Differentiation and Integration cannot always be swapped
In summary, we discussed the function ##f(x,y)=\begin{cases}x|x|g(xy), & y\neq 0 \\ 0, & y=0\end{cases}## where ##g(t)=e^{-t^2}## and showed that the integral of ##f## (with respect to ##y##) is equal to the derivative of the integral of ##f## with respect to ##x##, but the partial derivatives do not match, leading to a contradiction. This shows that the condition in question 10. e) is not true for this function.
Delta2
Insights Author
2,625
Well here is my (I hope successful this time ) attempt at 10. e)
We consider the function ##f(x,y)=\begin{cases}\dfrac{e^{-x|y|}}{y}, y\neq 0 \\ 0, y=0\end{cases}##.
For this function for ##y\neq 0## it is for any ##x##, ##\frac{\partial f}{\partial x}=-\frac{|y|}{y}e^{-x|y|}##.
Also it should be clear that due to the infinite discontinuity at the points ##(x,0)## the integral ##\int_\mathbb{R}f(x,y)dy## does not converge hence the left hand side of the condition of 10. e) is infinite (or undefined).
The right hand side of the condition is ##\int_\mathbb{R}-\frac{|y|}{y}e^{-x|y|}dy=\int_{-\infty}^0e^{xy}dy+\int_0^{+\infty} -e^{-xy} dy=0## ,
So the condition is true for this ##f##.
Mathematics news on Phys.org
We consider the function ##f(x,y)=\begin{cases}\dfrac{e^{-x|y|}}{y}, y\neq 0 \\ 0, y=0\end{cases}##. For this function for ##y\neq 0## it is for any ##x##, ##\frac{\partial f}{\partial x}=\frac{|y|}{y}e^{-x|y|}##.
The right hand side of the condition is ##\int_\mathbb{R}\frac{|y|}{y}e^{-x|y|}dy=\int_{-\infty}^0-e^{xy}dy+\int_0^{+\infty} e^{-xy} dy=0## ,
I was looking for finite values, i.e. existing integrals.
Edit:
However it suffices that the two sides differ at a point, where the differentials are evaluated. This would make the functions different. Your idea was good. My example also works with ##g\, : \,t \longmapsto \exp (-t^2)## and ##g(xy)##. But instead of dividing by ##y##, I multiplied by ##x## which avoids singularities.
Likes Delta2
Ok well, I see so you looking for an example where both sides converge. ok understood.
See my edit. You have almost the right function.
Likes Delta2
Interesting, my original line of thinking is that f should have some discontinuities in order for the two sides to be different. So you saying there is some f that is continuous in R yet the two sides are different?
Hmmmm,, trying to follow your hint.. does the function ##f(x,y)=xe^{-x|y|}## does the job?
fresh_42 said:
I don't see what your absolute value of ##y## is good for. I had a slightly different function, such that differentiation will leave me a factor ##x## to make it zero at ##x=0##.
Er but the integral on the left hand side will not converge if I don't put |y|...
But let me ask you directly, is your function continuous everywhere in R?
If I understood well, your "main" function is ##f(x,y)=xe^{-x^2y^2}## but is that all, you haven't defined any special discontinuities?
I first consider ##t \longrightarrow \exp(-t^2)## and calculated the integral. Then I used a continuously differentiable function ##f\, : \,(x,y) \longmapsto h(x)g(xy)## to calculate both sides. If you want to follow this path, find ##h(x)## and do the computations! The latter is part of the question, so wordings like "Also it should be clear that" aren't especially helpful.
ok so for 10. e) I will follow the suggestion of @fresh_42 .
First let's consider the function ##g(t)=e^{-t^2}## and the integral ##\int_{\mathbb{R}} g(t)dt=\int_{\mathbb{R}} e^{-t^2} dt=\sqrt \pi##
Next we consider the function ##f(x,y)=xg(xy)=xe^{-x^2y^2}##
Then ##\int_{\mathbb{R}} f(x,y)dy=\int xg(xy)dy##, integration by substitution ##t=xy\Rightarrow dt=xdy## so we get that (for ##x\neq 0##)
##\int_{\mathbb{R}} f(x,y)dy=\int xg(xy)dy=\int g(t)dt=\sqrt\pi##, and the derivative of this with respect to x is zero, so the LHS of the condition is 0. (For ##x=0## this integral is 0).
