Difficult Integration
  1. Dec 4, 2014 #1
    ##(e^y + 1)^2 e^{-y} dx + (e^x + 1)^3 e^{-x} dy = 0##
    2. Relevant equations
    3. The attempt at a solution
    ##(e^{2y} + 2 e^y + 1) e^{-y} dx + (e^{3x} + 3e^{2x} + 3e^x + 1) e^{-x} dy = 0##
    ##(e^{2y - y} + 2 e^{y - y} + e^{-y}) dx + (e^{3x - x} + 3e^{2x - x} + 3e^{x - x} + e^{-x}) dy = 0##
    ##(e^{y} + 2 e^{0} + e^{-y}) dx + (e^{2x} + 3e^{x} + 3e^{0} + e^{-x}) dy = 0##
    ##(e^{y} + 2 (1) + e^{-y}) dx + (e^{2x} + 3e^{x} + 3 (1) + e^{-x}) dy = 0##
    ##(e^{y} + 2 + e^{-y}) dx + (e^{2x} + 3e^{x} + 3 + e^{-x}) dy = 0##
    ##(e^{y} + e^{-y} + 2) dx + (e^{2x} + 3e^{x} + e^{-x} + 3) dy = 0##
    ##(e^{2x} + 3e^{x} + e^{-x} + 3) dy = - (e^{y} + e^{-y} + 2) dx##
    ## - \frac{1}{e^{y} + e^{-y} + 2} dy = \frac{1}{e^{2x} + 3e^{x} + e^{-x} + 3} dx##
    ## - \int \frac{1}{e^{y} + e^{-y} + 2} dy = \int \frac{1}{e^{2x} + 3e^{x} + e^{-x} + 3} dx##
    It is a difficult integration. What next?
  3. Dec 4, 2014 #2
    ShayanJ
    The only thing that I can see here is [itex] \frac{1}{e^y+e^{-y}+2}=\frac 1 4 \sec^2 \frac y 2[/itex].
  4. Dec 4, 2014 #3
    haruspex
    You mean sech(), right?
  5. Dec 4, 2014 #4
    How do you get ##\frac{1}{e^y+e^{-y}+2}=\frac 1 4 \sec^2 \frac y 2##?
    I know that ##sech \ x = \frac{2}{e^x + e^{-x}}##.
  6. Dec 4, 2014 #5
    ShayanJ
    Sorry...Yeah, I meant the hyperbolic thing!
  7. Dec 4, 2014 #6
    I know that ##sech \ y = \frac{2}{e^y + e^{-y}}##.
  8. Dec 4, 2014 #7
    ShayanJ
    [itex] sech x=\frac{2}{e^x+e^{-x}} -^{x=\frac{y}{2}}\rightarrow sech \frac y 2=\frac{2}{e^{\frac y 2}+e^{-\frac y 2}} \rightarrow sech^2 \frac y 2=\frac{4}{e^{y}+e^{-y}+2} [/itex]
  9. Dec 4, 2014 #8
    Why ##sech \ x = \frac{2}{e^x + e^{-x}} - x##?
    And why it equal to ##\frac{y}{2}##?
    The correct one is ##sech \ x = \frac{2}{e^x + e^{-x}}##, not ##\frac{2}{e^x + e^{-x}} - x##.
    What this -x variable mean?
  10. Dec 4, 2014 #9
    ShayanJ
    Oh...I meant to be a little fancy but looks like it was a bad idea. I meant take [itex]sech x=\frac{2}{e^x+e^{-x}}[/itex] and then set [itex] x=\frac y 2 [/itex].
  11. Dec 4, 2014 #10
    You said ##sech \ \frac{y}{2} = \frac{2}{e^{\frac{y}{2}} + e^{-\frac{y}{2}}}##
    ##= \frac{2}{e^{\frac{y}{2}} + \frac{1}{e^{\frac{y}{2}}}}##
    ##= \frac{2}{\frac{(e^{\frac{y}{2}})^2 + 1}{e^{\frac{y}{2}}}}##
    ##=\frac{2 e^{\frac{y}{2}}}{(e^{\frac{y}{2}})^2 + 1}##
    ##=\frac{2 e^{\frac{y}{2}}}{(e^{\frac{y}{2}}. \ e^{\frac{y}{2}}) + 1}##
    ##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{y}{2} + \frac{y}{2}} + 1}##
    ##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{y + y}{2}} + 1}##
    ##=\frac{2 e^{\frac{y}{2}}}{e^{\frac{2y}{2}} + 1}##
    ##=\frac{2 e^{\frac{y}{2}}}{e^{y} + 1}##
    Please explain. I am really confuse.
