Direction of wall shear stress
In summary, shear stress in a cylindrical tube can be represented by two equations: \tau = \mu \frac {\partial u} {\partial r} and \tau = - \mu \frac {\partial u} {\partial r}. The latter is used to arrive at a formula like \tau = - \frac{r}{2} \frac{dP}{dx} for positive shear stress in uniform flow. This is because the first equation represents shear in the fluid, while the second represents shear seen by the wall. The official nomenclature for speaking about these two types of shear is the Cauchy Stress Relationship, which is important to understand in fluid and solid mechanics problems.
Tunneller
What is the definition of shear stress in a cylindrical tube? It seems like sometimes that is written
[tex] \tau = \mu \frac {\partial u} {\partial r} [/tex]
but then at some magic moment it gets rewritten as
[tex]\tau = - \mu \frac {\partial u} {\partial r} [/tex]
so as to arrive at formula like
[tex] \tau = - \frac{r}{2} \frac{dP}{dx} [/tex]
for a value of positive shear stress in uniform flow.
So I guess this is because the one is shear in the fluid and the other is shear seen by the wall, or the other way around...
The slickest explanation I saw of this was to posit
[tex] \tau = \mu \frac {\partial u} {\partial y} [/tex]
where y was distance from the wall, so with y in the opposite sign of r that gets you to positive shear stress in the fluid again. But again this seems like semantics. Is there an official nomenclature how to speak of the shear that is measured in the direction of the flow versus the shear that is measured against the direction against the flow?
Thanks
Your suspicions about the two equations are correct. To get a fundamental understanding of how to handle stress in fluid and solid mechanics problems, it is imperative to learn about the Cauchy Stress Relationship. Google this, or find it in a textbook and master its use.
What is the definition of wall shear stress?
Wall shear stress is the tangential force per unit area acting on a surface, such as a wall, due to the flow of fluid. It is a result of the friction between the fluid and the surface, and is an important factor in determining the behavior of fluid flow near walls.
What is the direction of wall shear stress?
The direction of wall shear stress is parallel to the surface of the wall. This means that the force acting on the wall is in the same direction as the flow of fluid over the wall.
How is wall shear stress calculated?
Wall shear stress can be calculated using the formula τ = μ(du/dy), where τ is the shear stress, μ is the dynamic viscosity of the fluid, and du/dy is the velocity gradient in the direction perpendicular to the wall.
What factors affect the direction of wall shear stress?
The direction of wall shear stress is primarily affected by the velocity and viscosity of the fluid, as well as the geometry of the surface. Higher velocities and lower viscosities will result in higher shear stresses, while surface roughness can also affect the distribution of shear stress.
Why is the direction of wall shear stress important?
The direction of wall shear stress is important because it can have a significant impact on the behavior of fluid flow near walls. High shear stress can cause turbulence and eddies, which can affect the efficiency of fluid flow in pipes and channels. It can also cause wear and tear on surfaces, leading to erosion and damage over time.
  • Mechanical Engineering
  • Materials and Chemical Engineering
