Derivative of the Step Function: Exploring the Delta Distribution
In summary, the derivative of a step function can be found using the definition of a step function and the Dirac Delta function. The proof involves using Green's functions and the completeness relation to show that the derivative of the step function is equal to the Dirac Delta function. Despite some challenges with the definition of the Dirac Delta function, the integral of the Dirac Delta function can be shown to be equal to one for values greater than zero.
ayan
How can I find the derivative of a step function?
Mathematics news on Phys.org
It's not defined at the step, so you can't.
But if you can tell us more about the problem that leads you to ask this question, someone here will likely be able to help; there are many here who have experience dealing with the annoyances caused by discontinuities in step and delta functions.
You can use the definition of a step function. What do you think the derivative is?
If you are not at the "step" then there exist an interval around x such that f(x) is constant. What is the derivative of that?
The derivative of the step function is the Dirac Delta function. I don't know how good of a proof this is but it's the best I could come up with haha:
You can define a function ##f## such that ##f(x)=\frac{d}{dx}step(x)## and you can see that ##f## is zero everywhere except at zero, where it is infinity. So you can define ##f## as a piecewise function. Now, to show that ##f=\delta## you need to show that $$\int_{-a}^{a}f(x)dx=1$$ if ##a>0##.
I did this using the definition of the derivative and the definition of the step function $$\int_{-a}^{a}\frac{d}{dx}step(x)dx=\int_{-a}^{a}\lim_{h \to 0}\frac{1}{h}(step(x+h)-step(x))dx$$
If you assume that ##h>0## and consider ##\int step(x)dx = x step(x)##, you can evaluate the integral and see that it equals 1. $$\int_{-a}^{a}f(x)dx=\lim_{h \to 0}\frac{1}{h}\int_{-a}^{a}(step(x+h)-step(x))dx=\lim_{h \to 0}\frac{1}{h}h=1$$
Being a bit more sophisticated. Green's functions and the like. It can easily found that
[itex]\Theta (\tau) = - {1 \over 2 \pi i} \lim_{\epsilon \rightarrow 0} \int_{-\infty}^\infty d \omega {e^{-i \omega \tau} \over \omega + i \epsilon}[/itex]
From this we get directly
[itex]{d \Theta \over d \tau} = - {1 \over 2 \pi i} \lim_{\epsilon \rightarrow 0} \int_{-\infty}^\infty {d \over d \tau} {e^{-i \omega \tau} \over \omega + i \epsilon} d \omega[/itex]
[itex]= - {1 \over 2 \pi i} \lim_{\epsilon \rightarrow 0} \int_{-\infty}^\infty {-i \omega \over \omega + i \epsilon} e^{-i \omega \tau} d \omega[/itex]
[itex]= {1 \over 2 \pi} \int_{-\infty}^\infty e^{-i \omega \tau} d \omega = \delta (\tau)[/itex]
That is not how the Dirac delta is defined, and proving ##\delta = H'## uses a different definition of derivative. Indeed it should be obvious there is no piecewise function with the properties you outlined because integrating over a point is zero from the definition of the integral.
What are you using to justify the limit passage?
It is about contour integration and Jordan's lemma isn't it? You either complete the semi-circle in the UHP or LHP depending on the sign of [itex]\tau[/itex]? There is a pole in the LHP and not the UHP. For [itex]\tau > 0[/itex] you complete with semi-circle in the LHP (getting a non-zero answer from your contour integral), for [itex]\tau < 0[/itex] you complete with semi-circle in the UHP (getting a zero answer to your contour integral). That is where the piecewise-ness comes from. The rest, getting 1, comes from the limit [itex]\epsilon \rightarrow 0[/itex] from what you end up with from the residue theorem.
That is a definition of the delta-function.
