Disk Washer Method
  1. Jun 13, 2013 #1
    Find the volume of the solid generated by revolving the region bounded by y=1/sqrt(x) and y=0 for 1≤x≤2 about the line y=-1
    2. Relevant equations
    Disk Method? ∏ * ∫[f(x)]^2 dx
    3. The attempt at a solution
    A and B (lower and upper limits will be 1 and 2)?
    ∏ * ∫(1/sqrt(x)^2 dx
    ∏ * ∫1/x dx
    ∏ * ln x
    Since limits are 2 and 1, my final answer is: ∏ * ln 2
    Is this right? Thanks.
  3. Jun 13, 2013 #2
    Mark44
    Staff: Mentor
    This formula is applicable only if the rotation is around the x-axis.
    The formula would be better written as ∏ * ∫[radius]2dx
    No. Your integrand doesn't reflect the fact that the region is being rotated around the line y = -1. You can't use a disk in this case - you need to use a washer if you use vertical strips, or you could use shells if you go with horizontal strips.
  4. Jun 13, 2013 #3
    Would the correct way to set it up then be
    ∏ * ∫([1/sqrt(x)] + 1)^2) ?
    And follow up with:
    ∏* ∫[1/x + 2/sqrt(x) + 1]
    ∏ * ([ln x] + 4sqrt(x) + x) ?
    Thank you so much for all your help.
  5. Jun 13, 2013 #4
    Mark44
    Staff: Mentor
    No, this isn't set up correctly. You're using disks when you should be using washers.
    For a washer, the volume is ##\pi [(R_{outer})^2 - (R_{inner})^2]Δx##.
  6. Jun 13, 2013 #5
    But I just don't understand, even after drawing this diagram, how there's an inner AND an outer radius? If you could explain that to me, I'd appreciate it.
  7. Jun 13, 2013 #6
    Mark44
    Staff: Mentor
    The region to be rotated is roughly trapezoidal in shape. Its bottom edge is the x-axis, the left and right edges are the lines x = 1 and x = 2, and the top edge is the curve y = 1/√x.
    When the region is rotated around the line y = -1, you get a kind of ring-shaped solid that is hollow. The inner radius is 1, and the outer radius extends from the line y = -1 to the curve.
  8. Jun 13, 2013 #7
    Thank you! I am horrible at visualizing things in 3D and your description made it so much clearer.
    But how would I determine the length of the outer radius? I know that the points on the curve are (1, 1) and (2, sqrt(2)/2)- how would that help me in this problem, or would it not be of any use?
  9. Jun 13, 2013 #8
    Mark44
    Staff: Mentor
    Points on the curve are of the form (x, 1/√x). The upper end of the outer radius is at this point, and the lower end is at (x, -1). How far apart are these points?
  10. Jun 13, 2013 #9
    They are (1/sqrt(x) + 1) units apart?
  11. Jun 13, 2013 #10
    Mark44
    Staff: Mentor
    Yes, so this is the outer radius. Don't forget, it needs to be squared.
  12. Jun 13, 2013 #11
    So what I get now is:
    ∏ *∫{[(1/sqrt(x) + 1)^2] - (1^2)} * Δx (Isn't delta x = 1 since x=1 and x=2 are bounding the region?)
    ∏ * ∫(1/x) + 2/sqrt(x) + 1 - (1)
    ∏ * (ln x + 4sqrt(x))
    And since x=1 and x=2 are the left and right bounds, I'd plug that in to solve for the final volume?
    ∏* [(ln 2 + 4*sqrt(2) - (ln 1 + 4 sqrt(1)]
    ∏ * [ln 2 + 4sqrt(2) - 4]
    Is this correct?
  13. Jun 13, 2013 #12
    Mark44
    Staff: Mentor
    No, that's not what Δx means. It corresponds loosely with dx in the integral.
    I don't have time to look at this, right now, but will later on if nobody else jumps in.
  14. Jun 13, 2013 #13
    Okay thank you so much! (Yes I just realized, delta x can also be used for dx- I don't know why I even said that -_-)
  15. Jun 14, 2013 #14
    Mark44
    Staff: Mentor
    Yes, that's what I get, too.
  16. Jun 14, 2013 #15
    Thank you very much sir!
Have something to add?
Draft saved Draft deleted
Similar Discussions: Disk Washer Method
  1. Disk and washer method (Replies: 2)
Loading...
