P} per week.
Charge2
This is a interesting (morbid) problem from Simmons- Calculus with Analytic Geometry.
In a certain barbourous land, two neighbouring tribes have hated one another from time immemorial. Being barbourous peoples, their powers of belief are strong, and a solemn curse pronounced by the medicine man of the first tribe deranges and drives them to murder and suicide. If the rate of change of the population P of the second tribe is ##-\sqrt{P}## per week, and if the population is 676 when the curse is uttered, when will they all be dead?
Intial Conditions
##P(0) = 676##
[/B]
None
##\frac{dP}{dt} = -\sqrt{t} = -t^{1/2} ##.
Separating the differential equation,
##dP = -t^{1/2}dt ##,
Then, by intergrating,
##\int dP = - \int t^{1/2}dt ##
##P = -\frac{2}{3} t^{3/2}+ C ##...(1)
Solving for C at t= (0) or P(0) weeks, when the medicine man uttered his curse,
##676 = -\frac{2}{3} (0)^{3/2} + C ##,
##C = 676##.
Subbing this in (1)
##P = -\frac{2}{3} t^{3/2}+ 676 ## ...(2)
Rearanging (2) for t, when P = 0 because the second tribe are all dead,
##0 = -\frac{2}{3} t^{3/2}+ 676##,
##-676 = -\frac{2}{3} t^{3/2}##,
##t = (\frac{2028}{2})^{2/3}= 100.93 = 101## weeks .
Is this correct. Or have I made a massive error? Seems like they need a more powerful medicine man...
Intial Conditions
##P(0) = 676##
[/B]
None
##P = -\frac{2}{3} t^{3/2}d+ C ##...(1)
##C = 676##.
Subbing this in (1)
##0 = -\frac{2}{3} t^{3/2}d+ 676##,
Yes, you have made a massive error.
According to the OP, "the rate of change of the population P of the second tribe is ##-\sqrt{P}## per week", yet you have set your ODE = ##-\sqrt{t}##. Why is that?
Likes Charge2
No, the equation you need is [tex]\frac{dP}{dt}=-\sqrt{P}[/tex]
Likes Charge2
Dang. I had this on my first attempt but it just looked wrong and unfamiliar, so played around with the equation, this was the first attempt,
##\frac{dP}{dt} = -\sqrt{P} = -P^{1/2} ##.
and rearanged it to,
##t = \int \frac{1}{-p^{1/2}}dP = ##.
Is that ok?
Is that ok?
Yep, that's what you should start with.
Likes Charge2
Ok this is not working out,
##t = -2\sqrt{P} + C##
C = 52
##t = -2\sqrt{P} + 52##
##t = 0.##
Charge2 said:
t=−2P√+52
This is the correct solution. Substitute P=0 to find t.
Likes Charge2
52 weeks... not a bad medicine man after all. I on the other hand, need to work more on ode magick.
1. What is a differential equation?
A differential equation is a mathematical equation that relates a function to its derivatives. It is used to describe the relationship between a system's current state and how it changes over time.
2. What is the purpose of solving a differential equation problem?
The purpose of solving a differential equation problem is to find the function that satisfies the given equation and represents the behavior of a system. This allows us to predict future behavior and understand the underlying principles behind a system.
3. What are the different types of differential equations?
The different types of differential equations include ordinary differential equations (ODEs), which involve one independent variable, and partial differential equations (PDEs), which involve multiple independent variables. ODEs can further be classified as linear or nonlinear, and first-order or higher-order.
4. How do you solve a differential equation problem?
The method for solving a differential equation problem depends on the type of equation and its complexity. Some common techniques include separation of variables, substitution, and integration. For more complex problems, numerical methods or computer software may be used.
5. Where are differential equations used in real life?
Differential equations are used in many fields of science and engineering, including physics, chemistry, biology, economics, and engineering. They are used to model and analyze a wide range of phenomena, such as population growth, chemical reactions, and electrical circuits.
