Understanding Dirac Notation in Quantum Mechanics
In summary: Not quite. |\phi\rangle is a basisvector if and only if it is an eigenvector of the operator A. If it is not an eigenvector of A, then it is not a basisvector.
phyky
57
1.) an inner product of a state vector represent by <[itex]\psi[/itex]|[itex]\psi[/itex]>. sometimes the notation is like <[itex]\phi[/itex]|[itex]\psi[/itex]> is mean transfer from state |[itex]\psi[/itex]> to <[itex]\phi[/itex]|.it mean the former 1 do not transfer the state? what is the difference between both?
2.) what is mean by <x|[itex]\psi[/itex]>? is it mean x(position) mean the final state we reach where we extract form |[itex]\psi[/itex]> ? from eigen value equation [itex]\hat{x}[/itex] |[itex]\psi[/itex]>=[itex]\lambda[/itex]|[itex]\psi[/itex]> where [itex]\lambda[/itex] is the eigen value of position. so why do we need <x|[itex]\psi[/itex]>?
It is similar to the dot product of ordinary vectors. It is not a "transfer", but rather a projection. ##\langle \psi | \psi \rangle## is the "length" of the state ##\psi##. It is equal to 1 if the state is normalized.
I will not go into the fact that ##\langle x |## is not a proper bra, but basically writing
##\langle x | \psi \rangle## allows to given a representation of the state ##| \psi \rangle## as a wave function of the cartesian coordinate ##x##,
\psi(x) = \langle x | \psi \rangle
##| \psi \rangle## is an arbitrary quantum state, not an eigenvector of the ##\hat{x}## operator.
is projection kinda same as the ψ "collapse" to 1 of the eigenstate [itex]\phi[/itex]?
No. Do you know anything about dot-products from linear/vector algebra? The <|> inner products are just generalization of dot-product. Phi and psi are vectors, and [itex]\langle \phi | \psi \rangle[/itex] is just a dot-product between the two. Of course, in the continuous case, the sum over components becomes an integral over position. Hence if you are given [itex]\langle x | \psi \rangle = \psi(x)[/itex] and [itex]\langle x | \phi \rangle = \phi(x)[/itex], then [itex]\langle \phi | \psi \rangle = \int \phi^*(x)\psi(x) dx[/itex].
But if $\phi$ is an eigenfunction of $\psi$, then:
\begin{equation}
\end{equation}
is the transition amplitude, right? (I think that is maybe what the OP is asking.)
[itex]|\phi\rangle[/itex] is a vector. So is [itex]|\psi\rangle[/itex]. So one can't be an eigen vector of the other. Because they are both vectors. To have an eigen vector, you must be dealing with a map from a Hilbert space to Hilbert space. Such a map is called an operator. So if A is an operator, then for every [itex]|\psi\rangle[/itex] there exists a corresponding vector [itex]|A\psi\rangle[/itex] such that [itex]|A\psi\rangle = A|\psi\rangle[/itex]. Furthermore, if [itex]|\psi\rangle[/itex] is an eigen vector of A, then [itex]A|\psi\rangle = \lambda |\psi\rangle[/itex] for some [itex]\lambda[/itex].
Yeah, you are completely right. Sorry. I meant if [itex]|\phi\rangle[/itex] is a basisvector of the Hilbert space, then my statement is correct?
1. What is Dirac notation confusion?
Dirac notation confusion refers to the difficulty in understanding and applying the mathematical notation developed by physicist Paul Dirac for describing quantum states and operations.
2. Why is Dirac notation important?
Dirac notation is important because it provides a concise and elegant way to represent complex quantum systems and perform calculations in quantum mechanics. It also allows for a better understanding of fundamental principles and relationships in quantum physics.
3. What are some common sources of confusion with Dirac notation?
Some common sources of confusion with Dirac notation include understanding the meaning and use of symbols such as kets, bras, and operators; dealing with complex numbers and their conjugates; and correctly applying notation rules such as the bra-ket inner product.
4. How can I overcome Dirac notation confusion?
To overcome Dirac notation confusion, it is important to have a strong foundation in linear algebra and quantum mechanics. Practice and familiarity with the notation is also key. Seeking out additional resources, such as textbooks or online tutorials, can also help clarify any confusion.
5. Can I use Dirac notation in other areas of science?
Yes, Dirac notation can be used in other areas of science, particularly in fields that involve linear algebra and complex numbers. It has applications in quantum computing, signal processing, and even classical mechanics. However, it is most commonly used in quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
