Understanding the Dirac Delta Function in Spherical Coordinates
In summary, the given expression is in spherical coordinates and represents a volume integrand. The delta function in each coordinate represents an infinitesimal cube in the limit, and the r^2 * sin(theta) factor comes from the Jacobian for the coordinate transform from Cartesian to spherical coordinates. Additionally, the expression can be written as a product of three one-dimensional delta functions for each coordinate.
element1945
29
Justify the following expretion, in spherical coordinates;
delta (vector r) = (1 / r^2 * sin (theta) ) * delta(r) * delta(theta) * delta(phi)
I don't know what it means... please help?
are you sure you don't mean
[tex]
r^2{\sin{\theta}.dr.d\theta.d\phi
[/tex]
this an expression for a volume integrand, over spherical coordinates [tex](r, \theta, \phi)[/tex]
the delta represents each coordinate integral, whilst the [tex]r^2\sin{\theta}[/tex] factor comes from the jacobian, based on the coordinate transform from cartesian to spherical coordinates
in simple terms try drawing the volume element formed by the infintesimals, (approximating a infintesiaml cube in the limit..)
[tex]
dV = d\textbf{r} = r^2\sin{\theta}.dr.d\theta.d\phi
[/tex]
and you will see where the [tex]
r^2{\sin{\theta}
[/tex] terms comes from
I'l presume also aside from using the Jacobian for the coordinate transom one should start with:
[tex]\delta(x-x_o,y-y_o,z-z_o)=\delta(x-x_o)\delta(y-y_o)\delta(z-z_o)[/tex]
Cheers John, I've re-read the question - missed the meaning of delta first time round...
element1945 can you elaborate on the problem at all? also do you understand what the 1 dimensional delta function is?
What is the Dirac delta function?
The Dirac delta function, also known as the delta function or impulse function, is a mathematical function that is defined as zero everywhere except at the origin, where it is infinitely large.
What is the purpose of the Dirac delta function?
The Dirac delta function is commonly used in mathematics and physics to represent a point or localized source of energy or mass. It is also used to represent a distribution of point charges or masses in fields such as electromagnetism and fluid dynamics.
How is the Dirac delta function defined mathematically?
The Dirac delta function is defined as δ(x) = 0, x ≠ 0 and ∫δ(x)dx = 1. It can also be defined as the limit of a sequence of functions that approach a delta function as their width approaches zero.
What are the properties of the Dirac delta function?
The Dirac delta function has several important properties that make it useful in mathematical and physical applications. These include the sifting property, linearity, scaling, and convolution, among others.
What are some real-world applications of the Dirac delta function?
The Dirac delta function has many applications in physics, engineering, and mathematics. Some examples include representing point sources in electric and magnetic fields, modeling impulse responses in signal processing, and solving differential equations in quantum mechanics.
  • Differential Geometry
