Finding the Derivative of a Function with Arctan
In summary, the conversation is about finding the derivative of a function containing arctan and the best method to use. Different options are discussed, including differentiating each term separately and using the chain rule. The final solution is found to be -1/(x^2 + 1).
ACLerok
194
http://www.eden.rutgers.edu/~cjjacob/images/arctan.gif
I was given this problem yesterday. It's asking me to differentiate a function containing arctan. Should I find a common denominator and combine them into one term, should I just differentiate each term separately? Please I need help with this thing! I've been told it comes out to 0 but I'm not sure if he is correct or not. Thanks for replying if you choose to!
Should you try to combine the two arctan terms into one? Yikes! :eek:
No, just differentiate each term separately. If you know how to differentiate arctan(x) and how to use the chain rule, this should be a snap.
According to maple, f'(x) is this
[tex]\left( 1+{x}^{2} \right) ^{-1}-{\frac {1}{{x}^{2} \left( 1+{x}^{-2} \right) }}[/tex]
I can't help with how to get that though; I've never dealt with arctan before.
It simplifies to 0.
Draw a right triangle with a base of length 1 and a side of length x. Note that one of the acute angles is equal to arctan(x) and the other acute angle is equal to arctan(1/x). Since the three interior angles of any triangle add up to pi radians, and since the remaining angle in this triangle is pi/2, then the sum arctan(x) + arctan(1/x) has to equal the constant value pi - pi/2 = pi/2. Its derivative is thus zero.
[tex]y = \arctan{x}[/tex]
[tex]\tan{y} = x[/tex]
[tex]\frac{dy}{dx}\sec^2{y} = 1[/tex]
[tex]\frac{dy}{dx} = \cos^2{y}[/tex]
Draw a triangle based on the second line, tan(y) = x. This means that the opposite side is x and the adjacent side is 1, giving the hypotenuse a value of [itex]\sqrt{x^2 + 1}[/itex]. This means that cos(y) will be 1 over the hypotenuse, i.e.
[tex]\cos{y} = \frac{1}{\sqrt{x^2 + 1}}[/tex]
which means that our derivative is
[tex]\frac{dy}{dx} = \frac{1}{x^2 + 1}[/tex]
[tex]\frac{d}{dx}\Big(\arctan{x}\Big) = \frac{1}{x^2 + 1}[/tex]
The rest follows from the chain rule.
cookiemonster
cookiemonster
ok i think I can see what you have done. can you explain how you got from tan(y)=x to the line below it? did you just differentiate both sides with respect to y?
And then at the end are you saying to just substitute the equation for the derivative of arctan into the orginal equation?
Thanks for all your help guys!
Yes. The third line is reached by differentiating the second with respect to x.
The derivative of arctan(1/x) is found in a similar manner, or you can differentiate it using a substitution and the chain rule. Both methods require just about the same amount of work.
cookiemonster
I had a buddy in high school who liked to use non-calculus techniques to get the answer to homework problems that the calculus teacher assigned. The kid knew darn well that the teacher would not give credit for getting the right answer by "devious" means, but that didn't stop him from doing that. I think he had some sort of persecution complex, and he loved to wail to anyone who would listen about how unfair the teacher was.
Heh, just read your solution, Janitor. That's pretty neat.
cookiemonster
Thanks, Cookiemonster! But I had a guilty conscience since I figured the teacher wouldn't give him any credit for it, since it doesn't teach him how to do derivatives.
Haha, why not? He still has to differentiate pi/2. =]
cookiemonster
True!
cookiemonster
ok so the derivative of arctan x is 1/[(x^2)+1] but what is the derivative of arctan(1/x) do i just plug 1/x into 1/[(x^2)+1]? it seems like the logical thing to do but then again, i may be totally wrong.. Thanks.
