1. Not finding help here? Sign up for a free 30min tutor trial with Chegg Tutors
Direct Comparison Test
  1. May 6, 2013 #1
    Show that:
    [itex]\sum \frac{3}{n^{2} + 1}[/itex]
    converges from n = 1 to ∞
    2. Relevant equations
    If Ʃbn converges, and Ʃan < Ʃbn.
    Ʃan also converges.
    3. The attempt at a solution
    [itex]\sum \frac{1}{n^{2}}[/itex] converges
    [itex]\sum \frac{3}{n^{2} + 1}[/itex] = 3 * [itex]\sum \frac{1}{n^{2} + 1}[/itex]
    [itex]\sum \frac{1}{n^{2} + 1}[/itex] < [itex]\sum \frac{1}{n^{2}}[/itex] for all n from 1 to ∞.
    Therefore [itex]\sum \frac{1}{n^{2} + 1}[/itex] converges.
    Therefore [itex]\sum \frac{3}{n^{2} + 1}[/itex] also converges.
    The problem I am having is if the 3 remained in the summation.
    [itex]\sum \frac{3}{n^{2} + 1}[/itex] is not less than [itex]\sum \frac{1}{n^{2}}[/itex] for all n from 1 to ∞.
    Why does placing the 3 outside the summation make the problem work?
  3. May 6, 2013 #2
    SammyS
    Staff Emeritus
    If you leave the 3 inside the sum, you will have to find a different converging series to compare it to. The method will still work.
  4. May 6, 2013 #3
    So that means I would need to compare the series to [itex]\frac{3}{n^{2}}[/itex] instead.
    I can prove [itex]\frac{3}{n^{2}}[/itex] through the integral test. Though speaking of the integral test, it doesn't seem like the test works for the original series since I am getting tan-1(∞). So would the integral test be inconclusive in this case?
  5. May 6, 2013 #4
    Dick
    arctan(∞), which is what I assume is what you mean by tan^(-1)(∞), is finite.
  6. May 6, 2013 #5
    Ray Vickson
    You are making it WAAAAAY too complicated: it is a simple fact---easily proved---that if c is a constant, then ##\sum_n c a_n = c \sum_n a_n##, in the sense that if one side converges, so does the other (and the two sides are equal), and if one side diverges so does the other.
  7. May 6, 2013 #6
    SammyS
    Staff Emeritus
    No. You would not necessarily have to compare to [itex]\displaystyle \sum_{n=1}^\infty\frac{3}{n^{2}}\ .[/itex]
    There are many other possibilities.
Have something to add?
Draft saved Draft deleted