The Fourier transform is:
[itex]\tilde{f} (\omega) = \int_{-\infty}^\infty d x e^{i \omega x} f(x) \quad Eq1[/itex]
The inverse Fourier transform is:
[itex]f (x) = {1 \over 2 \pi} \int_{-\infty}^\infty d \omega e^{-i \omega x} \tilde{f} (\omega) \quad Eq2[/itex]
Say [itex]f(x) = \delta (x)[/itex] then putting this into Eq1 we get
[itex]\tilde{f} (\omega) = 1[/itex]
and putting that into Eq2 we get
[itex]\delta (x) = {1 \over 2 \pi} \int_{-\infty}^\infty d \omega e^{-i \omega x}[/itex]. It is the completeness relation basically.
Apologies, I'm not a mathematician. I just know that ##\delta = \frac{d}{dx}H## and this is the best I could do at showing why. Nobody else was really addressing the OP question.
Anyways, consider the integral $$\int_{a}^{b}\delta(x)dx$$ where ##a<b<0## or ##b>a>0##. This integral equals zero right? Even in the case where ##a \to -\infty## and ##b<0## or ##b \to \infty## and ##a>0##. So doesn't this imply that the integral in my above post must equal one as long as ##a>0##? It is clear that the only nonzero contribution to the integral is at the point ##x=0##.
$$\int_{-\infty}^{\infty}\delta(x)dx=1$$
if ##a>0##
$$\int_{-\infty}^{\infty}\delta(x)dx-\int_{-\infty}^{-a}\delta(x)dx-\int_{a}^{\infty}\delta(x)dx=\int_{-\infty}^{\infty}\delta(x)dx-0-0=\int_{-a}^{a}\delta(x)dx$$
this is true for arbitrarily small a. I see why integrating over a single point of finite value is guaranteed to equal zero, but integrating over a single point of infinite value is like a zero times infinity indeterminate case isn't it?
Hello Hertz
Well actually the delta function is often defined as the limit of a sequence of functions (non-zero values away from [itex]x=0[/itex]) and as such the step function is defined as a limit of a sequence of functions.
What you said is what I would have said. I'm not a mathematician, theoretical physics - I just know the definition I gave from scattering theory and was going to mention it as an application to physics.
Another time I went through the derivation of the Fokker-Planck equation from the Langevin equation, which involved the smoothing off of the corners of a time step function - this had a physics motivation.
Hertz said:
Anyways, consider the integral $$\int_{a}^{b}\delta(x)dx$$ where ##a<b<0## or ##b>a>0##. This integral equals zero right? <snip>
Given ##\mathbb{R}## we split it up into ##(-\infty,0)##, ##\{0\}## and ##(0, \infty)##. If you define ##f(x) = 0## for ##x \neq 0## and ##f(0)=\infty##; then
##\int_{-\infty}^\infty f(x) \, dx##
##=\int_{-\infty}^{0}f(x) \, dx + \int_0^0 f(x) \, dx + \int_0^{\infty}f(x) \, dx##
##= 0 \cdot \infty + \infty \cdot 0 + 0\cdot \infty##
In measure theory we define ##0 \cdot \infty## equal to zero, so the integral is zero from the definition of the integral.
This is why there is no real variable function with the properties of Dirac delta. Dirac is a generalized function, it does not take point values.
It's not indeterminate, the product is defined as zero in this branch of mathematics (measure theory and integration).
This is wrong and where your misunderstanding comes from. ##\frac{d}{dx}## is reserved for the standard definition of derivative you learned in high school. We have ##\frac{d}{dx}H(x) = 0## on the domain ##\mathbb{R}\setminus\{0\}##.
The Dirac delta is the distributional derivative of the Heaviside step function. You have not learned the definition so the "proof" you wrote above is invalid because you are using the wrong definition of derivative.
pwsnafu said:
Ok.
