Homework Help: Dirac notation with operators
  1. Apr 4, 2012 #1
    [A[itex]^{+}[/itex]A]=1
    A|a>=[itex]\sqrt{a}[/itex]|a-1>
    A[itex]^{+}[/itex]|a>=[itex]\sqrt{a+1}[/itex]|a+1>
    <a'|a>=[itex]\delta_{a'}_{a}[/itex]
    2. Relevant equations
    what is
    1 <a|A|a+1>
    4. <a+1|A[itex]^{+}[/itex]|a>
    3. <a|A[itex]^{+}[/itex]A|a>
    4. <a|AA[itex]^{+}[/itex]|a>
    3. The attempt at a solution
    1. <a|A|a+1> =<a|[itex]\sqrt{a+1}[/itex]|a+1-1>=[itex]\sqrt{a+1}[/itex]<a|a>
    since a=a and since its the Knocker delta it equals 1 so it equals
    2.<a+1|A[itex]^{+}[/itex]|a>=<a+1|[itex]\sqrt{a+1}[/itex]|a+1>=
    [itex]\sqrt{a+1}[/itex]<a+1|a+1>
    since a+1=a+1 and since its the Knocker delta it equals 1 so it equals
    <a|A[itex]^{+}[/itex]A|a> this is where i am having problems
    (<a|A[itex]^{+}[/itex])*(A|a>)= A[itex]^{+}[/itex]A<a|a>=1 is this right
    the same is for part 4
  3. Apr 4, 2012 #2
    fzero
    The left-hand side is a good idea, but the right-hand side makes no sense. You can't just pull the operators out of the inner product. However, if you can compute the action of the operator in terms of an eigenvalue, you can pull the ordinary number out. In this case, note that
    [tex] (\langle a | A^\dagger) = (A | a\rangle)^\dagger,[/tex]
    so that you can use the expression for [itex]A|a\rangle[/itex] to compute[itex] (\langle a|A^\dagger)(A|a\rangle)[/itex] directly.
  4. Apr 5, 2012 #3
    Ok so in this case [tex] (\langle a | A^\dagger) = (A | a\rangle)^\dagger,[/tex] would that make it equal to [itex]\sqrt{A}[/itex]|(a+1) and then how do you take the adjoint of that expresion
  5. Apr 5, 2012 #4
    fzero
    You want to be a bit more careful typing things out here. I realize it can be hard to figure out all of the codes to type formulas here, but you should stick to the same notation you've been using. So instead of [itex]\sqrt{A}[/itex]|(a+1), you probably mean [itex]\sqrt{a}[/itex]|(a+1), since we were using capital A for the operator and lowercase a for the eigenvalue.
    In any case, A is a lowering operator, so it lowers the index of the state it acts on. From your original post, you were given the correct result [itex]A|a\rangle = \sqrt{a}|a-1\rangle[/itex].
    As for taking adjoints, the results you need are that
    [tex] \langle \psi | = ( |\psi \rangle )^\dagger.[/tex]
    [tex] ( c | \psi \rangle )^\dagger = \langle \psi | c^* ,[/tex]
    where [itex] c[/itex] is a complex number and [itex]c^*[/itex] is its complex conjugate.
  6. Apr 5, 2012 #5
    Since there is no complex number involved with the would it just be that [tex] ( A | a \rangle )^\dagger = \langle a | A^* ,[/tex] is equal to [tex] \langle a-1 | \sqrt{a} ,[/tex]
    and the answer be [tex] \langle a-1 | \sqrt{a} \sqrt{a}|a-1\rangle [/tex].
    or a*<a-1|a-1>
    sorry just having a hard time seeing this its hard to picture
    from my understanding the whole thing with bra ket notation is that is is supposed to represent vector space <a| are the columns and |a> are the rows So you have the operator acting upon the rows in such kind of like a scalar on an vector.
    [itex]\sqrt{a}|a-1\rangle[/itex] \sqrt{a}|a-1\rangle[/itex].
    So in the above is the [itex]\sqrt{a}[/itex] the eigenvalue acting on the vector [itex]|a-1\rangle[/itex]
  7. Apr 5, 2012 #6
    fzero
    The second expression is fine because you just have a number multiplying the state, but when you have an operator in the first expression, you should really use the adjoint [itex]A^\dagger[/itex]. The reason is that, if you are working with vectors and matrices, like you mention below, the adjoint of a matrix operator is obtained by taking the complex conjugate of the matrix elements combined with the transpose of the matrix.
    Yes and you can simplify this a bit more by using orthonormality like you did earlier.
    That's correct.
  8. Apr 5, 2012 #7
    Thank you so much for the help. You are a lifesaver
  9. Aug 12, 2012 #8
    Is the commutator [A+ A] = 1 in the givens correct ?
    I get [A+ A] = -1 based on the definitions that follow.
    And therefore [A A+] = 1, consistent with my getting answers a and a+1 for equations 3 and 4, regardless of whether I apply both operators in turn to the ket, or apply the first to the bra and the second to the ket.
