1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Diffraction grating problem
  1. Jan 30, 2006 #1
    Hey
    Here is the problem, I think I may be stuck but I'll provide all the information I have so far.
    White light (400-700nm) is incident on a 600 line/mm diffraction grating. What is the width of the first order rainbow on a screen 2.0m behind the grating?
    What I figured was to use the equation d*sin(theta) = m * wavelength
    as well as the equation y = L*tan(theta), with L = 2.0m, m = 1 (first order rainbow),
    Basically, I have to find theta, then find y, which ends up being the width of my projected rainbow. I am, however, totally stuck at this point. I'm not even sure if my assumption that m = 1 is right, or if I am on the right path.
    Any help in the right direction would be awesome.
    Thank you
    twiztidmxcn
  3. Jan 30, 2006 #2
    This is probably not the best way, but the way that I would do that is to find theta when the wavelength is 400 nm, and then do the same to find the angle when the wavelength is 700 nm, then use a little trig and the difference between the angles to calculate the width of the spectrum.
    calculate the angles by using
    [tex]n\lambda = dsin\theta[/tex] (n = 1, d = distance between the slits).
  4. Jan 30, 2006 #3
    ok, i had already used that equation for both and found
    theta @ 400nm = 13.9 degrees
    theta @ 700nm = 24.8 degrees
    using the idea of finding the angle difference (10.9 degrees), then using trig we find that tan(theta) = y / x, y = tan (theta) * x, where x = 2m and theta is the angle difference that i calculated?
    thus leaving me with something like y = 2m * tan (10.9) = .385m?
  5. Jan 30, 2006 #4
    jtbell
    Staff: Mentor
    The difference between the angles doesn't help you here because [itex]\tan{\theta_2} - \tan{\theta_1}[/itex] does not equal [itex]\tan (\theta_2 - \theta_1)[/itex].
  6. Jan 30, 2006 #5
    I think I get what you mean
    It makes more sense with that explanation, and helps me to reason that since x*tan(theta) = y, y2 - y1 = x(tan(theta2)-tan(theta1)).
    What you were saying is to use the difference of lengths rather than angle because... well of what you said.
Similar Discussions: Diffraction grating problem
Loading...
