• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Direction of magnetic forces
  • Thread starter pyradell
1. Homework Statement
Two long parallel wires A and B. They are shown from a plane perpendicular to the wires.
There is a point P with some distance "d". This creates an "L" shape if you play connect the dots and look down on the paper.
1)What is the magnetic force on wire B if only A carries a current?
In this scenario the current in wire A is headed into the paper or away from me when looking down. Using the RHR this means my fingers are curled clockwise.
2)What is the magnetic force on proton P traveling to the right(in the direction of B) if only wire A is carrying a current.
In this scenario the current in wire A is headed out of the paper or towards me when looking down. Using the RHR this means my fingers are curled counter-clockwise.
3. The Attempt at a Solution
1) I figured, from using the RHR, that the field at B from A points down, tangent to the circular magnetic field lines(again looking down at the paper). Since only wire A has current running through it and none through wire B that there shouldn't be any force exerted on wire B(at least i believe so). If there was current running through wire B then the force on B would either attract or repel from A depending on current direction. My answer is there is no force on B or zero force.
2)I have no clue how to work this(well i'm not confident if i do know) but if i were to try and give it a go, I would have to say that the force on the proton is going to point towards the direction the current flows which is out of the paper in this scenario. I figured i'd use the RHR yet again.
Any help(if wrong) or a clearer understanding(if right) would be nice.
Thanks.
PeterO
2,425
46
Thanks.
Don't you need a current in both wires to get an induced force?
Related Threads for: Direction of magnetic forces
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
