Kinematics of Relativity: Deriving Dilation Time
In summary, David Morin explains that dilation time in Special Relativity is derived by assuming that light speed is absolute for all inertial reference frames. By comparing two reference frames, A on a moving train and B on the ground, he derived the formula tB=\gamma tA, which is commonly used. While the derivation uses a 'light clock' oriented transverse to the train's motion, the behavior of a light clock does not depend on its orientation.
gema
I'm about to ask derivation of dilation time in terms of Special Relativity.
I saw explanations in Introduction to Classical Mechanics by David Morin that dilation time is formed by assumption that light speed is absolute refers to all inertial reference. He derived it by comparing 2 reference; A who sitting on the train with constant speed v refers to the ground, and B who at rest on the ground. They are to see the light traveling on the train, which has long h.
He got that A's time to see the light traveling from end to end , in transverse direction of light traveling, of the train is tA=2h/c
And B's time to see the light traveling on the train tB=2h/(c^2-v^2)^1/2, by simply using pythagoras.
Then, he got that tB=[itex]\gamma[/itex]tA, and this formula is generally used.
My question, How can this formula be general, since this are just derived by assuming that train is traveling in transverse direction of light speed.
The 'light clock' is oriented transverse to the direction of train travel just to make the derivation easy. Of course, the behavior of a light clock does not depend on its orientation.
(If you put the light clock parallel to the direction of motion, you'd have to worry about length contraction when analyzing it from another frame.)
What is the theory of relativity?
The theory of relativity is a scientific theory developed by Albert Einstein in the early 20th century. It describes the relationship between space and time and how they are affected by the presence of massive objects.
What is kinematics of relativity?
Kinematics of relativity is a branch of physics that deals with the motion of objects in relation to the theory of relativity. It explains how the laws of motion change when an object is moving at high speeds or in the presence of strong gravitational fields.
How is time dilation derived in the theory of relativity?
Time dilation is derived from the principles of the theory of relativity, specifically the theory of special relativity. According to this theory, time is relative and can be influenced by factors such as velocity and gravity. The formula for time dilation is t' = t√(1-v^2/c^2), where t' is the time measured by an observer in motion, t is the time measured by a stationary observer, v is the velocity of the moving object, and c is the speed of light.
What is the significance of time dilation in the theory of relativity?
Time dilation is significant because it explains how time passes differently for observers in different frames of reference. This concept has been confirmed through various experiments and has important implications for space travel and our understanding of the universe.
How does time dilation affect the measurement of time?
Time dilation affects the measurement of time by showing that time is not absolute and can vary depending on the observer's frame of reference. This means that time can pass at a different rate for someone who is moving at high speeds compared to someone who is stationary. It also means that time can be affected by gravity, with time passing slower in stronger gravitational fields.
