How can differential equations be used to maximize profit?
In summary, differential equations can be used to model economic systems and optimize profits using mathematical techniques. This can be seen in the formula for compound interest, which can be solved using differential equations to find the optimal return on investment. This is applicable in a variety of business situations and can be used to compare investments based on their rate of return.
ojsimon
56
Hi
I am doing a research project on maximizing profit using mathematics, and found some high level phd theisis on maximizing profit using differential equations. I was wondering if anyone could explain in a simpler form how differential equations can be used to maximise profit.
Thanks
Olie
Differential equations are great for modeling things. For instance compounded interest follows the simple differential equation:
[tex]\frac{dy}{dt}=ky[/tex]
If an economic system was modeled with differential equations then optimization routines could be applied to try and maximize profits.
wait so that formula is just the formula for comound interest differentiated? so y=xk^n where n= time invested. k=intrest rate and x=initial amound. dy/dx=nx^n-1 ? How does this work? Thanks
It works like this...
[tex]\frac{dy}{dt} = ky[/tex]
[tex]\displaystyle\int_{y(0)}^{y(t)}\frac{dy}{y}=\displaystyle\int_{0}^{t}kdt[/tex]
[tex]\ln y(t) - \ln y(0) = kt - k*0[/tex]
[tex]\ln \frac{y(t)}{y(0)} = kt[/tex]
let y(0) = y_0
[tex]y(t) = y_0e^{kt}[/tex]
Well in a lot of cases certain business could be seen to be dependent on each other. So you might model these as a system of differential equations and figure out how to maximize profits.
Really there are infinite possibilities only bounded on how you make your economic model.
The formula for compound interest is:
[tex]a(t) = \left(1 + \frac {r} {n}\right) ^ {nt} [/tex]
which approaches in the limit as N approach infinity:
[tex]A(t) = A_0e^{rt}[/tex]
(see continuously compounded interest)
The previous post showed how to solve the differential equation I gave in an earlier post, you can verify this by differentiating the results. This is relevant with regards to investing because investments are compared on the basis of rate of return. If you pick up a book on engineering economics it will show how to treat non geometric profit returns in terms of an equivalent rate of return based on the time value of money.
Generally, I think company's give a fixed rate of return based on their current capital, I believe their is a quantity called return on capital that gives an idea of the expected growth rate. I'll give more details later.
1. What are differential equations?
Differential equations are mathematical equations that describe how a quantity changes over time. They involve rates of change and are used to model various systems and phenomena in science and engineering.
2. How are differential equations used in profit analysis?
In profit analysis, differential equations are used to model the relationship between a company's profits and various factors such as production rates, costs, and market demand. This allows businesses to make predictions and optimize their profits.
3. What is the difference between ordinary and partial differential equations?
Ordinary differential equations involve a single independent variable, while partial differential equations involve multiple independent variables. In profit analysis, ordinary differential equations are often used to model the change in profits over time, while partial differential equations are used to model the change in profits with respect to multiple variables.
4. Can differential equations accurately predict profits?
While differential equations can provide valuable insights and predictions, they are not always accurate. This is because they are based on certain assumptions and simplify real-world complexities. Other factors, such as external market conditions, can also affect profits.
5. What are some real-world applications of differential equations in profit analysis?
Differential equations are widely used in various industries for profit analysis. Some examples include predicting stock prices, optimizing production and pricing strategies, and analyzing market trends to make informed business decisions.
  • Differential Equations
