Digital design bcd counter some assistance
  1. Dec 3, 2011 #1
    hey yal'....so i was doing a bcd down counter, but I couldn't get it to run as i intended it to. The testbench gives me no results. Can someone help me debug it, please?
    Here's my code:
    -- Company:
    -- Engineer:
    -- Create Date: 18:29:02 12/01/2011
    -- Design Name:
    -- Module Name: bcd_example - Behavioral
    -- Project Name:
    -- Target Devices:
    -- Tool versions:
    -- Description:
    -- Dependencies:
    -- Revision:
    -- Revision 0.01 - File Created
    -- Additional Comments:
    library IEEE;
    use IEEE.STD_LOGIC_1164.ALL;
    use IEEE.STD_LOGIC_ARITH.ALL;
    use IEEE.STD_LOGIC_UNSIGNED.ALL;
    -- Uncomment the following library declaration if using
    -- arithmetic functions with Signed or Unsigned values
    --use IEEE.NUMERIC_STD.ALL;
    -- Uncomment the following library declaration if instantiating
    -- any Xilinx primitives in this code.
    --library UNISIM;
    --use UNISIM.VComponents.all;
    entity bcd_example is
    Port ( --data_in: in STD_LOGIC_VECTOR( 7 downto 0);
    -- load: in std_logic;
    start : in STD_LOGIC;
    --pause: in STD_LOGIC;
    clk : in STD_LOGIC;
    reset : in STD_LOGIC;
    bcd_output : out STD_LOGIC_VECTOR (7 downto 0));
    end bcd_example;
    architecture Behavioral of bcd_example is
    signal bcd_counter: std_logic_vector(7 downto 0);
    begin
    process(reset, clk, start)
    begin
    if (reset = '1') then
    bcd_counter <= (others => '0');
    elsif(clk'event and clk = '1') then
    if( start = '1' ) then
    bcd_counter <= "01011001";
    bcd_counter <= bcd_counter - 1;--count down
    if(bcd_counter = x"00") then
    bcd_counter <= bcd_counter;--hold value
    elsif(bcd_counter(3 downto 0) = "0000") then--once it reaches 0000 then switch to 1001
    bcd_counter(3 downto 0) <= "1001";
    bcd_counter(7 downto 4) <= bcd_counter(7 downto 4) - 1;--meanwhile keep decrementing our first four bits (MSB's)
    end if;
    end if;
    end if;
    end process;a
    bcd_output <= bcd_counter;
    end Behavioral;
