How do I differentiate m(L^2)/16?
In summary: Does your textbook have examples of each type of problem?In summary, the conversation revolves around a question regarding calculating dI/dx, with the participants discussing the use of the product rule and chain rule for differentiation. They also clarify that the masses and length are constants and do not need to be taken out as such.
matt_crouch
161
i have been told to calculate DI/Dx i calculated I as being = m(L^2)/16
how do i differentiate this? I am confussed with what happens to the m is it a constant an just removed? same with the 1/16 i assume that is removed as a constant?
just need some clarification.
thanks
Is that all you are told? If m and L are functions of x, then you will need to take that into consideration.
If m and L are just constants, then treat them like you would any other number.
EDIT: Hmm just re-read your question; did you mean you want to calculate dI/dL and not dI/dx?
Well the question says that it passes a distance of x from the perpendicular axis ? does that mean i have to substitute a value for dx in?
How about posting the problem exactly as it was given to you? That would save us a lot of time.
OK.
Two point masses m1 and m2 are separated by a massless rod of length L.
a) write an expression for the moment of inertia I about an axis perpendicular to the rod and passing through it a distance x from mass m1
b)Calculate dI/dx and show that I is a minimum when the axis passes through the centre of mass of the system
So m and L are not functions of x.
Now show us how you calculated I. If you haven't drawn a picture, now would be a good time to do that.
i think i calculated I i drew a picture an since its two point masses i don't think i need to intergrate so therefore the Inertia is equal to the sum of the product individual mass and the distance from the axis squared.
so i then got [m1L^2]/32 +[m2L^2]/32 so simplify this to get
mL^2/16
You are assuming that the two masses are equal, which is not given. Also, you have not used the information that the axis passes through a point a distance x from m1.
should i replace L with X then? i don't really kno where to go
To calculate the moment of inertia you need to know the mass and the length of the lever arm (i.e., the distance from the mass to the point for which you're calculating the moment of inertia).
What is the M.I. for mass m1?
What is M.I. for mass m2?
so the M.I for mass one =m1x^2 ? that was using the equation I=mr^2 where r is the radial distance
so the M.I for mass two is = m2(L-x)^2
Yes for both. The combined M.I. is I = m1x2 - m2(L - x)2, right? The two masses are on opposite sides of the axis, so their lever arms are acting in opposite directions.
Now, can you find dI/dx and finish off part b?
ahh cheers thanks for the help ill give b a shot now. =]
so b)
dI/dx = m.2x+x^2-[-2(L-x)]+(L-x)^2
not so sure if iv done that right :/
matt_crouch said:
so b)
No, not right. dI/dx will have both m1 and m2 in it.
To make your work more readable here, use the X2 button for exponents and the X2 button for subscripts. These buttons are in the advanced menu bar. If you don't see this menu bar, click the Go Advanced button just below the text entry area.
sorry was supposed to put
m12x+x2-m2(-2[L-x])+(L-x)2
The first term is right (2m1x) but the rest isn't, and I have no idea how you got what you show.
Start with I = m1x2 - m2(L - x)2, and show me your steps in getting dI/dx.
Im not really sure i just used the product rule. I am not sure what happens to the mass or the length or if they are taken out as constants so need some help really
The masses and length L are constants. You don't just "take them out."
dI/dx = d/dx(m1x2) - d/dx(m2(L - x)2)
= 2m1x - m2 d/dx ((L - x)2)
Use the chain rule to get the remaining derivative. If you don't know the chain rule, expand (L - x)2 and differentiate that instead.
so m2d/dx(L-x)2
will that go to
m22(L-x)L ?
matt_crouch said:
so m2d/dx(L-x)2
will that go to
m22(L-x)L ?
No. Why do you have that final L?
chain rule? u differentiate the bracket then times by the deferential of the inside of the bracket since x goes to -1
should it be -L ?
should it be -L ?
Yes, use the chain rule. To differentiate (L - x)2, you get 2(L - x) times the derivative (not differential) of what's inside the parentheses. What is d/dx(L - x)?
What you said about x going to -1 makes no sense.
is the derivative
dL/dx -1
Yes, d/dx(L - x) = dL/dx - 1, but this should be simplified. What is dL/dx?
i don't know :/
What is dm1/dx?
What is dm2/dx?
What is dL/dx?
im not sure how do i calculate them?
What is d(2)/dx?
What is d([itex]\pi[/itex])/dx?
What is the derivative of any constant?
is the derivative 0 then ?
  • #31
Yes! Since dL/dx = 0, what do you get for dI/dx?
dI/dx = d/dx(m1x2 - m2(L - x)2) = ?
  • #32
so dI/dx=2m1+2m2(L-x)
  • #33
Now the second term is correct, but the first one isn't. You had it right before.
Since you're having so much trouble with differentiation, I would advise you to go back and review the basic differentiation rules, especially the product rule and chain rule, and derivative of a constant rule.
  • #34
ahh ye just missed the x from the first term
thanks for all the help btw =]
1. How do I differentiate m(L^2)/16 with respect to m?
To differentiate m(L^2)/16 with respect to m, we can use the power rule for differentiation. This states that when differentiating a term with a variable raised to a power, we can bring down the power and subtract 1 from the original power. Therefore, the differentiation of m(L^2)/16 with respect to m is (L^2)/16.
2. How do I differentiate m(L^2)/16 with respect to L?
To differentiate m(L^2)/16 with respect to L, we can use the product rule for differentiation. This states that when differentiating a product of two terms, we can take the derivative of the first term and multiply it by the second term, plus the derivative of the second term multiplied by the first term. Therefore, the differentiation of m(L^2)/16 with respect to L is (mL)/8.
3. Can I simplify m(L^2)/16 before differentiating?
Yes, you can simplify m(L^2)/16 before differentiating. In this case, we can use the power rule to simplify the term (L^2)/16 to L/4. Therefore, the simplified version of m(L^2)/16 is mL/4.
4. How do I differentiate m(L^2)/16 if m and L are both variables?
If both m and L are variables, we can use the product rule and the power rule to differentiate m(L^2)/16. The differentiation with respect to m would be (L^2)/16, and the differentiation with respect to L would be (2mL)/16, which simplifies to mL/8.
5. Can I differentiate m(L^2)/16 if m and L are constants?
No, you cannot differentiate m(L^2)/16 if m and L are constants. This is because differentiation is only applicable to variables, not constants. If m and L are constants, then the expression m(L^2)/16 is already simplified and cannot be further differentiated.
