• Support PF! Buy your school textbooks, materials and every day products Here!
Direct current circuit
  • Thread starter zvee_y
I've attached the problem in this post, so that's way yall can see the problem and picture easily.
3. The Attempt at a Solution
what is this signal [tex]\sum[/tex] means in the problem?
THe problem said they find the ammeter in the cirucuit read 2A, I just wonder is it the total current?
If i set up I = I1 + I2, then in loop 1 (top loop) I can use I and I1 to; and in loop 2(bottom loop) I can use I and I2 in order to find the currents. Is it correct? Please give me a hint. Thank you!!
Answers and Replies
mgb_phys
7,744
The symbol is a capital Sigma, it generally means sum of ( ie add them all up )
ps - You don't seem to have attached the picture properly
31
Thanks. I did fixed the picture. Can anyone please help me out?
454
define the potential to the point to the right of the ammeter to be 0.
call the potential to the left of th 5 ohm resistance U.
What must U be to make the current through the ammeter equal to 2A?
Once you have U you can calculate I_1 and the use kirchhof's current law to get I_2
458
Go around the bottom loop and go around the top loop using Kirchoff's loop law, then find I3 through the ammeter in terms of I1 and I2. 3 equations and 3 unknowns.
I want answer for questions, wuold you help mme?
Defennder
2,579
Unfortunately no one can give you the answer, per PF rules. Show your work and we'll help you if you have problems.
Related Threads for: Direct current circuit
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
