Dimension of matrices problems
In summary, the given conversation discusses how to solve questions involving matrices. It includes a specific example of two matrices A and B, where B is the reduced row echelon form of A. The conversation also covers various questions related to the rank, basis, dimension, and linear independence of the rows and columns of A. Ultimately, the main question is whether three given vectors can span R^3, and the answer is derived by examining the dimension of the column space and the definition of spanning a subspace.
Benny
584
I'm having trouble with some matrices questions, can someone please help me?
[tex]
A = \left[ {\begin{array}{*{20}c}
1 & 2 & 3 & 1 \\
2 & 4 & 8 & { - 2} \\
{ - 5} & { - 10} & { - 19} & 3 \\
\end{array}} \right]
[/tex]
[tex]
B = \left[ {\begin{array}{*{20}c}
1 & 2 & 0 & 7 \\
0 & 0 & 1 & { - 2} \\
0 & 0 & 0 & 0 \\
[/tex]
B is the row reduced echelon form of the matrix A.
a) What is the rank of A.
2.
b) What down a basis for the column space of A.
{(1,2,-5),(3,8,-19)}
c) Find the dimension of the row space of A.
2.
d) Are the rows of A linearly independent? Explain your answer.
No, rank(row space) > dimension(row space).
e) Do the vectors (1,2,-5), (3,8,-19) and (1,-2,3) span R^3?
The answer says something along the lines of "The 3 vectors are in the column space of A which has dim=2. This implies that the 3 vectors span a subspace with dim <= 2. So they do not span R^3."
I'm not completely about how to get to the answer. I know that dim(R^3) = 3 but I don't see why the 3 vectors span a subspace which has dimension less than or equal to 2. Further, I can't understand why it follows that they cannot span a subspace greater than 2.
Because I don't understand this and also due to the fact people seem to prefer seeing an attempt from the OP I will try to explain what I have tried. I wasn't really sure about this question from the beginning so I went back to the definitions.
A set of vectors T spans a subspace of R^m, S, if every vector in S can be written as a linear combination of T(I think:D). In this case the set S is R^3 and T is the set of the 3 given vectors. So yes, I think I could just let v = (x,y,z) to be an arbitrary vector in R^3, equate coefficients, write the corresponding augmented matrix and deduce the answer. However, the way that the question is set out and the way that the answer is phrased suggests that I do not need to do that.
In any case, looking at the answer I see that there is a mention of the dimension of the column space of A, which is equal to the rank of A. Ok well at this point I'm just confusing myself and its getting late so I'm finding it hard to think. So could someone please provide me with some assistance.
How does that prove the rows are linearly dependent?
Anyways, that's not right -- the (row) rank is defined to be the dimension of the row space.
Think about this once you've awakened and have a clear head!
I made a mistake in typing up the answer to part d. I don't know what I was thinking.
Anyway, the answer(to part d) I've got with me is: Number of rows in A = 3 > dim(row space) = 2. This implies rows of A are not linearly independent.
I'm pretty sure I've figured out why the answer is the way that it is. There's a theorem in my book related to this question. The question as a whole seems quite nit picky.
As for part 'e' I'm not sure about it but the answer seems right. The dimension of R^3 is 3. But why does it follow that the since the vectors {(1,2,-5),(3,8,-19),(1,-2,3)} are in the column space of A, with has dimension 2, then the 3 vectors span a subspace with dimension less than or equal to 2?
For those 3 vectors to span a subspace(call it S) then every vector in S can be written as a linear combination of the 3 vectors. Oh wait, that's why they span a subspace of dimension less than or equal to 2.
One way to look at this is that the row reduction from A to B tells you that the rows of A are not linearly independent. You can think of the rows of A as being three vectors in 4-space, but clearly all three of those vectors can be written as linear combinations of the two non-zero row vectors in B. If you lablel the row vectors as A1, A2, A3, A4, B1, B2 then
A1 = B1 + 3B2
A2 = 2B1 + 8B2
A3 = -5B1 - 19B2
Since there are only two independent vectors in the 4-space, they span a 2 dimensional sub-space. Matrix A has 4 column vectors. The first two are clearly dependent by inspection, with the second being twice the first. That leaves the three vectors of part e) as potentially independent. You can show that they are not independent by forming a row matrix from those three vectors and performing a row echelon reduction (could also be done directly as columns of course, but the calculator likes rows)
[tex] C = \left[ {\begin{array}{*{20}c} 1 & 2 & {-5} \\ 3 & 8 & {-19} \\ 1 & {-2} & 3 \\\end{array}} \right][/tex]
which has the row reduced echelon form
[tex] D = \left[ {\begin{array}{*{20}c} 1 & 0 & {-1} \\ 0 & 1 & {-2} \\ 0 & 0 & 0 \\\end{array}} \right][/tex]
with
C1 = D1 + 2D2
C2 = 3D1 + 8D2
C2 = D1 - 2D2
If you transpose matrix D, the first two columns are a pair of independent vectors in 3-space that span the 2-dimensional subspace that contains all 4 of the column vectors of the original matrix A.
I'm sure the theorems are fresher in your mind than in mine, but one of them says something like the number of independent rows and the number of independent columns is always the same and is called the rank of the matrix.
Thanks for your detailed response OlderDan, I'll need to spend some time later on to go over it. For part 'e' I can think of a way longer method to get to the answer but the question is structured so that I don't need to do it that way, so I thought, why not take advantage of it?Thanks again for you help.
1. What is the dimension of a matrix?
The dimension of a matrix refers to the number of rows and columns it has. It is written in the form of "m x n", where m represents the number of rows and n represents the number of columns.
2. How do you determine the dimension of a matrix?
To determine the dimension of a matrix, you simply count the number of rows and columns. For example, if a matrix has 3 rows and 4 columns, its dimension would be 3 x 4.
3. Can the dimension of a matrix be different for different matrices?
Yes, the dimension of a matrix can vary depending on the number of rows and columns. Some matrices may have the same number of rows and columns, while others may have different numbers.
4. What is the importance of knowing the dimension of a matrix?
Knowing the dimension of a matrix is important because it helps determine the size and shape of the matrix. It also helps in performing operations on matrices, such as addition, subtraction, and multiplication.
5. Can the dimension of a matrix change?
No, the dimension of a matrix is fixed and cannot be changed. If any operation is performed on a matrix, it may result in a new matrix with a different dimension.
  • Linear and Abstract Algebra