For the RHS of the condition we first note that ##\frac{\partial f}{\partial x}=g(xy)-2x^2y^2g(xy)##, and integrating w.r.t y we get (for ##x\neq 0##)
##\int_{\mathbb{R}}\frac{\partial f}{\partial x}dy=\int_{\mathbb{R}} g(xy) dy-2 \int_{\mathbb{R}}x^2y^2g(xy)dy=\frac{\sqrt\pi}{x}-2x^2\frac{\sqrt\pi}{2x^3}##. This is also zero. (For ##x=0## this integral is ##\int_{\mathbb{R}}(g(0y)-0)dy=+\infty##).
Well it seems that again I am stumbled upon a non convergence, hmmm, are you sure @fresh_42 that there is function such that both sides converge (for any ##x##) yet they differ?
That wasn't my suggestion! My suggestion is ##f(x,y)=x|x|g(xy)## with ##g(t)=\exp(-t^2)## which leads to
\sqrt{\pi}=\left.\dfrac{d}{dx}\right|_{x=0} F(x)=\left.\dfrac{d}{dx}\right|_{x=0}\int_\mathbb{R}f(x,y)\,dy \neq \int_\mathbb{R}\left.\dfrac{\partial}{\partial x}\right|_{x=0}f(x,y)\,dy =0
\sqrt{\pi}=\left.\dfrac{d}{dx}\right|_{x=0} F(x)=\left.\dfrac{d}{dx}\right|_{x=0}\int_\mathbb{R}f(x,y)\,dy \neq \int_\mathbb{R}\left.\dfrac{\partial}{\partial x}\right|_{x=0}f(x,y)\,dx =0
You mean ##dy## at the end?
I would quibble that ##f(0,y)## is not defined. I thought of making an example using Cantor functions as discussed here, but then the partial derivatives are only defined "almost everywhere", so that is not rigorous either.
Thanks, typo corrected. And ##f(0,y)=0\,.##
Hmmm @fresh_42 , if we set ##F(x)=\int_{\mathbb{R}}f(x,y)dy## then ##F(0)=0## and
##F'(0)=\lim_{x\rightarrow 0}\frac{F(x)-F(0)}{x-0}=\lim \frac{F(x)}{x}=lim_{x\rightarrow 0} \frac{\sqrt\pi|x|}{x}## which doesn't exist...
##F(x) =x\cdot \sqrt{\pi}## so ##F'(x)=\sqrt{\pi} ## which does exist.
in post #89 I calculated that ##\int_{\mathbb{R}}xg(xy)=\sqrt\pi## where am I wrong there?
Are you saying that ##\int_{\mathbb{R}}|x|g(xy)=\sqrt\pi##?
In my opinion it is ##F(x)=|x|\sqrt\pi##
Find an example for which
\dfrac{d}{dx}\int_\mathbb{R}f(x,y)\,dy \neq \int_\mathbb{R}\dfrac{\partial}{\partial x}f(x,y)\,dy
Proof:
We first define ## g(t) = \exp(-t^2) ## and show ## I:= \int_\mathbb{R} g(x)\,dx = \sqrt{\pi} \,. ##
\begin{align*}
I^2&=\left(\int_\mathbb{R}g(x)\,dx \right)\cdot \left(\int_\mathbb{R}g(y)\,dy \right)\\
&=\int_\mathbb{R}\int_\mathbb{R}g(x)g(y)\,dx\,dy\\
&=\int_\mathbb{R}\int_\mathbb{R}\exp(-x^2-y^2)\\
&=\int_0^{\infty}\int_0^{2\pi}r\exp(-r^2)\,d\varphi \,dr\\
&=2\pi \int_0^\infty r\exp(-r^2)dr\\
&=-\pi\left[\exp(-r^2) \right]_0^\infty\\
&=\pi
\end{align*}
The function ##h(x,y)=x\cdot g(xy)## is continuous, however the parameter integral ##H(x)=\int_\mathbb{R}h(x,y)\,dy## is not:
\begin{align*}
H(x)&=\int_\mathbb{R}x\cdot g(xy)\,dy\\
&=\operatorname{sgn}(x) \int_\mathbb{R}|x|\cdot g(xy)\,dy\\
&=\operatorname{sgn}(x) \int_\mathbb{R} g(t)\,dt \\
&=\operatorname{sgn}(x)\cdot \sqrt{\pi}
\end{align*}
Now let ##f\, : \,\mathbb{R}\times \mathbb{R} \longrightarrow \mathbb{R}## the continuously differentiable function ##f(x,y)=x|x|g(xy)## such that we for ##F(x)=\int_\mathbb{R}f(x,y)\,dy##
\begin{align*}
F(x)&=\int_\mathbb{R}x|x|g(xy)\,dy\\
&= x \int_\mathbb{R}|x|g(xy)\,dy\\
&=x \int_\mathbb{R}g(t)dt\\
&=x\sqrt{\pi}\quad\quad \text{ and }\\
F\,'(x)&=\sqrt{\pi}
\end{align*}
Differentiation under the integral gives us
\int_\mathbb{R}\dfrac{\partial}{\partial x}f(x,y)\,dy=\int_\mathbb{R}\left(2|x|g(xy)+x|x|\dfrac{d}{dx}g(xy) \right)\,dy
