Differentiation questions
In summary, the first problem involves finding dy/dx for the given equation, using the chain rule and implicit differentiation. The second problem involves simplifying given equations and then using the chain rule to find dy/dx at a specific value of a.
billmccai
Find dy/dx for:
a) xsin(xy^2) - ln(x/y) = y
b) x = 3cos(a), y = 2sec(a). simplify then find dy/dx when a = pi/3
I've done both of them, was just hoping someone could check I've done things correctly. I'm still feeling pretty uncertain.
a)
dy/dx = d/dx[xsin(xy^2) - ln(x/y)]
dy/dx = sin(xy^2) + (xcos(xy^2) * (y^2 + 2xy*dy/dx)) - 1/(x/y) * (1/y - x/(y^2) *dy/dx)
dy/dx = sin(xy^2) + xy^2cos(xy^2) + 2x^2ycos(xy^2)dy/dx - (1/y)/(x/y) + (x/y^2)/(x/y) * dy/dx
thus
dy/dx = (-sin(xy^2) - xy^2cos(xy^2) +1/x) / (2x^ycos(xy^2) + 1/y - 1)
b)
dy/dx = (dy/da) / (dx/da)
= 2sec(a)tan(a) / -3sin(a)
using tan(a) = sin(a) / cos(a), and sec(a) = 1/cos(a)
dy/dx = -(2/3) * 1/cos(a) * sin(a)/cos(a) * 1/sin(a)
= -(2/3) * (1/cos^2(a))
so for a = pi/3
dy/dx = -(2/3) * (1/ (.5^2))
= -(2/3) * 4
= -2 2/3
There might be some sign mistakes lurking in there that I didn't catch, but your general procedure is sound.
At b), why not just use:
[tex]\cos(a)=\frac{x}{3}\to\sec(a)=\frac{3}{x}\to{y}=\frac{6}{x}\to\frac{dy}{dx}=-\frac{6}{x^{2}}[/tex]
Then, a=pi/3 implies x=3/2, whereby [tex]\frac{dy}{dx}=-\frac{8}{3}[/tex]
1. What is differentiation?
Differentiation is the process of finding the rate of change of a quantity with respect to another quantity. In mathematics, it refers to finding the derivative of a function.
2. Why is differentiation important?
Differentiation is important because it helps us understand how a quantity changes over time or with respect to another quantity. This is useful in many fields such as physics, economics, and engineering where understanding rates of change is crucial.
3. What are the different types of differentiation?
The two main types of differentiation are implicit differentiation and explicit differentiation. Implicit differentiation involves finding the derivative of a function that is not explicitly written in terms of one variable. Explicit differentiation involves finding the derivative of a function that is explicitly written in terms of one variable.
4. How is differentiation related to integration?
Differentiation and integration are inverse operations of each other. This means that differentiation is the process of finding the rate of change, while integration is the process of finding the original function given its derivative.
5. What are some real-life applications of differentiation?
Differentiation is used in many real-life applications, such as calculating the velocity of an object, finding the slope of a curve, determining the optimum production level in economics, and predicting population growth in biology. It is also used in fields like machine learning and data analysis to understand patterns and make predictions.
