Dirac's K
  • Thread starter wavemaster
Main Question or Discussion Point
In http://nobelprize.org/nobel_prizes/physics/laureates/1965/feynman-lecture.html" [Broken], he mentions this:
...So I simply put them equal, taking the simplest example where the Lagrangian is [tex]\frac{m}{2}\dot{x}^2 - V(x)[/tex] but soon found I had to put a constant of proportionality A in, suitably adjusted. When I substituted [tex]Ae^{i \epsilon L / \hbar}[/tex] for K to get
[tex]\varphi(x',t+\epsilon) = \int A e^{\frac{i}{\hbar} L(\frac{x'-x}{\epsilon},x) \epsilon} \varphi(x,t) dx[/tex]
and just calculated things out by Taylor series expansion, out came the Schrödinger equation.
I'm trying to get the same result, but I'm stuck. Has anyone done this before?
Answers and Replies
samalkhaiat
Insights Author
1,693
935
Write [tex]L= \frac{1}{2} (\frac{x-x'}{\lambda})^{2} - V(x)[/tex] , change integration variable to [tex]x-x'=y[/tex] , then expand [tex]V(x),\phi(x)[/tex] about [tex]y=0[/tex] and keep first order terms in [tex]\lambda[/tex] ;
[tex]\phi(x',t+\lambda)= A \int dy exp(\frac{iy^{2}}{2\lambda}) exp[-i\lambda (V(x') + yV'(x') + ..)][\phi(x',t) + y \frac{\partial {\phi(x')}}{\partial{x'}} + \frac{1}{2} y^{2}\frac{\partial^{2} \phi(x',t)}{\partial {x'}^{2}} +...][/tex]
or
[tex]\phi(x',t+\lambda) = A[1 - i \lambda V(x')] \int dy exp[\frac{iy^{2}}{2\lambda}][\phi(x',t) + (1/2) y^{2} \frac{\partial^{2}\phi}{\partial {x'}^{2}}][/tex]
we dropped the factor
[tex]exp[-iV'(x')y\lambda][/tex]
because when the integration over y is done this will be of order
[tex]\lambda^{3/2}[/tex]
we also used
[tex] \int dy y exp(-a y^{2}) = 0[/tex]
Now use the integrals:
[tex] \int dy exp(-a y^{2}) = (\pi/a)^{1/2}[/tex]
[tex] \int dy y^{2} exp(-a y^{2}) = (\pi/2)^{1/2}(1/2a)[/tex]
Schrodinger eq follows when you choose A so that the coefficient of
[itex]\phi(x',t)[/itex] is one, and take the limit [itex]\lambda\rightarrow 0[/itex];
[tex]\frac{\phi(x',t+\lambda)-\phi(x',t)}{\lambda} = \frac{\partial}{\partial{t}} \phi(x',t)[/tex]
regards
sam
Thanks for the reply!
I didn't know the bounds are infinities... Also, I couldn't get [tex]\lambda[/tex] to the 3/2th power, for [tex]-iV'(x') y \lambda[/tex], but as you did, I used only the first term for potential.
Anyway, I couldn't see how Schrödinger equation comes out from what you've written, so
I've tried to work out the details for myself, but I ended up a weird equation that is far from Schrödinger's. Here it goes:
(You seem to've cranked up [tex]\hbar[/tex] and m to 1, but for keeping a better track of things, I'm leaving them there).
[tex]L = \frac{m}{2} {(\frac{x-x'}{\epsilon})}^2 - V(x)[/tex]
[tex]y = x-x'[/tex], keeping [tex]x'[/tex] fixed, [tex]dy = dx[/tex] (I guess this was what you meant).
