Difficult rearranging problem
I have a math problem that I cannot wrap my head around. Maybe there is no easy answer but I thought I would ask for some help.
So first the equation:
AOI = cos-1 {cos(Tm) cos(Zs)+sin(Tm) sin(Zs) cos(AZs-AZm)}
Where:
AOI = solar angle of incidence (deg)
Tm = tilt angle of module (deg) (0deg is horizontal)
Zs = zenith angle of sun (deg)
AZm = azimuth angle of module (0deg = North, 90deg= East)
AZs = azimuth angle of sun (0deg= North, 90deg= East)
*Note that the -1 beside the cos means "ACOS" not "COS to the power of -1"
So my problem is that for a given sun postion (Zs, AZs), I want to know the best combination of Tm and AZm to give me the lowest possible value for AOI.
I calculate Tm based on AZm with the formula:
Tm = AZm x .5
I know that I need to substitute AZm x .5 for all the Tm’s in the original equation but I cannot seem to rearrange it to isolate AZm onto one side. I fear my lack of trig identity knowledge is what is preventing me from solving. I would appreciate any help or guidance anyone could give. Even just a hint.
Thanks!
Answers and Replies
tiny-tim
25,836
251
welcome to pf!
hi drogerssolar! welcome to pf! :smile:
(try using the X2 icon just above the Reply box :wink:)
Tm = AZm x .5
is the aim to minimise cos-1{cos(Tm) cos(Zs)+sin(Tm) sin(Zs) cos(AZs-AZm)} ?
(btw, that's the same as maximising what's inside the {})
can't you do it by finding the derivative?​
Well my calculus is a bit rusty I was able to find the derivative (I think). So first I made AZm a function of Tm (Tm/.5). I also am looking just inside the brackets of the ACOS.
So my starting equation looked like this:
(cos(Tm)*cos(Zs))+(sin(Tm)*sin(Zs)*cos(AZs-(Tm/.5)))
The derivative I ended with was:
f'x = 2*sin(Tm)*sin(Zs)*sin(AZs-2*Tm)+cos(Tm)*sin(Zs)*cos(AZs-2*Tm)-sin(Tm)*cos(Zs)
So with this derivative I assume I want to make f'x = 1 in order to obtain the minimum value of AOI?
tiny-tim
25,836
251
hi drogerssolar! :smile:
what's "x" ? :confused:
yes that's the correct value for ∂f/∂(Tm) :smile:
but don't you also need ∂f/∂(Zs)?
and no, you need f' = zero for a maximum or minimum, don't you? :wink:
Thanks for the help Tim. This is a good refresher for my brain. Once I figure this all out I will get write back with the correct answer. You have pointed me in the right direction. Thank you :)
So if I make ∂f/∂(Tm)=0
and I make ∂f/∂(Zs)=0
That means ∂f/∂(Tm)=∂f/∂(Zs)?
and then I just rearrange the get Tm on one side plug in my value for Zs and solve.
Am I on the right track here?
Thanks again Tim!
tiny-tim
25,836
251
hi drogerssolar! :wink:
and I make ∂f/∂(Zs)=0 …
these are two separate equations,
you can solve them quite separately (which is easier) :smile:
Tim,
I may require a little more guidance if you don't mind. I have a slightly different equation than I had in the previous posts as my initial equation was not correct. I have determined that:
y=(cos(35)*cos(x)*cos(25))+(sin(acos(cos(35)*cos(x)))*sin(25)*cos(180-(acos(atan(sin(x)/tan(35))*cos(x)))))
Where:
Y = Angle of incidence
X= Degrees of Rotation (around panel axis)
I was not able to take the derivative myself; however, with the help of a derivative solving web page I ended up with a rather large derivative. So large in fact that I cannot possible type it out so I will save it as an image and attach it to this post.
Now I know I have to set the derivative equal to zero and solve for X.
My question:
Is there anyway to shrink this equation down to something a little more manageable? Is it even solvable?
Thanks again for any help you can provide.
Regards,
Dan
tiny-tim
25,836
251
erm …
thumbnail totally unreadable :redface:
Sorry Tim,
I just realized when I uploaded, the file size was shrunk way too much. Let me see if I can ZIP the original and attach it. The only other way would be to go to:
http://www.numberempire.com/derivatives.php
and copy and paste the following into the form:
(cos(35)*cos(x)*cos(25))+(sin(acos(cos(35)*cos(x )))*sin(25)*cos(180-(acos(atan(sin(x)/tan(35))*cos(x)))))
I have a feeling I might need to help of some math software like Mathematica or MatLab to rearrange such a large derivative.
  • Axis Tilt Derivitive.zip
Related Threads on Difficult rearranging problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