which vanishes at ##x=0\,.## For ##x\neq 0## we get
\begin{align*}
\int_\mathbb{R}\dfrac{\partial}{\partial x}f(x,y)\,dy&=2\int_\mathbb{R}g(t)\,dt - 2\int_\mathbb{R}t^2g(t)\,dt\\
&= 2\sqrt{\pi}-2\left(\left[-\dfrac{t}{2}\exp(-t^2)\right]_{-\infty}^{\infty} + \dfrac{1}{2}\int_\mathbb{R}g(t)\,dt \right)\\
&=\sqrt{\pi}
\end{align*}
In the end we have
and although both sides are identical for ##x\neq 0## they differ at ##x=0## and thus cannot be the same.
Likes Delta2
Well this is interesting, it seems that ##\int_{\mathbb{R}}|x|g(xy)=\int_{\mathbb{R}}xg(xy)=\sqrt\pi## or where am I wrong in the last equality? Where post #9 goes wrong?
quote from post #9
The point is that we only have ##y## in ##g(xy)## as variable. This alone determines the sign of ##xy##. Therefore, ##x## is treated as a positive constant here, because in ## t \longmapsto g(t) = \exp(-t^2)## we have ##g(c\cdot t)= \exp(-c^2t^2)## and the constant factor at our variable has to be positive in ##\dfrac{d}{dy}(xy)=|x|\cdot 1\,.##
quote from post #9
This is just another function than mine was. And you get a quotient at the end: ##\dfrac{1}{x}\text{ or }\dfrac{|x|}{x}## which my solution avoids.
I am not sure...
But can you tell me where the integration by substitution goes wrong at post #9. I used ##t=xy## and ended up with ##\int_R xg(xy)dy=\int_R g(t)dt=\sqrt\pi###...
Apparently there is a subtle mistake here, I ll try to understand it, thanks
OK I found where the mistake is. If ##x<0## and ##t=xy## then for ##y=-\infty## it is ##t=+\infty## and vice versa, so for ##x<0## it is ##\int_{-\infty}^{+\infty}xg(xy)dy=\int_{+\infty}^{-\infty}g(t) dt=-\sqrt\pi##
Thanks all and especially @fresh_42 , the search for this counterexample was an interesting learning experience for me!
1. Why can't differentiation and integration always be swapped?
Differentiation and integration are two different mathematical operations that are not always interchangeable. In most cases, the order in which they are performed matters, and swapping them can lead to incorrect results.
2. When can differentiation and integration be swapped?
There are some special cases where differentiation and integration can be swapped, such as when the function being integrated is a constant or when the integration is performed over a certain range of values.
3. What happens if differentiation and integration are swapped?
If differentiation and integration are swapped incorrectly, it can result in the wrong answer or an unsolvable equation. This is because differentiating and integrating undo each other's effects.
4. Can differentiation and integration be swapped for all types of functions?
No, differentiation and integration cannot be swapped for all types of functions. They are only interchangeable for certain types of functions that have specific properties.
5. How can I determine if differentiation and integration can be swapped for a particular function?
You can determine if differentiation and integration can be swapped for a particular function by analyzing its properties and applying mathematical rules. It is always best to consult a calculus textbook or a mathematician for a definitive answer.
  • General Math
  • Math POTW for Graduate Students
  • General Math
