Dirac Notation and commutation
  • Thread starter maximus123
maximus123
50
Hi everyone, my problem is this
Using Dirac notation show that
[itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|[itex]\hat{A}[/itex]|[itex]\varphi[/itex]> = [itex]\frac{i}{\hbar}[/itex]<[itex]\varphi[/itex]|[[itex]\hat{H}[/itex],[itex]\hat{A}[/itex]]|[itex]\varphi[/itex]>
where A does not explicitly depend on t
I am given as a hint that the hamiltonian operator in Dirac notation is
i[itex]\hbar[/itex][itex]\frac{d}{dt}[/itex]|[itex]\varphi[/itex]>=[itex]\hat{H}[/itex]|[itex]\varphi[/itex]>
and that the conjugate expression is
-i[itex]\hbar[/itex][itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|=<[itex]\varphi[/itex]|[itex]\hat{H}[/itex]
I'm a bit stumped, I know that the left hand side of the equation is the time derivative of the expectation value of operator A but as for the right hand side. I tried to expand the commutator as normal as if it were acting on the function (ket) |phi> but this came out to be zero which if true would surely make the whole RHS zero, which makes me think I don't understand what the rhs means. Any help would be appreciated.
Answers and Replies
CAF123
88
Perhaps start with the LHS first and rewrite $$\frac{d}{dt} \langle \hat{A} \rangle = \frac{d}{dt} \langle \psi | \hat{A} | \psi \rangle = \frac{d}{dt} \int dx\, \psi^* \hat{A}\, \psi$$
The RHS can be zero but only if ##\hat{A}## and ##\hat{H}## were to commute, but this was not given.
JorisL
492
189
Use the product rule one the left hand side first.
Then impose the hint to rewrite some of the terms.
It should become quite clear almost immediately.
An extra question, does it change a lot if the operator A does explicitly depend on time?
maximus123
50
Thanks to both of you, I think I have it
[itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|[itex]\hat{A}[/itex]|[itex]\varphi[/itex]> = <[itex]\varphi[/itex]|[itex]\hat{A}[/itex][itex]\frac{d}{dt}[/itex]|[itex]\varphi[/itex]> + [itex]\hat{A}[/itex][itex]\varphi[/itex]>[itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|
then from the hints
[itex]\frac{d}{dt}[/itex](|[itex]\varphi[/itex]>) = [itex]\frac{\hat{H}}{i\hbar}[/itex]( |[itex]\varphi[/itex]>) and [itex]\frac{d}{dt}[/itex](<[itex]\varphi[/itex]|) = -[itex]\frac{\hat{H}}{i\hbar}[/itex]( <[itex]\varphi[/itex]|)
Substitute those in, do a bit of simplifying and rearranging then I got the correct answer. Thanks a bunch
I do have another question if I may
I have to show how we get the commutation identity [[itex]\hat{A}[/itex],[itex]\hat{B^{2}}[/itex]]=[[itex]\hat{A}[/itex],[itex]\hat{B}[/itex]][itex]\hat{B}[/itex] + [itex]\hat{B}[/itex][[itex]\hat{A}[/itex],[itex]\hat{B}[/itex]] but am having trouble, I'd be very grateful for any suggestions in the right direction.
Thanks again
CAF123
88
Thanks again
Try working with the RHS this time and show that it reduces to the LHS.
Also, [itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|[itex]\hat{A}[/itex]|[itex]\varphi[/itex]> = <[itex]\varphi[/itex]|[itex]\hat{A}[/itex][itex]\frac{d}{dt}[/itex]|[itex]\varphi[/itex]> + [itex]\hat{A}[/itex][itex]\varphi[/itex]>[itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|
in the second term, I think that should be ##\left( \frac{d}{dt} \langle \psi | \right) \, \hat{A} \psi,## when you are dealing with operators, the ordering matters.
maximus123
50
Thanks for the help with the last question, hadn't realized it would be so easy, however for my original problem, what I meant in that term you flagged up is
([itex]\hat{A}[/itex]|[itex]\varphi[/itex]>)([itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|)
Is this not correct? I thought
([itex]\hat{A}[/itex]|[itex]\varphi[/itex]>)([itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|) = ([itex]\frac{d}{dt}[/itex]<[itex]\varphi[/itex]|)([itex]\hat{A}[/itex]|[itex]\varphi[/itex]>)
Is that not right?
Thanks again
MisterX
764
71
No it's not right. It's like [itex]\mathbf{v}^T\mathbf{w} \neq \mathbf{w} \mathbf{v}^T[/itex]
The first results in a scalar (it's a representation of an inner product), the second results in a higher order tensor (or in other words it's an outer product).
[itex]\langle a \mid b \rangle[/itex] is a scalar.
[itex]\mid a \rangle \langle b\mid[/itex] is an operator that "eats" up [itex]\mid b \rangle[/itex] and results in some multiple of [itex]\mid a \rangle [/itex].
Judas503
23
First, if you assume the operator has an explicit time dependence, you can write:
[itex] \frac{d}{dt}\langle \phi |A(x,t)|\phi\rangle = \langle \frac{d\phi}{dt}|A|\phi\rangle +\langle \phi|\frac{dA}{dt}|\phi \rangle +\langle \phi |A|\frac{d \phi}{dt}\rangle [/itex]
Then, the R.H.S. can be simplified to:
[itex] \frac{1}{-i\hbar}\langle \phi |HA|\phi \rangle + \frac{1}{i\hbar}\langle \phi |AH|\phi \rangle +\langle \frac{dA}{dt}\rangle[/itex]
The final result is:
[itex] \frac{i}{\hbar}\langle [H,A]\rangle + \langle \frac{dA}{dt}\rangle [/itex]
Drop the dA/dt for no explicit time dependence.
Suggested for: Dirac Notation and commutation
  • Last Post
  • Last Post
