• Support PF! Buy your school textbooks, materials and every day products Here!
Differentiation help ,
  • Thread starter tweety1234
The curve [tex] y = ax^{2} + bx [/tex] passes through the point (2,4) with gradient 8. Find a and b .
I have no idea how to work out a and b , do I use simultaneous equations?
Answers and Replies
well start of by thinking about what your dy/dx would be.....
okay so dy/dx = [tex] 2ax + b [/tex] from this how do I find what a and b equal ?
4,793
Use the fact that (2, 4) is a point on the curve in your given equation, which will give you an equation that involves only a and b.
Then use the fact that at x = 2, dy/dx = 8 in your equation for the derivative. This will give you another equation in a and b.
Finally, solve the two equations in a and b simultaneously.
so I just sub in the values for x and y ?
are these two equations correct..
[tex] 4a + b = 4 [/tex]
[tex] 4a + b = 8 [/tex]
danago
Have another look at the first equation.
x=2 so 2x2=4? can you give more hints, cause I am really stuck
thank you!
is it meant to be [tex] 32a + b =4 [/tex] ?
4,793
No.
Write your first equation.
Substitute 2 for x and 4 for y in that equation. The other equation you wrote, 4a + b = 8, is correct.
[tex] y = ax^{2} + bx [/tex] , [tex] 4a + 2b = 4 [/tex] is this correct? so a = 3 and b = -4 ?
HallsofIvy
41,770
911
Check it yourself. IF a= 3 and b= -4, you have y= 3x2- 4x. What is y when x= 2? What is y' when x= 2?
Related Threads for: Differentiation help ,
  • Last Post
  • Last Post
