Dirichlet function question
  • Thread starter Pyroadept
Pyroadept
89
Define Dirichlet's function f by putting f(x) = 1 if x is rational and f(x) = 0 if x is irrational. Explain why it is difficult to draw the graph of f. Prove that the lower Riemann sum L(x_0,...,x_n) is always equal to 0 and the upper Riemann sum U(x_0,...x_n) is always equal to 1.
Equations for upper and lower Riemann sums.
Hi everyone,
Here's what I've done so far:
The graph is difficult to draw because there are infinitely many rational numbers and infinitely many irrational numbers, all interspersed among one another, so you will continuously be switching between f(x) = 0 and f(x) = 1.
For every rational number, there is an irrational number, so any chosen interval will contain both a rational [f(x) = 1] and irrational [f(x) = 0] number.
m = 0 and M = 1
So the lower Riemann sum will be zero, as two points side-by-side (i.e. a rational and an irrational with only 'vertical' area between them) will have minimum vertical area 0.
And, for the upper Riemann sum, two points side-by-side will have maximum vertical area 1.
Is this correct?
Thanks for any help
Answers and Replies
benorin
Insights Author
1,410
159
Yep, graph difficulty is correct. The graph would look like two solid lines, y=1 and y=0.
The second part is close. Between every two rational numbers lies an irrational number. In fact, the irrationals are dense in the reals. Furthermore, between every two irrationals is a rational, and generally between any two real numbers there are both irrational and rational numbers. And you got the rest.
