Homework Help: Differential equation
  1. Nov 1, 2012 #1
    fxo
    Use L'Hospitals rule to show that [itex]lim x->0 x^a ln(x) = 0 [/itex]
    I don't know how to solve this. I guess the first thing to do is to transform it in some way so that one can use L'Hospitals rule, but I don't know how.
    Thank you!
    EDIT: a>0
    It's not a differential equation as the headline says, my bad.
  3. Nov 1, 2012 #2
    LCKurtz
    Is there something else you haven't told us? Like ##a>0##? Write it like this:$$
    \lim_{x\rightarrow 0}\frac {\ln x}{\frac 1 {x^a}}$$
  4. Nov 1, 2012 #3
    fxo
    Oh sorry you're right I totally missed that a>0. I get it then.
    Can I ask a follow-up question based on this one?
    By setting x=ln(t) in the equation above(the one I asked for help on first) show that:
    \lim_{x\rightarrow -∞} |x|^a e^x = 0$$
    This one really bugs my mind I just don't get it.
  5. Nov 1, 2012 #4
    LCKurtz
    You should note that in the original limit, it is really ##x\rightarrow 0^+##. What happens if you substitute ##x=\ln t## in the original problem?
  6. Nov 1, 2012 #5
    fxo
    \lim_{ln(t)\rightarrow 0}\frac {\ln (ln(t))}{\frac 1 {ln(t)^a}}$$
    So I get $$
    ln(ln(t))ln^a(t)$$
    But that expression don't tell me much all I know is that it's root should be e.
  7. Nov 1, 2012 #6
    LCKurtz
    Woops, I didn't mean that. I meant to try ##t=\ln x## which is ##x=e^t##. I expect that is a typo in your text.
  8. Nov 1, 2012 #7
    fxo
    ##\lim_{e^t\rightarrow 0}\frac {\ln (e^t}{\frac 1 {e^t^a}}##
    I don't really get it what's the connection to the new limit, do they want me to change the e^x to x=ln(t) and get |x|^a * t instead?
  9. Nov 1, 2012 #8
    LCKurtz
    C'mon, do the algebra simplification. And express it as$$
    \lim_{t\rightarrow\, ?}....$$Then you might see a connection to your new problem.
  10. Nov 2, 2012 #9
    fxo
    By setting ##x=e^t## in the first one I got
    \lim_{t\rightarrow\, 0} te^t^a $$
    I'm starting to see that it's close to the form in b but not exactly, should I use L'Hospitals rule from here to show that as this goes to infinity the limit goes to zero?
  11. Nov 2, 2012 #10
    LCKurtz
    Tex won't accept e^t^a with no parentheses. Anyway, do you consider that to be simplified? It is more properly written ##(e^t)^a##, but still not simplified until you write it as ##e^{at}##. And you have ##t\rightarrow 0##. If ##x=e^t## and ##x\rightarrow 0^+##, does ##t\rightarrow 0##? What should it be?
    That being said, you are correct that you can massage it into ##|x|e^x## form but it still isn't in the ##|x|^ae^x## form requested. So I'm afraid my suggestion to correct what I think is a misprint isn't going to finish it. To tell the truth, I don't see why your author wants you to do it that way anyway. It is easy to work it directly. Letting ##x = -t## we have$$
    \lim_{x\rightarrow {-\infty}}|x|^ae^x=\lim_{t\rightarrow \infty}t^ae^{-t}
    =\lim_{t\rightarrow \infty}\frac{t^a}{e^{t}}$$which you can now do with repeating L'Hospitals rule until the exponent on ##t## goes negative.
