Differential Squared: Do We Always Assume (dx)^2=0?
In summary, in a Taylor Expansion, higher order terms such as (dx)^2 are ignored because they have a 1/n! which becomes very small as n \to \infty. This decision to ignore the terms depends on the desired level of precision and can be determined using a remainder term. In the case of y=1+dx+(dx)^2, the term (dx)^2 is ignored because it is much smaller than dx. However, in the case of y=1+(dx)^2, the term cannot be ignored since there is no dx term to compare it to.
learner928
Quick question on high order term such as (dx)^2
in taylor expansion, higher order terms such as (dx)^2 is ignored because it's too small compared to the first order term...
if there is no first order term, can second order term still be ignored?
eg. if y=(dx)^2, do we always assume y=0 because (dx)^2 is too small?
In a Taylor Expansion, we expand [itex]f[/itex] about a point [itex]x_0[/itex]. Then we take successive derivatives at [itex]x_0[/itex]. So when you say "y=(dx)^2" do you mean that the first term in the Taylor expansion is [itex]f''(x_0)[/itex]?
Also, the higher order terms are not ignored because the derivatives are getting smaller. The higher order terms are ignored because the terms all have a [itex]1/n![/itex] which is getting very small, very fast as [itex]n \to \infty[/itex].
Now, to know when to cut the terms off, you need to 1)know how precise you need to be and 2)use a remainder term to get a bound on the truncation error (here is a wikipedia article: http://en.wikipedia.org/wiki/Taylor's_theorem)
sorry, maybe I should ask my question this way:
if we have y=1+dx+(dx)^2 in the limit of x->0, we ignore the term (dx)^2 and approximate y=1+dx, is this because the term (dx)^2 is too small relative to dx or is it because the term is just absolutely too small?
ie. if we have y=1+(dx)^2 in the limit of x->0, do we still ignore (dx)^2 in this case or we can't since there is no dx term.
You mean as [itex]dx \to 0 [/itex] right? Usually the arguments you are making are more intuitive type arguments rather than rigorous arguments. But, we ignore the dx^2 because it is much smaller than dx. In your question, the dx^2 can't be ignored.
1. What is differential squared?
Differential squared is a mathematical concept that involves taking the square of the differential of a variable. This is commonly used in calculus and physics to represent small changes in a function or quantity.
2. Why do we assume (dx)^2 = 0?
This assumption is based on the principle of infinitesimal approximation, which states that when dealing with very small changes, the square of the change is considered negligible. This simplifies calculations and allows us to focus on the main terms in an equation.
3. Are there any circumstances where (dx)^2 does not equal 0?
Yes, there are cases where (dx)^2 can represent a non-zero value. For example, in non-linear systems or when dealing with higher-order differentials, (dx)^2 can have a non-zero value and must be taken into account in calculations.
4. Can we assume (dx)^2 = 0 in all mathematical operations?
No, we cannot assume this in all operations. The assumption of (dx)^2 = 0 is only valid when dealing with infinitesimal changes. In other operations, such as integration or differentiation, the value of (dx)^2 must be considered carefully.
5. How does (dx)^2 = 0 affect the accuracy of calculations?
Assuming (dx)^2 = 0 can lead to small errors in calculations, especially when dealing with highly precise measurements. In some cases, these errors may be negligible, but in others, they can significantly affect the accuracy of results. Therefore, it is important to consider the validity of this assumption in each specific scenario.
  • Differential Equations