  12. Dec 4, 2014 #11
    epenguin
    When you write this
    exdx/(ex + 1)3 = - eydy/(ey + 1)2
    isn't each side easily recognised as derivative of something?
  13. Dec 4, 2014 #12
    vela
    Staff Emeritus
    Education Advisor
    Or if you don't recognize the derivatives, try the obvious substitutions.
  14. Dec 5, 2014 #13
    I still don't get it. Give me more clue please.
  15. Dec 5, 2014 #14
    Mark44
    Staff: Mentor
    Vela gave you a clue in post #12. Try it.
  16. Dec 5, 2014 #15
    ##\frac{e^x dx}{(e^x + 1)^3} = \frac{-e^y dy}{(e^y + 1)^2}##
    I shall integrate the left side (the x variable) first. If using the substitution method, which one should be substituted?
    Let ##u = e^x## or ##u = e^x + 1##?
  17. Dec 5, 2014 #16
    Mark44
    Staff: Mentor
    Try them both. You should see that one is slightly better than the other.
  18. Dec 5, 2014 #17
    (1)
    Let ##u = e^x + 1## then ##\frac{du}{dx} = e^x## or ##du = e^x dx##
    ##\int \frac{e^x dx}{(e^x + 1)^3}##
    ##= \int \frac{1}{u^3}du##
    ##= \ln |u^3| + c##
    ##= \ln (e^x + 1)^3 + c##
    (2)
    Let ##u = e^y + 1## then ##\frac{du}{dy} = e^y## or ##du = e^y dy##
    ##\int \frac{-e^y dy}{(e^y + 1)^2}##
    ##= - \int \frac{e^y dy}{(e^y + 1)^2}##
    ##= - \int \frac{1}{u^2}du##
    ##= - \ln |u^2| + c##
    ##= - \ln (e^y + 1)^2 + c##
    From (1) and (2), I get:
    ##\int \frac{e^x dx}{(e^x + 1)^3} = \int \frac{-e^y dy}{(e^y + 1)^2}##
    ##\ln (e^x + 1)^3 + c = - \ln (e^y + 1)^2 + c##
    Is it correct?
  19. Dec 5, 2014 #18
    Zondrina
    That is certainly not correct. What is:
    $$\int u^{-3} \space du$$
  20. Dec 5, 2014 #19
    Mark44
    Staff: Mentor
    Good catch, Zondrina. I totally missed that he was using this integration "rule" (in quotes because it's not an integration rule):
    ##\int \frac{dx}{f(x)} = ln|f(x)| + C##
  21. Dec 5, 2014 #20
    Thank you for the correction.
    Let I correct the mistake:
    (1)
    ##= \int u^{-3} du##
    ##= \frac{1}{-3+1}u^{-3+1} + c##
    ##= \frac{1}{-2}u^{-2} + c##
    ##= - \frac{1}{2}(e^x + 1)^{-2} + c##
    (2)
    ##= - \int u^{-2} du##
    ##= - \frac{1}{-2+1} u^{-2+1} + c##
    ##= - \frac{1}{-1} u^{-1} + c##
    ##= u^{-1} + c##
    ##= (e^y + 1)^{-1} + c##
    ##- \frac{1}{2}(e^x + 1)^{-2} + c = (e^y + 1)^{-1} + c##
    Is it correct?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Difficult Integration
  1. Difficult integral (Replies: 4)
  2. Difficult Integral (Replies: 10)
  3. Difficult Integral (Replies: 31)
  4. Difficult integral (Replies: 7)
  5. Difficult integral. (Replies: 5)
Loading...