As I said in my previous post, you can figure it out using the same method as for arctan(x), i.e.
tan(y) = 1/x
differentiate both sides implicitly to get
dy/dx = -cos^2(y)/x^2
then we build a triangle based on tan(y) = 1/x, which means the opposite side is 1 and the adjacent side is x, so the hypotenuse is sqrt(x^2 + 1), so the cos^2(y) term is x/sqrt(x^2 + 1), meaning
dy/dx = 1/x^2 * -x^2/(1+x^2) = -1/(x^2 + 1)
Alternatively, you could have made a substitution u = 1/x into the derivative, so we have
d/dx(arctan(u)) = df(u)/du * du/dx = 1/(1 + 1/x^2)*-1/x^2
which can be shown to be equivalent with a little bit of algebra.
cookiemonster
tan(y) = 1/x
cookiemonster
so the derivative of the problem simplifies to -1/(x^2 + 1)? and that equals 0?
Yes. Both Janitor's solution and brute force show the solution to be 0. You wanted it to be 0 in the first place anyway, didn't you?
cookiemonster
cookiemonster
alright, i understand everything now except this one line:
how did you get this? i got up to dy/dx = -x^2+1/x^2
whatd you do to get that line? i tried using the quotient rule to differentiate it but i got 2x/x^4 but that is incorrect.
i never wanted the answer to be zero, i was just told that it is. i guess. thanks alot!
That's the derivative of the second term in your original expression. Add that to the derivative of the first term and the sum will equal zero.
I assume you can differentiate arctan(x)? That will be the first term of your answer.
Now use the chain rule to differentiate arctan(u), where u = 1/x. (What's the derivative of 1/x?) That will be the second term making up your answer.
for differentiating arctan 1/x, i got up to drawing the triangle to find cos(y) and i got dy/dx = -cos^2(y)/x^2. know what do i do with these two piece of information? do i just substitute sqrt(x^2+1) into dy/dx = -cos^2(y)/x^2 or what? please this is due tomorrow and i don't know how to finish it!
cos(y) can be expressed in terms of x. What does the triangle you drew tell you it should be?
cookiemonster
sqrt(x^2+1). i don't know how you differentiated it. can you just explain the steps you took?
Differentiated what? I had two entire posts on the method to differentiate arctan(x) and arctan(1/x). Which parts are giving you trouble?
cookiemonster
i don't understand what you did here and how you got this:
this is from differentiating arctan(1/x)
i know that you just substituted sqrt(x^2+1) into dy/dx = -cos^2(y)/x^2 but I have no clue how you went about finding the derivative or which method(s) you used. (quotient rule/chainrule/both/etc.) i know I'm giving you a hard time but calc isn't my piece of cake. sorry.
I used implicit differentiating.
y = arctan(1/x)
is equivalent to
tan(y) = 1/x
but the second one is easier to differentiate. So I did that and solved for dy/dx to get
Since tan(y) = 1/x, we can make a right triangle. Assign one angle to be y, so therefore the side opposite y will be equal to 1 and the adjacent side will be equal to x. You understand how to make this triangle?
By the pythagorean theorem, the hypotenuse of the triangle will be sqrt(x^2 + 1). So cos(y) is equal to x/sqrt(x^2 + 1), and therefore cos^2(y) = x^2/(x^2 + 1). Substitute this into the expression for dy/dx to get
dy/dx = -(x^2/(x^2 + 1))(1/x^2)
which simplifies to
dy/dx = -1/(x^2 + 1)
If you're still having trouble, you're going to need to be more specific about what's giving you difficulty.
cookiemonster
i don't know how you differentiated this: dy/dx = -(x^2/(x^2 + 1))(1/x^2)
and got: dy/dx = -1/(x^2 + 1)
haha nevermind i got it. Thanks for all your help!
1. What is the derivative of arctan?
The derivative of arctan is 1/(1+x^2).
2. How do you differentiate arctan?
To differentiate arctan, we use the quotient rule, which is (f'(x)g(x)-f(x)g'(x))/[g(x)]^2.
3. Can you simplify the derivative of arctan?
Yes, the derivative of arctan can be simplified to 1/(1+x^2).
4. What is the domain and range of the derivative of arctan?
The domain of the derivative of arctan is (-∞, ∞) and the range is (-1, 1).
5. How is the derivative of arctan used in real life?
The derivative of arctan is used in various fields such as physics, engineering, and economics to calculate rates of change and find optimal solutions for problems.
  • Differential Equations
