• Support PF! Buy your school textbooks, materials and every day products Here!
Difficult units conversion
  • Thread starter matteo86bo
I need to infer the observed star formation efficiency of the Kennicutt Schimdt law starting from a volumetric SF law.
The KS law is a relationship between gas and stellar surface density that we can approximate as:
[itex]\frac{d\Sigma_*}{dt}=A\Sigma_{gas}^{1.5}[/itex]
Where [itex]A[/itex] is the efficiency and its values is roughly 2.5e-4 when [itex]\frac{d\Sigma_*}{dt}[/itex] is measured in [itex]M_\odot kpc^{-2} yr^{-1}[/itex] and [itex]\Sigma_{gas}[/itex] in [itex] M_\odot pc^{-2}[/itex].
Now the problem is I want to derive this efficiency starting from this formula
[itex]\frac{d\rho_*}{dt}=B\frac{\rho_{gas}}{t_{ff}}[/itex]
where [itex] {t_{ff}}[/itex] is the free-falling time and is equal to
[itex] {t_{ff}}=\sqrt{\frac{3}{32\pi G \rho_{gas}}}[/itex]
I need to compute B and then convert it in the same units of the Kennicutt Schimdt law.
2. The attempt at a solution
Since the Kennicutt law involes surface density I have multiplied both sides of the volumetric equation by a characteristic scale length [itex]\Delta x[/itex].
Therefore B should be equal to:
[itex]\sqrt{\frac{32\pi G}{3}} \Delta x[/itex]
The things is I had to convert this number from cgs units to the units in which the Kennicutt law is given but I don't get the same order of magnitude. Can you help me?
Answers and Replies
Chi Meson
1,789
I gave this a shot, but it turns out I'm less able than you are at solving this. I would re-post this question in the Advanced forum if no one else here helps you soon.
dynamicsolo
1,648
Let's see if the units are making sense first:
For [itex]\frac{d\rho_*}{dt}=B\frac{\rho_{gas}}{t_{ff}}[/itex] ,
we have [itex]M_\odot pc^{-3} yr^{-1}[/itex] on the left and
B times [itex]M_\odot pc^{-3}[/itex] divided by years on the right , so B should be dimensionless, no? (I'm taking it that the rho's are volume densities.)
So I don't think [itex]B = \sqrt{\frac{32\pi G}{3}} \Delta x[/itex] can be right.
(And A has units of [itex] \frac{pc }{ M_\odot^{1/2}\cdot yr} [/itex] ,yes? )
Related Threads on Difficult units conversion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
