Dimension of the gamma matrices in general dimension
In summary, the dimension of gamma matrices in a d dimensional space, where d is even, is m = 2^{d/2} , and for odd d, it is m = 2^{(d-1)/2} . This can be understood by the antisymmetric properties of the gamma matrices and the role of \gamma_5.
ismaili
160
Dear guys,
I read a derivation of the dimension of gamma matrices in a [tex]d[/tex] dimension space, which I don't quite understand.
First of all, in [tex]d[/tex] dimension, where [tex]d[/tex] is even.
One assumes the dimension of gamma matrices which satisfy
[tex] \{ \gamma^\mu , \gamma^\nu \} = 2\eta^{\mu\nu} \quad\quad\cdots(*)[/tex]
is [tex] m [/tex].
A general a m by m matrix with complex arguments should have [tex]2m^2[/tex] independent components.
Now, eq(*) gives [tex]m^2[/tex] constraints. (<= I don't quite understand this.)
So, the independent components of a single gamma matrix should be [tex] m^2 [/tex].
On the other hand, one finds that the anti-symmetrization of gamma matrices can produce space-time tensors under Lorentz transformation, i.e. for example,
[tex] \bar{\psi}\gamma^{\mu\nu}\psi \rightarrow \Lambda^\mu{}_\rho\Lambda^{\nu}{}_\sigma\bar{\psi}\gamma^{\rho\sigma}\psi[/tex]
where [tex] \gamma^{\mu\nu} = \gamma^{[\mu}\gamma^{\nu]}[/tex]
Now, the various antisymmetric tensors decompose the Lorentz group into different pieces which do not mix. We now calculate the independent components of each anti-symmetric tensor, and add it up:
[tex] C^d_0 + C^d_1 +C^d_2 + \cdots + C^d_d = 2^d [/tex]
Now we match the two independent components we calculated (Why?! why they should match?!)
[tex] m^2 = 2^d [/tex]
This concludes that [tex] m = 2^{d/2} [/tex].
Now, for d = 2k+1 being odd, one can easily add [tex]\gamma^{2k} \sim \gamma^0\gamma^1\cdots\gamma^{2k-1}[/tex], together with the original [tex]\gamma^0,\gamma^1,\cdots,\gamma^{2k-1}[/tex] to form gamma matrices in d = 2k+1.
Since the anti-symmetric tensors has a linear relation,
[tex]\gamma^{\mu_0\mu_1\cdots\mu_r} = \epsilon^{\mu_0\mu_1\cdots\mu_{2k}}\gamma_{\mu_{r+1}\cdots\mu_{2k}}[/tex].
So there are actually [tex] 2^{d}/2 [/tex] independent components for odd [tex]d[/tex].
Hence, the dimension of gamma matrices in odd spacetime dimension should be [tex]2^{\frac{d-1}{2}}[/tex].
My question is that, isn't the linear relation between anti-symmetric tensors also hold in d = even spacetime dimension?
Anyone help me go through the puzzles? thanks so much!
ismaili
Oh, by the way, I found that from the Dirac representation method which I described in another nearby thread titled "spinors in various dimensions", one can easily realize the dimension of gamma matrices in even dimension d should be [tex] 2^{d/2} [/tex].
I think you are trying to do this the hard way: by brute force. There are several really cute and powerful theorems that help a lot on the way. I really recommend that you take a look at Appendix-L, in the book "Group Theory in Physics, Volume-II, by J.F. Cornwell", published by Academic Press in 1984. It may or may not be out of print these days, but I am sure you can find it in a library if it is out of print.
In this appendix which is only 25 pages or so, Cornwell does better than most books do in a 100 pages on the application of Clifford Algebras to Physics. The theorems are provided, many are actually proven on the way, including the ones you need. Where needed, he also provides good physical insight. I hope it will be helpful to you.
bigubau said:
Hello, I have the second volume from the 1984 edition. There's no "Appendix L". The last one is <J>. I think it's in the 3rd volume, namely this one: https://www.amazon.com/dp/0121898067/?tag=pfamazon01-20
My bad, you are right, it is the third volume, not the second. Appendix-L starts on page 475.
ismaili said:
Dear guys,
is [tex] m [/tex].
ismaili
I reconsidered this recently.
I think for my first question, the reason that reduces the independent components [tex]2m^2[/tex] into [tex]m^2[/tex] is the (anti-)hermitian properties of the gamma matrices, not the Clifford algebra. Then, the antisymmetrized products of gamma matrices form a basis for the algebra, hence, by matching independent components [tex]m^2[/tex] and the number of basis [tex]2^d[/tex], we see that [tex] m = 2^{d/2} [/tex] for even dimension [tex]d[/tex].
The solution to the second equation is due to the role of [tex]\gamma_5[/tex].
That's why only in odd dimension, those basis are related by Levi-Civita tensor,
and the number of basis is reduced to [tex]2^{(d-1)/2} [/tex] for odd [tex] d [/tex].
For your information.
I found this reference which deals with Clifford algebra in a mathematical rigorous way.
http://arxiv.org/abs/hep-th/9811101
But at least those [tex]B,C[/tex] matrices are not suddenly popped.
1. What are gamma matrices?
Gamma matrices are a set of mathematical objects used in the field of quantum mechanics to represent the Dirac equation. They are a generalization of the Pauli matrices and are used to describe spinor fields in different dimensions.
2. How many gamma matrices are there in general dimension?
In general dimension, there are n gamma matrices, where n represents the dimension of the space. For example, in 3-dimensional space, there would be 3 gamma matrices. In 4-dimensional space, there would be 4 gamma matrices, and so on.
3. What is the significance of the dimension of the gamma matrices?
The dimension of the gamma matrices is important because it determines the number of spinor components needed to describe a fermion field in that particular dimension. It also affects the properties and behavior of the gamma matrices, such as their commutation and anticommutation relations.
4. Can the dimension of the gamma matrices be changed?
No, the dimension of the gamma matrices is determined by the dimension of the space in which they are being used. For example, in 3-dimensional space, there will always be 3 gamma matrices, and this cannot be changed.
5. How are the gamma matrices related to the concept of spin?
The gamma matrices are closely related to the concept of spin, as they are used to represent the spinor fields of fermions. The eigenvalues of the gamma matrices correspond to the spin states of the particles, and the manipulation of these matrices allows for the prediction of spin-related phenomena in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
