Differentiate damped sinusoid
In summary, to sketch the unit response of a damped sinusoid in an underdamped system, you can differentiate the equation, find the turning points, and plot the position and velocity responses to create a graph that illustrates the behavior of the system over time.
akabyte
Hi all,
I'm trying to sketch a unit response of a damped sinusoid an (unnderdamped system). I presume I'll have to differentiate the function such as the following (1 + 1.25e^(-6t)cos(8t+143))u(t) and then find the turning points of the function and then sketch it.
However I'm encountering problems in differentiating it properly and finding the two critical points, I was therefore hoping if any of you guys out there would know how to sketch the function either by inspection or any other method.
Cheers,
I would first like to clarify that a damped sinusoid is a type of response that occurs in a system that is undergoing damped oscillations. This means that the amplitude of the oscillations decreases over time due to the presence of a damping force. The equation you have provided, (1 + 1.25e^(-6t)cos(8t+143))u(t), is an example of a damped sinusoid, where u(t) is the unit step function.
To sketch the unit response of this damped sinusoid, you can follow these steps:
1. First, differentiate the equation with respect to time. This will give you the velocity equation, which represents the rate of change of the position of the system. In this case, the velocity equation will be: (-7.5e^(-6t)sin(8t+143)+10e^(-6t)cos(8t+143))u(t).
2. Next, find the turning points of the velocity equation by setting it equal to zero and solving for t. In this case, there will be two turning points at t = 0 and t = 0.4 seconds.
3. Using the turning points, you can sketch the velocity response by plotting the velocity values at different time points. For example, at t = 0, the velocity will be 10 units, and at t = 0.4 seconds, the velocity will be -7.5 units. You can connect these points to create a smooth curve.
4. To sketch the position response, you can integrate the velocity equation with respect to time. This will give you the position equation, which represents the displacement of the system from its equilibrium position. In this case, the position equation will be: (-1.25e^(-6t)sin(8t+143)+1.25e^(-6t)cos(8t+143))u(t).
5. Using the position equation, you can sketch the position response by plotting the position values at different time points. For example, at t = 0, the position will be 0 units, and at t = 0.4 seconds, the position will be approximately 0.08 units. You can connect these points to create a smooth curve.
6. Finally, you can combine the velocity and position responses to sketch the unit response of the damped sinusoid. The
1. What is a damped sinusoid?
A damped sinusoid is a mathematical function that describes a periodic oscillation with decreasing amplitude over time. It can be represented by the equation y = A * e^(-at) * sin(bt + ϕ), where A is the initial amplitude, a is the damping factor, b is the frequency, t is time, and ϕ is the phase shift.
2. How is a damped sinusoid different from a regular sinusoid?
A regular sinusoid has a constant amplitude over time, while a damped sinusoid has a decreasing amplitude. This is due to the presence of a damping factor in the equation, which causes the amplitude to decrease exponentially as time passes.
3. What causes damping in a sinusoid?
Damping in a sinusoid can be caused by various factors, such as friction, resistance, or energy loss. These factors can affect the amplitude of the oscillation and cause it to decrease over time.
4. How is damping represented in a damped sinusoid graph?
Damping is represented in a damped sinusoid graph by the decreasing amplitude over time. The higher the damping factor, the faster the amplitude decreases. This can be seen as the curve flattening out and approaching the x-axis as time goes on.
5. What are some real-world applications of damped sinusoids?
Damped sinusoids are commonly used in various fields such as physics, engineering, and economics. They can be used to model damped oscillations in mechanical systems, electrical circuits, and stock market trends. They are also used in signal processing and filtering, as well as in musical instruments to produce certain sounds and tones.
