Homework Help: Diffraction of X rays
  1. Sep 26, 2008 #1
    Problem:
    Diffraction of X rays has been observed when a beam strikes an extremely fine slit. What must be the width if the slit if X rays of wavelength 10A are to display a diffraction pattern with a central beam of angular width 0.1?
    I used Bragg's equation to obtain:
    d=n(lambda)/2sin(theta)
    d=1*10A/2sin(0.1)=2864.8A= 246.48nm?
    Is this correct?
  3. Sep 26, 2008 #2
    alphysicist
    Hi Quelsita,
    I don't believe you are using the correct equation here. Bragg's law describes diffraction by a crystal; here the process is single slit diffraction. What equation would describe that?
  4. Sep 26, 2008 #3
    Could you use the grating equation d[sin(thetam)+sin(thetai)]=m(lambda)?
    But what is thetamax?
  5. Sep 26, 2008 #4
    alphysicist
    I think you should use the single slit diffraction equation. The equation for the minima is
    [tex]
    a\ \sin\theta =m\lambda
    [/tex]
    I would think that your book has at least a section on single slit diffraction, so it can tell you how to apply this to your problem. What do you get?
