How do I find the derivative of f(x)=x+9/x without using the power rule?
In summary, the problem is this:
efekwulsemmay
54
This is the larger problem to the small portion that I already posted in the Precalc Hw help forum. I still can't figure out how to get to the answer.
The problem is this:
I am trying to find the derivative of [tex]f(x)=x+\frac{9}{x}[/tex].
I know via power rule that the answer will be:
[tex]\frac{dy}{dx}=1+\frac{9}{x^{2}}[/tex]
However, I must do it the messy way. :grumpy:
This is what I have got so far:
1.[tex]\frac{f(x+h)-f(x)}{h}[/tex]
2.[tex]=\lim_{h\rightarrow0}\frac{\left((x+h)+\frac{9}{x+h}\right)-\left(x+\frac{9}{x}\right)}{h}[/tex]
3.[tex]=\lim_{h\rightarrow0}\frac{x+h+\frac{9}{x+h}-x-\frac{9}{x}}{h}[/tex]
4.[tex]=\lim_{h\rightarrow0}\frac{h}{h}+\frac{\frac{9}{x+h}}{h}-\frac{\frac{9}{x}}{h}[/tex]
5.[tex]=\lim_{h\rightarrow0}1+\left(\frac{9h}{x+h}-\frac{9h}{x}\right)[/tex]
6.[tex]=\lim_{h\rightarrow0}1+\left(\frac{x}{x}\cdot\frac{9h}{x+h}-\frac{9h}{x}\cdot\frac{x+h}{x+h}\right)[/tex]
7.[tex]=\lim_{h\rightarrow0}1+\frac{9hx-9hx-9h^{2}}{x(x+h)}[/tex]
8.[tex]=\lim_{h\rightarrow0}1+\frac{-9h^{2}}{x(x+h)}[/tex]
I don't know where to go from here or even if here is where I am supposed to be. Help please?
Feldoh said:
Partial fraction decomposition might work.
Partial whos-a-what? :confused:
You were doing fine until step 5. Then you changed (9/(x+h)-9/x)/h into (9h/(x+h)-9h/x). You can't do that. You just moved h into the numerator by 'magic'. Leave it in the denominator! You also don't want to multiply by h/h in the next step. You want to multiply by x/x to get the common denominator.
Ok that's where I went wrong. Thanks for your help. :biggrin: Btw the multiplying h/h was a typo, its supposed to be x/x.
Awesome. So going by what you said Dick, I figured out that I messed up by putting that h in the numerator (slopy fraction solving :) ) I worked it out and got the right answer. Thanks for your help Dick.
1. What is differentiation problem?
Differentiation problem refers to the mathematical process of finding the rate at which a function changes, also known as the derivative. It is used to analyze the behavior of functions and is an important concept in calculus.
2. How do you solve a differentiation problem?
To solve a differentiation problem, you need to use the rules of differentiation, such as the power rule, product rule, and chain rule. These rules help you find the derivative of a function, which represents the rate of change of the function at any given point.
3. Why is differentiation important?
Differentiation is important because it allows us to analyze the behavior of functions and make predictions about their future values. It is also used in many real-world applications, such as physics, economics, and engineering.
4. What are some common applications of differentiation?
Some common applications of differentiation include finding the maximum and minimum values of a function, calculating the velocity and acceleration of an object, and optimizing functions in economics and engineering.
5. Can differentiation be used in higher dimensions?
Yes, differentiation can be used in higher dimensions, also known as multivariable calculus. In this context, the derivative becomes a vector called the gradient, which represents the rate of change in multiple directions.
