Difficult integral
44
##\displaystyle \int_0^{\infty} \frac{\log (x+1)}{x(x+1)} dx##
I tried to convert the log to a series, but that got be nowhere, since the resulting integral was divergent. Any hints on how to approach this?
Answers and Replies
Ray Vickson
Dearly Missed
10,706
1,722
The indefinite integral can be expressed in terms of the non-elementary function ##\text{dilog}(\cdot)##, defined as
$$\text{dilog}(w) = \int_1^w \frac{\ln t}{1-t} \, dt $$
Some progress stems from integration by parts, using
$$u = \log(x+1) \;\;\text{and} \;\; dv = \frac{dx}{x(x+1)} $$
Likes jim mcnamara and lurflurf
lurflurf
2,445
140
hint find for ##k+k^\ast>-2##
##\int_0^\infty \log(x+1)(x+1)^{-k-2} dx##
then use geometric series
$$I=\int_0^\infty \frac{log(x+1)}{x(x+1)}dx\\
=\int_0^\infty \frac{log(x+1)}{[(x+1)-1](x+1)}dx\\
=\int_0^\infty \frac{log(x+1)}{[1-1/(x+1)](x+1)^2}dx\\
=\sum_{k=0}^\infty \int_0^\infty \log(x+1)(x+1)^{-k-2} dx $$
lurflurf
2,445
140
Your way is better than mine, but it helps to change variables.
let u=x/(x+1)
\int_0^\infty \frac{\log(x+1)}{x(x+1)}dx=\int_0^1 -\log(1-u)\frac{du}{u}
now expand in series.
I guess the two ways are similar, my way has an easy integral that looks hard and an easy series expansion that looks easy, your way has an easy integral that looks easy and an easy series expansion that looks hard. That was a fun integral.
Likes Mr Davis 97
lurflurf
2,445
140
https://en.wikipedia.org/wiki/Polylogarithm
That is nice. The change of variable t=1/(x+1) puts the given integral in the desired form. If we know in your notation (notation varies) ##\mathrm{dilog}(0)## we are done, otherwise we can use dilog identities or expand the logarithm in series as suggested. I was confused about the integration by parts at first I tried something similar and got stuck. Now I see the change of variable and integration by parts are equivalent. That is pretty weird.
Ray Vickson
Dearly Missed
10,706
1,722
There is a wealth of material about the dilog (and other polylog functions), including values at some special arguments and the like. That allows the proposed definite integral to be performed in terms of known functions and their values, but whether the OP would be permitted to just go ahead and use those tabulated results is, or course, another matter entirely.
44
let u=x/(x+1)
This way allowed me to solve it. Where did you come up with the substitution ##\displaystyle u=\frac{x}{x+1}## though?
lurflurf
2,445
140
^As you point out we need to do something about the convergence.
Taking the reciprocal helps this.
Another idea would have been to split the domain and use different series
for each but I wanted to avoid that.
I had expanding log(1-x) in mind, though using log(x) like Ray Vickson did worked also.
##dI=\frac{\log(x+1)}{x(x+1)}dx\\
=-\frac{\log(\frac{1}{x+1})}{x(x+1)}dx\\
=-\frac{\log(1+\frac{1}{x+1}-\frac{x+1}{x+1})}{x(x+1)}dx\\
=-\frac{\log(1-\frac{x}{x+1})}{\frac{x}{x+1}(x+1)^2}(x+1)^2d\left(\frac{x}{x+1}\right)##
vela
Staff Emeritus
Education Advisor
15,445
2,070
You could also use the substitution ##x = e^u-1## and then expand the integrand in powers of ##e^{-u}##.
Related Threads on Difficult integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
