Dipole in a Dielectric: Analysis of r→0
In summary, the conversation discusses a dipole in a vacuum cavity inside an LIH dielectric, with given equations for Vin and Vout. It is mentioned that as r tends to 0, the field must approach the dipole field, and there is confusion about whether this refers to the E-field or potential. However, it is clarified that the order of differentiation does not matter and the purpose of the condition is to determine the coefficient B.
sachi
75
We have a dipole in a vacuum cavity inside an otherwise infinite LIH dielectric.
We assume form Vin = Arcos(theta) + B/(r^2) * cos(theta)
Vout = C/(r^2) * cos(theta)
We are told that "as r tends to 0 the field must approach the dipole field".
I'm not sure if they are talking about the E-field or the potential, as the E-field does not appear to tend to a dipole field as r tends to zero (if you differentiate Vin wrt r to get the E-field, you find a term Acos(theta) which does not tend to zero as r tends to zero. therefore we don't get a purely dipole type field. is it legitimate to let r tend to zero first, then perform the differentiation to get the E-field, or are they just talking about the potential anyway in the first place?)
thanks for your help
The order of differentiation doesn't matter. Remember that the dipole part blows up at r = 0 so the constant term gets completely swamped, that's what they mean when they say the field approaches the pure dipole field. The purpose of this condition is simply to tell you what the coeffecient B is.
1. What is a dipole in a dielectric?
A dipole in a dielectric is a term used in physics to describe a system where there is a separation of positive and negative charges within a material. This creates an electric dipole moment, which is a vector quantity that measures the strength and direction of the separation.
2. How is r→0 used in the analysis of a dipole in a dielectric?
In the context of a dipole in a dielectric, r→0 refers to the distance between the two charges of the dipole becoming very small. This is used in the analysis to simplify the calculations and make certain assumptions about the behavior of the dipole.
3. What is the significance of the dielectric in a dipole?
The dielectric is the material in which the dipole is located. It is important because it affects the strength and direction of the electric field surrounding the dipole. The dielectric also plays a role in determining the capacitance of the dipole.
4. How does the orientation of a dipole affect its behavior in a dielectric?
The orientation of a dipole refers to the direction of the separation between the positive and negative charges. This orientation can affect the strength and direction of the electric field, as well as the energy stored in the dipole. In a dielectric, the orientation can also affect the polarization of the material and its ability to store charge.
5. What are some real-world applications of dipole behavior in dielectrics?
Dipoles in dielectrics play a crucial role in various technologies, such as capacitors, sensors, and electronic devices. They also play a role in biological systems, such as the movement of charged particles in cells. Understanding the behavior of dipoles in dielectrics is also important in the study of electromagnetism and quantum mechanics.
