Dirac Wave Function: Schrodinger Equation Coupling
In summary: In fact, the whole point of relativistic quantum field theory is that it allows for the existence of billions and billions of particles. However, because these particles always interact with each other, the theory can never be completely described in terms of a set of wave functions. This is why relativistic quantum field theory is also known as a "quantum field theory with particles."
jamie.j1989
79
Hi, is the wave function that couples to the Dirac equation the same as that which couples to the Schrodinger equation? Thanks.
No, it's different, the biggest difference is that the Dirac equation has a bispinor as a solution. But generally the Dirac wavefunctions follow relativistic transformation rules, the Schroedinger ones are Galileian.
In addition, it has a completely different physical meaning. It cannot be interpreted easily as a "wave function" like in nonrelativistic physics. The reason is that at relativistic energies, you always can create and destroy particles in scattering processes. The Dirac equations solutions are Dirac-spinor fields. They are best interpreted in their quantized form, leading to relativistic quantum-field theory, because this is the most elegant way to describe particle creation and destruction or, more generally, many-body systems in quantum theory.
Likes bhobba
Yes. Though I didn't want to stress that because single-particle relativistic QM, inconsistent as it is in the fundamental interactions context, has consequences like Klein's paradox that actually show up in solid state physics iirc.
Well, the Klein paradox occurs precisely because of the problems when enforcing a single-particle interpretation!
I don't quite understand why if particles can be created and destroyed in scattering processes at relativistic energies we can't easily interpret it as a wave function? Also by scattering processes are you referring to particle collisions?
If particle numbers are not fixed you have a Fock Space and the QFT formalism.
Its inevitable when you combine it with relativity that particle numbers are not fixed - see for example section 8.3 of:
https://www.amazon.com/dp/019969933X/?tag=pfamazon01-20
Thanks
Bill
Likes vanhees71
What is the Dirac wave function?
The Dirac wave function is a mathematical description of the quantum state of a particle, based on the work of British physicist Paul Dirac. It is a complex-valued function that describes the probability amplitude of finding a particle at a specific location and time.
What is the Schrodinger equation?
The Schrodinger equation is a fundamental equation in quantum mechanics that describes how the quantum state of a physical system changes over time. It relates the time evolution of a system's wave function to its energy and potential energy.
How are the Dirac wave function and Schrodinger equation coupled?
The Dirac wave function and Schrodinger equation are coupled through a process known as the Dirac equation, which combines the principles of special relativity and quantum mechanics. This equation allows for the prediction of the spin of a particle, which cannot be described by the Schrodinger equation alone.
What is the significance of the Dirac wave function and Schrodinger equation coupling?
The coupling of the Dirac wave function and Schrodinger equation allows for a more complete understanding of the behavior of particles at the quantum level. It also provides a framework for understanding the relationship between energy, momentum, and spin in quantum mechanics.
What are some applications of the Dirac wave function and Schrodinger equation coupling?
The Dirac wave function and Schrodinger equation coupling have many practical applications, including in the fields of quantum computing, nuclear physics, and materials science. They also play a crucial role in the development of quantum field theory and have been used to make accurate predictions in particle physics experiments.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
