Differential Equations Help
  • Thread starter rpgkevin
Solve The following Equations:
2(y+3)dx-xydy=0
(x2-xy+y2)dx - xydy=0 use following assumption y=vx
xy3+ex2dy=0
I am still a novice at diff eqs but here is what I got on the first one:
After seperating it I ended up with
(dx/x)=(ydy)/(2y+6) Then I get stuck with integrating the side with the Y
For the other two I believe they can not be separated and I am not sure what to do when this is the case
Answers and Replies
rock.freak667
6,230
31
For the right side, you can rewrite it as
y/2(y+3) dy or ½(y+3-3)/(y+3), you can simply it even further i.e. polynomial division
vela
Staff Emeritus
Education Advisor
14,845
1,416
For the y-integral on the first one, you can do this:[tex]\frac{1}{2}\int \frac{y}{y+3}\,dy = \frac{1}{2}\int \frac{(y+3)-3}{y+3}\,dy = \frac{1}{2}\int \left[1-\frac{3}{y+3}\right]\,dy[/tex]or you could use the substitution u=y+3.
On the second one, what did you get when you used the substitution y=vx?
I have never used the substitution method I have no clue how to use that I looked it up earlier because someone told me that but I was unable to use the examples to work that one out
vela
Staff Emeritus
Education Advisor
14,845
1,416
If you differentiate y=vx with respect to x, you'll get
[tex]\frac{dy}{dx} = v + x\frac{dv}{dx}[/tex]
Multiplying through by dx, you end up with
[tex]dy = v \,dx + x\, dv[/tex]
Use this and the original substitution to eliminate y from the original equation. You should find it separates then, allowing you to solve for v, from which you can then find y.
I don't think you wrote this correctly - there seems to be a dx missing.
ahh you are correct it is suppose to be a dx after the xy3
I tried what you said and plugged stuff back in and then I Tried separating things out and I cant seem to get it to separate out I am stuck at
X2(1-V-V2)dx=x2v2+(x3v)dv/dx)
vela
Staff Emeritus
Education Advisor
14,845
1,416
Please show your work. It's impossible to see what went wrong without seeing what you actually did.
HallsofIvy
41,833
961
For (2) you are told to let y= vx and from that dy= vdx+ xdv. Replace y and dy in the equation with those. It will reduce to a separable equation.
vela
Staff Emeritus
Education Advisor
14,845
1,416
In that case, it's pretty straightforward to see the equation separates. Why do you think it can't be separated?
6,229
Also, when the variables are separated, the integration is not very difficult.
Related Threads on Differential Equations Help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
