Dimensional Analysis
  • Thread starter Pajamas
Pajamas
A=B^3C^1/2 where A has the dimensions L/M and C has dimensions L/T. What are the dimensions of B?
When I worked the problem I got B=M/T but it is wrong. I'm not sure how to approach the question.
Answers and Replies
Simon Bridge
17,874
1,657
You substitute the dimensions into the equation and work out what dimenstions B has to have to make the LHS match the RHS.
Please show your working.
Pajamas
So far I have B^3=TL/M^2
L/M=B^3(L/T)^1/2
with L/T then in the square root, square both sides and get T/L*L/M^2=B^3, cancel the L on bottom and one on top to get the above answer.
Pajamas
This doesn't make a lot of sense to me since B is still B^3. Am I supposed to have it look similar to the other side with TLM?
nasu
3,957
583
L/M=B^3(L/T)^1/2
You have several errors in this.
Squaring will produce B^6. And L^2 in L/M.
Using parentheses will make the things clearer. For you as well as for the people reading your posts.
You don't need to square. Just solve for B and put the dimensions.
Simon Bridge
17,874
1,657
T/L*L/M^2=T/L^2/M^2=T/(L^2M^2) ...
Yike... you need to use brackets more to group your terms.
Use square brackets to represent when you mean "dimensions of"
[B^3]=(T/L)(L/M^2)=T/(M^2)
OK - but you need ... you've not finished.
(And - check your arithmetic.)
Suggested for: Dimensional Analysis
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