Then,
[tex]\varphi(x',t+\epsilon) = A \int_{-\infty}^{\infty} e^{\frac{im}{\hbar \epsilon}y^2} e^{-\frac{i}{\hbar} \epsilon V(x')} (\varphi(x',t) + y\frac{\partial \varphi(x',t)}{\partial x} + \frac{y^2}{2}\frac{\partial^2 \varphi(x',t)}{\partial x^2}) dy[/tex]
[tex]\varphi(x',t+\epsilon) = A e^{-\frac{i}{\hbar} \epsilon V(x')} (\varphi(x',t)\sqrt{\frac{\pi}{-im/\hbar \epsilon}} + \frac{1}{2}\frac{\partial^2 \varphi(x',t)}{\partial x^2} \sqrt{\frac{\pi}{2}} \frac{1}{2(-im/\hbar \epsilon)})[/tex]
To make coefficient of [tex]\varphi(x',t)[/tex] 1, A should obey:
[tex]A e^{-\frac{i}{\hbar} \epsilon V(x')} \sqrt{\frac{\pi}{-im/\hbar \epsilon}} = 1[/tex]
By making A so, I got:
[tex]i\hbar \frac{\partial \varphi}{\partial t} = -\frac{\hbar^2}{2m} \frac{\partial^2 \varphi}{\partial x^2} \frac{i}{2\sqrt2} \sqrt{\frac{\hbar \epsilon}{im}}[/tex]
which has some weird coefficients for spatial derivative, and missing the potential term. Am I (or maybe you) doing something wrong??
samalkhaiat
Insights Author
1,693
935
Write
[tex]e^{-\frac{i}{\hbar} \epsilon V(x')}= 1 - \frac{i}{\hbar} \epsilon V(x')[/tex]
so that you dot miss the potential term :smile: ,
then make equal to one the coefficient of [tex]\varphi(x',t)[/tex] NOT [tex]\varphi(x',t) V(x')[/tex]
now try it :wink:
regards
sam
Ups. I missed that bit. So my A became
[tex]A \sqrt{\frac{\pi}{-im/\hbar \epsilon}} = 1[/tex]. [tex]V(x') \frac{\partial^2 \varphi}{\partial x^2}...[/tex] term is dropped since it has an second order [tex]\epsilon[/tex]. OK, by doing so, I had the potential term nicely, but I still have a weird extra coefficent in the same place. This time, it's this:
[tex]\sqrt{\frac{im}{8 \hbar \epsilon}}[/tex].
Can you spot the error this time?..
Umm.it seems too easy :rolleyes: :rolleyes: if all physics were so easy we shouldn't have problem finding Quantum Gravity:
As far as i know the Integral equation satisfied by the wave is:
[tex] \psi(x',t')=\int_{-\infty}^{\infty}dxdtG(x,x',t,t')\psi(x,t) [/tex]
with [tex] G(x,x',t,t')=A\int D[x]e^{iS(x)]/\hbar [/tex]
[tex] S(x)=\int_{a}^{b}dt [(1/2)m(\dot x)^{2}-V(x)] [/tex]
However the Functional integral above can't be done except for "Semiclassical Approach" or when V(x)=0 or V(x)=x^{2}
samalkhaiat
Insights Author
1,693
935
the error was in
[tex] \int dy e^{-a y^{2}} = (\pi/2)^{1/2}(1/2a)[/tex]
it should be
[tex] \int dy e^{-a y^{2}} = (\pi/a)^{1/2}(1/2a)[/tex]
I think my miss-keying is to blame :frown:
regards
sam
Horray! :approve: Huge thanks, finally Schrödinger equation did come out!
One last question, how could you (or Feynman) see which term you had to expand? I rather tried expanding [tex]e^{iLdt/\hbar}[/tex] directly, without expanding the potential term around a fixed point, and without leaving a [tex]e^{imv^2/2\hbar}[/tex]. It was all a mess. I really wonder how you did see?
eljose, is that equation for QG?
samalkhaiat
Insights Author
1,693
935
Let us write
[tex]L(\frac{x-x'}{\epsilon} , x) = L(\frac{y}{\epsilon} , y+x') = T(\frac{y}{\epsilon}) - V(y+x') [/tex]
since we know the functional form of T;
[tex]T= \frac{m}{2}(\frac{y}{\epsilon})^{2}[/tex]
and this can be integrated out, then we only need to expand [tex]V(y+x')[/tex] .
We also do not expand the e first;
[tex]e^{iL\epsilon} = 1+ iL \epsilon + ...[/tex]
because this would lead to divergent integrals.
I hope this helps.
sam
Related Threads on Dirac's K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
