Homework Help: Differential operator
  1. Nov 11, 2005 #1
    for the following question:
    [4(x^2)(D^2)+12xD+3)]y=0
    my problem:
    i only know how to solve this type of question if i change it back to its original form. however, if i want to solve it by just using D, how would i do that?
  3. Nov 12, 2005 #2
    quasar987
    What do you mean its original form?
    And what are you expected to do with this equation anyway?
  4. Nov 12, 2005 #3
    i mean that if i changed the D to y``
  5. Nov 12, 2005 #4
    quasar987
    OH! Well I guess just treat Dy as dy/dx and solve as you would.
  6. Nov 12, 2005 #5
    saltydog
    I looked at it early this morning and even briefly posted what I though was the factored form of the differential operators and even though it resulted in a correct answer, my factored version was incorrect because the differential operators are NOT commutative. Turns out equations with functions of x are not easily factored for this reason, something I'm not clear on. So I would just treat it as a regular Euler-Cauchy equation and look for a solution of the form:
    [tex]y=x^{m}[/tex]
    (unless someone can further comment about the factoring).:smile:
  7. Nov 13, 2005 #6
    i had the same problem as you when i tried to factor it too~
  8. Nov 14, 2005 #7
    This ia a quadratic in D.Just find out D using the formula used for quadratic equations and then proceed
  9. Nov 14, 2005 #8
    HallsofIvy
    The whole point is that this is an equation with VARIABLE coefficients. That method doesn't work with variable coefficients.
  10. Nov 14, 2005 #9
    @@ why doesn't it work for variable coefficients?
