How Do You Calculate Angular Acceleration from Tangential Acceleration?
In summary, the disk is turning around an axle perpendicular to its center and has a constant pull, which increases in magnitude and results in an acceleration of the ball. The ball's angular acceleration reaches 1.50 m/s^2 after 3 seconds.
makeAwish
128
Disk rotating problem. urgent, help pls..
A disk of radius 30.0cm is free to turn about an axle perpendicular to it through its center. It has very thin but strong string wrapped around its rim, and the string is attached to a ball that is pulled tangentially away from the rim of the disk. The pull increases in magnitude and produces an acceleration of the ball that obeys the equation a(t) = At , where t is in seconds and A is a constant. The cylinder starts from rest, and at the end of the third second, the ball's acceleration is 1.50 m/s^2.
a. Express the angular acceleration of the disk as a function of time.
b. How much time after the disk has begun to turn does it reach an angular speed of 17.5 rad/s?
c. Through what angle has the disk turned just as it reaches 17.5 rad/s?
The attempt at a solution
I have found A to be 0.500m/s^3.
but i duno how to do part a.
can help me pls?
thanks!
i tried applying angular acceleration, alpha = r/a where a is tangential acceleration. and i get 0.3/(0.5t)
the answer shld be in (rad/s^3)t units. and is independent on t..
Hi janettaywx! :smile:
(have an alpha: α :wink:)
No, A = 0.500m/s
No, look at the dimensions …
angular acceleration (α) is in rad/s2,
and ordinary acceleration (a) is in m/s2,
and r is in m,
so a = rα, and α = a/r :smile:
hahah. thanks for the alpha.
hmm. but i tot A is accel divide by time.. so its units is rad/s³?
so α = 0.5t/0.3 ?
hmm.. it shld be indpt of t.. what shld i do next?
so α = 0.5t/0.3 ?
sorry, I misread it … you're right, it is m/s3 :redface:
No, α = 0.5t/0.3 is ok … it should be a function of t :smile:
(because a = At, and α = a/r, so α = At/r :wink:)
hmm. say i want to convert it to radians, is this how we convert?
1rev -> 2∏ rad
1 rev = 2∏r = 2∏(0.3m)
so 2∏(0.3m) = 2∏ rad
0.3m -> 1 rad
and 1m -> (1/0.3)rad
den 0.5 m/s^3 = 0.5*(1/0.3) rad/s^3?
actually, from my qns here, they sae we shld get an answer indpt of t. but i don't rly noe why cos' it is a function of t...
(why ∏? everyone uses π :wink:)
No, it's already in radians …
the radian is defined specially so that α = a/r (or ω = v/r) works without adjustment. :smile:
i see. okay thanks!
but how u do 2nd part?? to find the time.
i tried taking time = angular speed / angular accel = 10.5s
but wrong..
You have angular acceleration as a function of time …
inegrate it to get angular speed as a function of time :wink:
hi!
means i will get (1.67t^2) / 2 = 17.5
so t = 4.58s?
ok i got it. thanks a lot! :))
so t = 4.58s?
Looks good :smile:
What is the disk rotating problem?
The disk rotating problem refers to a malfunction or issue with a disk drive that causes it to stop spinning or rotate at a slower speed than normal, resulting in difficulties accessing data from the disk.
What are the common causes of the disk rotating problem?
The disk rotating problem can be caused by various factors, such as a faulty motor, damaged disk platters, or a malfunctioning disk controller. It can also be a result of physical damage to the disk or a virus or malware infection.
How can I troubleshoot the disk rotating problem?
To troubleshoot the disk rotating problem, you can try restarting your computer and checking the disk connections. You can also run disk diagnostic tools or use data recovery software to retrieve data from the disk. If these methods do not work, it is best to seek professional help.
Can the disk rotating problem be fixed?
In many cases, the disk rotating problem can be fixed, depending on the cause. If the issue is due to a malfunctioning component, it can be replaced. If the disk is physically damaged, data recovery specialists may be able to retrieve the data from the disk.
How can I prevent the disk rotating problem?
To prevent the disk rotating problem, it is essential to handle disks carefully and avoid physical damage. Regularly backing up data from the disk can also help prevent data loss in case of a malfunction. Keeping your computer protected from viruses and malware can also prevent issues with the disk drive.
