Differential Equations Question - Temperature
Here’s the problem:
A body was found dead in the refrigerator at 5:30am at 6 am the coroner measured the core temp of the body to be 85 degrees at 6:30 it was measured again, 84 degrees. Assume the body was killed in the refrigerator what time was the person killed?
I figured this part out. I used:
dT/dt = k(T-Tm)
Solving this:
T(t) = (T-Tm)e^kt +Tm
T is the temperature at time t and Tm is the temp around the body, the environmental temperature.
I solved this and got t = 5.3.
We needed to use positive numbers for t so the book assigned 6:00 am to t = 0 and so t= 1 would be 5 am and t = 5.3 would be roughly 12:42am.
Before I go to the next part I understand you can solve this with something called Laplace Transform but I haven’t learned that yet.
That part I think I understand. Now assume that the person wasn’t killed in the refrigerator and let h represent the number of hours in the refrigerator. So at h = 1 the body was moved in to the refrigerator at 5:00am what time was the person killed? And so on with h = 1 then 2 then 3 …
Filling in this chart:
h time body moved time of death.
12 6:00pm
I think my trouble is this idea of ‘h’
Numbers that need to be known are
Tm in the refrigerator is 50 degrees F
Tm in the diner is 70 degrees F
The person was initially 98.6 degrees
In the beginning I solved for e^k which I got 1.06
So the equations I’m working with is:
In refrigerator
T(t) = (T-50)(1.06)^h + 50 (*)
In the diner:
T(t) = (T-70)(1.06)^t + 70 (**)
I thought I needed to work backwards
If he was in the refrigerator for h= 1 plug this into (*) but I get 83 which doesn’t make sense because he needed to be warmer when he went into the refrigerator to be cooled down to 85. I was looking for that number to be 88 or 87 ish then I could use that as the target temp for (**) to solve for the time to get to 88 or 87 ish.
If you could be any help that would be great. Thanks
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