Ok. Well I was introduced to the delta function as a piecewise defined function where ##\delta=0## if ##x≠0## and ##\delta=\infty## if ##x=0## such that ##\int_{-\infty}^{\infty}\delta(x)dx=1##. Yes, I'm aware that this same function can be represented as a series of other functions. After being taught this definition, I was taught that the derivative of the heavyside step function is the delta function. It was proven to me at that point (given the definitions I was taught) but I have since forgotten what proof was used. My understanding of the Dirac Delta function is largely from Griffith's Electrodynamics book. Anyways, given my level of understanding, or lack thereof, what I said above is my best attempt at addressing the OP question of the derivative of the step function.
Anyways, regarding your claim that ##0\cdot\infty=0##, I'm still a bit confused. I wasn't aware you could define something like this. If I define ##1\cdot 2=5## it doesn't make it true. I was taught in early calculus that ##0\cdot\infty## is an indeterminate form.
-edit
I just read through the section in Griffith's book where he talks about the 1D delta function again. He does make mention of the fact that it is a 'generalized function' but he introduces it using the definition I was using. Guess I have some learning to do about generalized functions.
Anyways, even in hindsight I think my post about the derivative of the step function is quite interesting :)
I don't think the convention of [itex]\infty \cdot 0 = 0[/itex] comes into this. The fault in the proof is basically that you can't switch the limit sign with the integration sign unless the derivative (the limit) exists and the absolute value of the derivative is bounded on the domain of integration (if I remember correctly). The derivative, in the conventional sense, of the heaviside step function does not exist.
The proper way to introduce the dirac delta function is as a distribution (a linear operator on a set of functions). There are other ways, perhaps, but it's the most immediate way to do it mathematically correct, at least when restricting to functions on real domains. This can be seen as integration, but in a more general sense (integration over distributions). It is not the same as Riemann or Lebesgue integration.
A distribution is not a function from the reals to the reals, and even when extending to the extended real number line it does not make sense to say that a function [itex]\delta(x)[/itex] satisfies [itex]\int^{\infty}_{-\infty} \delta(x)f(x)dx = f(0)[/itex], unless properly defining what you mean by this integration. There are no functions with codomain the extended real number line which satisfies this if you mean Lebesgue integration, even though Lebesgue integration can deal with such functions. Since [itex]\delta(0) = \infty[/itex], in your definition, and 0 elsewhere, it is still only non-zero on a null set, which means that integrating over it, multiplied with any function, must be 0 (with Lebesgue integration). That follows from the definition of this type of integration, and the convention [itex]\infty \cdot 0 = 0[/itex], although useful and consistent in this setting (still arguably somewhat arbitrary), is not the reason for it. It follows simply from that it's zero everywhere but on a null set (a null set is a set with Lebesgue measure 0).
If you are going to talk about the delta "function" as being the derivative of the step function, then you are going to have to talk in terms of "distributions" or "generalized functions", not just functions.
1. What is the Dirac delta function?
The Dirac delta function, also known as the impulse function, is a mathematical function used to model a point or spike at a specific location. It is defined as zero everywhere except at the origin, where it is infinite, and its integral over the entire real line is equal to one.
2. How is the Dirac delta function related to the Kronecker delta function?
The Kronecker delta function is a discrete version of the Dirac delta function, where it takes the value of one when the input is zero and zero otherwise. Both functions are used to represent impulses or spikes, but the Dirac delta function is a continuous function while the Kronecker delta function is a discrete function.
3. What is the physical interpretation of the Dirac delta function?
The Dirac delta function is often used in physics to represent a point mass or charge at a specific location. It is also used to model idealized point sources of energy, such as a point source of light or heat.
4. How is the Dirac delta function used in engineering and signal processing?
In engineering and signal processing, the Dirac delta function is used to represent a very short or instantaneous signal. It is also used to model impulse responses of systems, such as filters and amplifiers.
5. What are the properties of the Dirac delta function?
The Dirac delta function has several important properties, including the sifting property, linearity, and time-shifting. It is also related to the unit step function and the Heaviside function, and it can be convolved with other functions to produce interesting results.
  • General Math
24K
  • Calculus
  • General Math
  • General Math
  • General Math
  • General Math
