Homework Help: Dimensional motion
  1. Sep 16, 2007 #1
    A motorists drives south at 20.0 m/s for 3.0min, then turns west and travels at 25.0m/s for 2.0min and finally travels northwest at 30.0m/s for 1.00min. For this 6.00 min trip, find:
    a)the total vector displacement
    b) the average speed
    c)the average velocity
    Let the positive x-axis point east
    2. Relevant equations
    v=deltavectorR/delta-t
    vector-v=d-vectorR/dt=dx/dt(i)+dy/dt(j)
    vectorR=vectorR(i)+vector-velocity(t)+1/2vector-at^2
    3. The attempt at a solution
    I drew a diagram, to make the problem clearer. I think t=6min xi=25.om/s. But then I have two y-components
    Thanks for your time
  3. Sep 16, 2007 #2
    learningphysics
    How did you approach part a) ?
  4. Sep 16, 2007 #3
    its displacement vector: deltavectorR=vectorR(f)-vectorR(i)
    But I dont know how to go about the final and initial displacement. I am confused
  5. Sep 17, 2007 #4
    learningphysics
    Find the displacement in the east/west direction... then the north/south direction...
    I'd write each displacement as a vector (taking i horizontally, j vertically, postive east and north):
    ie: the first part (20*3*60)
    [tex]\vec{r} = -3600\vec{j}[/tex]
    Does that make sense... same way write all 3 displacements. Then add them.
  6. Sep 17, 2007 #5
    ok, its starting to kick in. now for b): wouldnt average velocity be=my value for deltavectorr/delta t??
  7. Sep 17, 2007 #6
    learningphysics
    yes, that would be for average velocity... average speed will be different.
  8. Sep 17, 2007 #7
    OK-so if my displacement are in terms of vectors, then how in the world is b) computed. B/c the average velocity is deltaR/delta t...but my delta-displacement is going to be in vectors. how in the world am i supposed to divide vectors.
    also average speed is total distance/delta t.
  9. Sep 17, 2007 #8
    learningphysics
    You need to find the total distance travelled. then divide by time.
  10. Sep 17, 2007 #9
    for the total distance do i add the total values given? and what about average velocity?
  11. Sep 17, 2007 #10
    learningphysics
    find the distance travelled in each segment and add them up. distance is not displacement. With distance, you're ignoring direction.
    Average velocity is the total displacement/time.
    Did you calculate the displacement vectors for each section. Add up those vectors and you get the total displacement.
    For total distance, you're just adding up numbers, not vectors.
  12. Sep 17, 2007 #11
    for the average velocity, isnt my displacement in vectors, and if so then how is it divided by time? i did calculate the displacement for each section
  13. Sep 17, 2007 #12
    learningphysics
    Add up all the displacements of each section.... that gives total displacement as a vector... divide that by the total time... we can divide vectors by scalars... time is just a scalar.
  14. Sep 18, 2007 #13
    OK-Ive added my vectors, but it still hasnt given me the same answers in the book. In the book:a)4.87km at 209 degree from east
    b) 23.3 ms
    c)13.5m/s at 209
    I converted the given values into meters. for instance:{3.0min*60s/min}which then i computed 20.0m/s*180s=-3600
    This was what ive done for each one.
    then (0,-vt)=(0,-3600)
    (v2t2,-vt)= (3000, -3600)
    (v3t3)=(-2545.6,3600)
    This is the part where i get lost. for vector i=2745.4, j=-3600
    If the question asks for total vector displacement, why is the answer 4.87 at an 209 angle
    For b) my time would be 6min, but for my total length, would i total my values i converted into meters?
    AGAIN-thank you sooooo much for your patience
  15. Sep 18, 2007 #14
    learningphysics
    I don't understand your numbers... Are you getting the displacement over each section? For example... 25.0m/s west for 2.0min is a displacement of (-3000,0). How do you get (3000,-3600) ?
  16. Sep 19, 2007 #15
    those are my x and y components. im over-complicated this, arent i
